Question about Maytag Portable Air Conditioner M6P09S2A
Red light flashing and unit will not come back on.
  • 3,741 Answers
There is a water bucket in the right side of the unit...take it out, dump it and it will work again.this will help. thanks please keep updated.please do rate the solution if helped.thank you for using fixya.
Posted on Sep 05, 2009
Green "ice size" light is
try to reset your unit to unplug the unit then after a several minutes plug it on then observe the unit.
Mar 06, 2011 | Refrigerators
Three rings are green one red on tv says error e73
Turn on unit until the red light flashes and the error code(E 73) shows up on the screen. Next insert toothpicks in the back of the console(while unit is running) into the cooling fans, this is to suppose to overheat the console and start two red lights flashing. Turn off console when this happens(unplug all cords from console) and turn the system back on.
Thank you
Jun 04, 2010 | Microsoft Xbox 360 Console
Flashing red light on the bottom right of the ring and an error code 73 picture on the screen
Hi,Turn on unit until the red light flashes and the error code(E 73) shows up on the screen. Next insert toothpicks in the back of the console(while unit is running) into the cooling fans, this is to suppose to overheat the console and start two red lights flashing. Turn off console when this happens(unplug all cords from console) and turn the system back on.
This solution will fix your problem for sure. Thank you!
May 12, 2010 | Microsoft Xbox 360 Console
What is the problem when red light is appear?
the other tech is correct but theres also other causes. if 4 red lights are flashing making a full ring your av plug at the back of the xbox is not plugged in. if it has 2 red flashing lights yor unit is overheating. 3 red flashing lights means your cpu is unstuck and is stuffed. 1 red flashing light is a HDD issue
Jun 16, 2009 | Microsoft Xbox 360 Console
Unit will not boot up, 3 flashing red lights
hello...remove the memory then make clean and take it back then to boot the unit..Good Luck and Have a nice day..^_^
May 19, 2009 | HP Compaq Business d530 PC Desktop
Kyocera Ecosys FS 920
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
YBC (/\)
Mar 24, 2009 | Kyocera FS-920 Laser Printer
Red-Eye Reduction Lamp Is not Work and I cant adjust my lenses easely my camera is nikon F80 and I Have Nikon Lenses 28-100 & 70-300
I own an F70 with similar lenses. I am not fully familiar with the F80, and therefore can't be sure what I am saying will halp, but I believe it is the next model of similar specs as mine. However, from your description, I think what you are saying is that the little red light that flashes, before the photo is taken and when you have the flash mechanism up, is no longer working, and that your camera is haveing difficulty getting a fix on the focus in automatic focus mode?
This red light is not the 'red eye reduction' flash, but rather a red light (so it doesn't make your subjects blink / squint too early) that helps the camera focus: Auto focus mechanisms need light too. If your light has stopped working, then that would explain why the camera can't focus. This should however only occur in low light conditions.
Fixes:
-Obviously, if it's still under warranty - take it back.
-Get it repaired
- OR if that's going to cost too much or you were thinking of doing so anyway, a dedicated flash unit MAY solve the problem. Most flash units have there own red light to aid autofocus. At any rate, you could take it in to a store and test a flash unit in-store to see whether it helps with the problem. If a dedicated flash unit didn't help (make sure you try it in a dark room - ask them to take it into a back room and try it) then it might suggest another problem such as: the camera is failing to send the signal to the red light to flash rather than the light not working. After all, the red light would be an LED, which have extremely long lifespans.
Mar 22, 2009 | Nikon F80 35mm Film Camera
I have a digistat scr with a flashing red light and no heating there is nothing wrong with the batteries, this only occured after a poweer cut.
Try this first before condeming the unit.
1. Turn off the power supply to the Digistat SCR (receiver unit)
and leave for 5 seconds.
2. Turn on power to SCR unit and check red light is on.
3. Press override button No.2 and check the green light comes
on and boiler fires.
4. Press & hold down button No.1 (Keep depressed), then
press No.2 and keep depressed. {The Red LED light will flash
a couple of times and then it will go out}
5. Now release both the buttons – {the two LED lights should
come back on}
6. Get the Digistat+2RF/+3RF unit and stand two metres away
from the SCR unit with the Digistat+2RF/+3RF unit in your hand.
7. Remove the battery cover and fit the batteries.
8. The Red LED light on the SCR will now flash for approx. 7
seconds.
9. This confirms that the radio signal is being sent and
received.
10. The Digistat+2RF/+3RF and the SCR are now successfully
linked by a dedicated RF address.
Mar 21, 2009 | Water Heaters
No 'green' light on bacl of my 'old' Vivitar 285
Then I'd say it's a reasonably sure thing that the green light is just burned out, The lights are supposed to be off at first, then red when there's a partial charge, then green when there's a full charge, then flashing between red and green when the "battery saver" kicks in. If you're seeing off, then red, then off, then flashing red, then that means everything in the charging circuit is working perfectly, there's just no green light.
Nov 30, 2007 | Vivitar 285HV Flash
Heating & Cooling Logo
146 people viewed this question
Top Maytag Heating & Cooling Experts
Bill Long
Donni Steen
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
