Question about Maytag Washing Machines
Right before my washer spins it sounds like an airplane taking off. What's wrong
  • 135 Answers
Is it a front loader? If so the rear bearing is bad. This is very expensive to replace.
Posted on Sep 05, 2009
Maytag FAV6800 AWW transmission?
the noise is more than likely coming from the clutch as you correctly surmised that the transmission only functions the paddles. As far as the airplane sound during the spin cycle well that is a bearing issue also called the "spinner support". I would be very careful attempting to replace this part yourself as doing it wrong results in a very leaky washer. The clutch runs about $150 while the spinner support runs about $250 so even though the diagnosis of the tech was clearly wrong (transmissions are relatively cheap and are fairly easy to put into these machine) it still might not be worth the money. Maytag did extend warranties on clutches for very specific models but it only covered the part and not the labor so you may still wind up with an expensive bill. I hope this helped.
Nov 16, 2012 | Maytag Neptune FAV6800AW Top Load Washer
Whirlpool washer WTW6400SW very loud spin cycle, sounds like airplane taking off
Most likely it is the spin tube bearing worn. Reguires some know how and special tools. Requires a major dismantle of the machine and usally I did these repairs in the shop. Bearing will eventually sieze over use and time. Labor will probably exceed the value of the machine.
Jul 06, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag Neptuen Washer makes loud noise when spinning. Sounds like an airplane taking off.
The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle.Get the spin bearing and motor checked.Replace the faulty. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 30, 2010 | Maytag Neptune Washer
Maytag Epic front load washer spin cycle sounds like an airplane is taking off
If you mean a jet aircraft, that is normal. Front loaders achieve amazing spin rates.
Feb 14, 2010 | Maytag MAH2400A Front Load Washer
Kenmore washer sounds like a plane taking off while spinning...
yes the rear bearing is gone,,you may have caused the issue by using the wrong soap,,in a front load you must use he soap only,,,the cost to fix 500.00-700.00
http://www.washerwizzards.com
Dec 24, 2009 | Kenmore Washing Machines
On spinning cycle machine has whirring sound and does not spin
This has to be a front loader right? if yes i have baaaaad news. you say it sounds whirlly kind of like and airplane taking off or a train going through your house? If yes YOU HAVE A BAD BEARING!!!!!!! not good news. you are better off replaceing the unit because this repair will cost more than buying a new washer. Now if it is a top loader this would be a different issue. please clarify if it is a top loader or a front loader?
Aug 14, 2009 | Whirlpool Washing Machines
Roars when spin cycle
You are right it is the bearing also called a tripple lip seal and there are special tool to do that job if it has a metal outer tub I would not repair it. If it has a plastic outer tub the repair will fix it
Mar 29, 2009 | Maytag HAV4657 Top Load Washer
Washer is extremely loud
defective back bearing and spin basket..onthejob
Feb 03, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Sounds like an airplane taking off!
check your drive block under your agitator if metal shavings replace
Nov 08, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
