Question about Frigidaire Electric Dryer
My Frigidaire dryer will only run in "no heat" mode. Any other mode the unit will start and quickly stop.
  • 1,531 Answers
Check the main power supply to the unit make sure there are no problems there. then check your heating element and thermal fuses.i think that the main control board needs ot be replaced
Posted on Sep 17, 2009
How do I make my Frigidaire Affinity dryer stop beeping and run?
Have you checked the lint has been cleaned off filter and water reservoir emptied.?
Dec 09, 2014 | Frigidaire Dryers
Dryer will run but will not heat and the lights all flash
Good Afternoon Friend,
I understand that your Frigidaire dryer, model# GLEQ2152ES, will run for a few minutes and then stop and display "AD" with the lights flashing. The "AD" means that your appliance was in an automatic dry mode. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 03, 2014 | Frigidaire GLEQ2152ES Electric Dryer
Why would a frigidaire flse60rgs1 combo dryer runs but not heat and washer not start?
check out house breaker and could be heating element problem or thermostat issues ,not enough info for more respond .
May 18, 2014 | Washing Machines
Turns on, no heat, stopas after about 5 mins and all lights start blinking.
Good Afternoon Amanda,
I understand that your Frigidaire Affinity dryer, model# FAQE7001LW, is not heating as well as only running about 5-7 minutes of the cycle before shutting off. There are a couple things to check.
    1)The gas supply valve is not open. Check to make sure that the gas valve is open.
    2)The dryer does not have enough air supply to support the burner flame. Check with your local gas company to make sure that your dryer is installed correctly.
    3)There is a possibility that your LP gas supply tank is empty or there has been a utility interruption of natural gas. Try refilling or replacing the tank.
    If you are still having trouble with your dryer, I suggest giving it a hard reset, by either unplugging it or shutting the power off at your homes circuit breaker for 3-5 minutes. When power is restored, start any cycle. If you are still noticing that there is no heat and it stops 5-7 minutes into the cycle, I suggest contacting your local authorized technician. Hope this is helpful.
    -Best Regards-
    WP
May 14, 2014 | Frigidaire FAQE7001LW Dryer
Dryer will not stop running
If the start switch is stuck or the start knob is stuck in the start position the dryer will run when the door is closed, and the timer is at at a time setting. if you have no heat you might need a heating element or your unit might have a thermal fuse that would need replacing.
Jan 18, 2014 | Frigidaire FEQ1442ES Electric Dryer
Your machine may have a feature called wrinkle guard or wrinkle shield, which basically keeps tumbling the clothes without heat to prevent wrinkles from setting in. Turn that feature off and see if that does the trick.
May 15, 2010 | Frigidaire Electric Dryer
My Frigidaire model GLEQ2152ES0 will run but the air does not get hot.
Need to order the resistant heater, use the mothel of the unit to make the orther
Aug 11, 2009 | Frigidaire Electric Dryer
Dryer got very hot when shut off,wouldn't heat up when running.
We took apart the dryer. the heating coil was broken in two. When the dryer was stopped it was not in off mode therefore the electricity was going through and the ends off the coil where it was broken was touching the metal and eating the dryer which made it hot to touch. We tested the 3 different fuses? the ohms were good. Ordered the part waiting to put it back together to be sure. Rule to remember even when dryer is stopped it should always be put in off mode.
Jun 02, 2009 | Frigidaire FSE748GF Dryer
Stops after 20-30 seconds but only when using heat. Can immediately restart.
rbf, in looking Im not finding a 649732, but I do find a 649723. This dryer has a even heat board but also a thermistor. If you had to hold the start button for it to run, I would suspect the even heat board. That's not the case so Im suspecting a open or shorted thermistor. If you remove the lower panel it sits right behind the blower housing next to the thermal fuse. Should be black in color. Part number 3976615. The thermistor should ohm out at about 10k ohms plus or minus 3. When one of these thermistors fails usually you get the symtom your describing. Catriver.
Jun 23, 2007 | Kenmore 64952 Electric Dryer
Frigidaire  Electric Dryer Logo
106 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
