Question about Bose Cinemate Digital Home Theater System Speaker
Connecting Vizio 32 in HDTV to Bose Cinemate
I tried the suggested solution, but iI was unable to make it work. The only audio out jack for the TV is an optical connection Is there a converter box from an optical out to an RCA in on the (Cinemate)?
Thanks for any help you can give.
    Problem Solver:
  • 8 Answers
A lot of those Vizio LCDs have a headphone out. You can buy a headphone to rca conversion cable at radioshack. Hope this helps.
Posted on Sep 07, 2009
Have Technics SA-EX500 connected to Samsung Smart TV. For tv channels the sound is perfect but when I switch to Netflix or HBOGO the sound is static/cackling.
Suggest connecting via the headphones jack or if available the RCA audio output jacks. If you connect via the headphone jack you will need to adjust the TV volume to a lower setting to avoid distortion/./ The The problem is that the optical output connection is a digital connection and depending on the digital format the Digital to Analog converter may not be a configuration that the audio stream to the stereo required for the tv/vcr in.
How does the audio sound using the Samsung Smart TV internal speakers>
Also under menus/audio/settings you may need to change the Optical output to stereo.
Netflix also has settings that will change the audio stream.
Hope This helps?
Nov 21, 2016 | Samsung Audio Players & Recorders
Optical Audio output problem - What is the problem and what do I do to fix the audio output problem on my LG 55LH90 TV.
Do you have any other audio cables still plugged in that are not required,this could be the source of your echo.
Len.....
Sep 07, 2014 | LG 55LH90 55 in. LCD HDTV
No volume cinemate gs seris ii
OK, so your Bose remote is set up for your TV. That's good. You still have to connect some kind of audio output from the TV and connect it to one of the inputs on the Bose. Then you must select the input button on the Bose remote that you connected the TV to. For more information, please visit my website at audioserviceclinic.com. Thank you.
Nov 10, 2013 | Bose CineMate GS Series II Speaker System
I have recently purchased SONY MDR-DS6500 wireless headphones. Wireless transmitter have two inputs (1) Audio In : Optical Digital Input (2) Analog Stereo Input mini jack. I would like to hook it up to my...
Its all about the quality of the converter in the Headphone unit.
If the quality is lower than the quality of the converter in the receiver, then using the head jack is a better idea. Since there is more room, power, and money going into the receiver, it may be better
I do not believe that there is a cheap way to connect to the headphone with optical audio
The only way to be sure though, is to test it and see. Connect your computer to the receiver with HDMI, play audio through, and compare it to when you just connect your computer to the headphones, via optical audio
Oct 21, 2013 | Sony Audio Players & Recorders
No problem - I hope!!!! Just need to know if Direct TV is compatible.
Direct TV is compatible with all TV's. Just requires the proper cable connections
Mar 10, 2011 | Televison & Video
How to connect from panasonic lcd tv to bose cinemate II speakers?
Why? Does a TV make audio, or does the udio come from, say, a Cable Box, which is an audio device and has a) straightforward outputs and b) high fidelity.
The TV is an end point for video.
Mar 05, 2011 | Bose Cinemate Digital Home Theater System...
We have a bose audio system w time warner cable on vizio 1080p 42" tv. audio went dead. bose about two years old
did you check the audio connections? do your audio rec / amp have any fuse(s)? the tv still have sound? is the jacks on the TV external / fixed .... once you have checked all this and still no sound before you call it.......... I would unplug everything and start from scratch and reconnect before I throw/buy a replacement.......... good luck
Jan 17, 2011 | Vizio L32 32 in. LCD HDTV
I have a Bose Cinemate System and a new LG Plasma TV that it will not work with. The Bose system connects using red and white RCA connectors and needs it to be plugged into an Audio Out. The only Audio Out...
If you're using a Cinemate for HDTV listening you're missing out on multichannel sound. However, since it only supports analog 2-channel audio AND a TV or monitor is NOT a meaningful contributor to the listening experience, maybe you could extract the TV audio from the cable box where it ultimately originates in the first place. I'm sure it has a convenient and compatible RCA pair.
Dec 28, 2010 | Bose Cinemate Digital Home Theater System...
How can I hook up my Bose cinemate on my Philips HD tv when no there is no Audio out and I want to use it for my dvd player, cable box, and video systems?
You don't need to send audio TO a TV. I's a TV, not a source of anything. Many of us use monitors (no TV speakers). The Bose speakers are presumably superior to the TV speakers so whatever the TV is watching (cable/sat/dvd) shuld have its own audio.
Page 11.
If your TV does not have any audio output jacks, you can connect the CineMate™ speaker
system to the audio output jacks of another source, such as a DVD player or cable/satellite
box. However, you will hear sound only from the connected source through your CineMate
speakers.
http://www.retrevo.com/support/Bose-Cinemate-Speaker-Systems-manual/id/526dj591/t/2/
Dec 25, 2010 | Bose Cinemate Digital Home Theater System...
I can't get tv to send sound to sound system
Having browsed the user manual I wonder if you plugged in the Sony BDV T57 Home Theatre System while the Polaroid FLM-2632 tv was powered down via the optical cable .
Then powered up the Sony BDV T57 Home Theatre System first and then powered up the Polaroid FLM-2632 tv
Maybe the Polaroid FLM-2632 TV has to detect that the Sony BDV T57 Home Theatre System is connected and powered up when the Polaroid FLM-2632 powers up. To activate its digital audio out ????
The note part about only being available only under HDTV (cable/air) mode. Might be the cause of your hassle also ?
DIRECTLY FROM THE USER MANUAL
source from
http://tv.manualsonline.com/manuals/mfg/polaroid/polaroid_flm_flm2632.html
? Connecting to Audio Receiver:
Use an audio cable to connect the audio receiver's audio LINE IN jacks to LCD TV's
AUDIO OUT jacks. ? Connecting to Digital 5.1 Sound System:
METHOD A:
Use an optical cable to connect the audio amplifier's OPTICAL IN jacks to LCD TV's
OPTICAL OUT jacks.
METHOD B:
Use a coaxial cable to connect the audio amplifier's COAXIAL IN jacks to LCD TV's
COAXIAL OUT jacks.
Note: Above mentioned function is only available under HDTV (cable/air) mode.
? Connect all AC power sources, before turning on the power switch of the LCD TV or
other connected equipment.
? Press the button on the remote to turn on the LCD TV."
May 25, 2017 | Polaroid FLM-2632 Television
Bose Cinemate Digital Home Theater System Speaker Logo
1,109 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
