Question about Hayward Pool & Spa
HEATER WILL START AND AFETER A FEW MINUTES WILL STOP HAETING
    Champion:
  • 246 Answers
DO YOU HAVE A CODE? CHECK IF ALL THE BURNESR ARE ON IF NOT MUST BE CLEAN.ALSO THE PRESSURE AT THE FILTER IS BETWEEN 10-18 PSI IF NOT CLEAN THE FILTER
Posted on Sep 14, 2009
Intermittent heater blower and motor slugging and missing at certain speeds
it does it every so often not all the time it just dies while driving. then starts after a few minutes .but one time I sprayed starting fluid in throttle body and I got fire . but after fluid ran out it would die again . but would start a few minutes later.
Feb 27, 2014 | 1987 Isuzu Trooper
Hot water thermostats only lasting 15 minutes.My old Beasley solar hot water system is causing thermostats to stop working within 15 minutes of them being installed. I have had four new thermostats
try using the services of an electrician when fitting electrical components
the thermostats only stop/ start electrical power to the elements and will not control the temp of solar systems
if they physically burn the points , there must be an electrical short of some sort so an electrician in to test circuitry is in order
Jun 24, 2017 | Water Heaters
My civic heater star blowing hot but in a few min. stop working , what could be wrong
Check the water/anti-freeze level in the engine coolant system. If the engine coolant is full then you may have a problem with the thermadoors or controls.
Dec 24, 2012 | Heating & Cooling
Anti-thief system cut off power to den gine an won't cut it back on
If you are dealing with the anti theft the anti theft will flash as you are trying to start the vehicle if this is the case then it is the anti theft if not then you are not dealing with a ant theft issue. You can do a 30 minute relearn procedure without a scan tool. here is how Turn ignition on without the engine reunning.attempt to start the vehicle then release the key to ON.(vehicle doest start) Observe the security light.afeter 10 minutes the security light will turn off.Turn off the ignition and wait 5 seconds.do this 3 times for 30 minutes. start the engine with the engine started the vehicle will learn the passlock key.
Feb 24, 2012 | Cars & Trucks
My 2002 camry dont stay idling afeter i changed the battery. what it colud be?
Try to rev the engine a little bit by feeding more gas to it through the acclerator pedal and see if it can relearn.
It might take a few minutes before it finds optimal settings.
Is there a service engine soon light associated with this malfunction? If so, then what is the
Feb 08, 2011 | 2003 Toyota Camry
I have a 1988 mk 2 golf when i start the engine the heater warms up as normal but when the engine warms up the heater starts blowing cold air out. also now that the cold weather has started after driving...
sounds like the thermostat stickng as when engine gets cold the choke will start workin again, causing the over reving or your electric fan is on all the time "over cooling" the engine
Dec 22, 2009 | 1988 Volkswagen Golf
Pilot goes out afeter a few minutes
I bet you have a dirty pilot assmbley which caused the thermocouple to go bad. Remove the assembley clean it well (including the small oriface inside the assembley). then install a new thermocouple (probably 12-15 dollars) this should solve your problem.
Mar 25, 2009 | Dyna-Glo Double Tag-a-long Heater
PA blows cold air everytime I restart the car
The cooling thermostat may be failing since this customarily diverts hot water to the heater core first to give a faster response. That isn't an expensive or difficult job to replace it so I would start there. If the system is going to be opened anyhow, I suggest you flush the system first. That may even solve the problem.
Coolant will be lost in the replacement so catch as much as you can to avoid having someone's pet lap up the stuff and die.
Feb 14, 2009 | 1995 Buick Park Avenue
Heater will not stay running
bigrench1843@aol.com. I just fix this same problem 15 min. ago after 2 days of headbanging
915 EST. lets talk
Jan 28, 2009 | Reddy R155D Utility Heater
Pool & Spa Logo
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
