Question about Frigidaire Dishwashers
Does not let water come through n I can hear the pump running .It is a frigidaire dw3200p*1
  • pmillard126 Sep 05, 2009
    Thanks ..this was vary helpfull..Thanks again..lets start a appliance repair shop..lol I will try what you have suggested.
  • 6,784 Answers
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Posted on Sep 04, 2009
Testimonial: "Shut off valve is open , fLoat switch isnt stuck or hung , Should I shut off water and remove fill valve where water come into and check if it may be "
  • Michael Masters
    Michael Masters Sep 05, 2009
    Yes, This defective vale should be tested for its operational value. use the procedure below to help guide you through the proper testing.
    To access the inlet valve remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to reach the screws over the panel, then close the door to remove the panel. The water inlet valve can be identified by the water hoses connected to it. One hose will lead from the valve to the pump/motor assembly in the center of the dishwasher. Check that the hoses are securely connected to the valve and that there are no kinks in the hoses which could restrict water flow. There are two wires (four, if it has two solenoids) connected to the water inlet valve. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced. Use a continuity tester or multimeter to test for continuity. Set the multimeter to the ohms setting X1. Touch one probe to each terminal. A reading of infinity indicates a bad solenoid that must be replaced. Different brands and models will have various measurements, but the valve should show some resistance if it is functioning properly. If your valve has two solenoids, test the second one in the same way as the first. If the solenoid is working properly, but water leaks through the valve even when the dishwasher is off, then the valve itself is the problem. Debris may be preventing the valve from closing. If the valve cannot be cleaned, it will have to be replaced. The valve can also fail mechanically. So even if it passes the electrical test, it may still require replacement. If you have ruled out all other possibilities, go ahead and replace the valve.
  • Michael Masters
    Michael Masters Sep 09, 2009
    That shop sounds like a great idea:-),
Washer will not spin out
There is most likely a clog in the pump filter. Check the hose between the tub and drain pump. If that isn't it check the door switch.
Cleaning the pump procedure is here:
http://www.youtube.com/watch?v=b3kL3daLZ9g
Door switch procedure is here:
http://www.youtube.com/watch?v=FGo3xEABxm0
Jan 23, 2013 | Frigidaire Washing Machines
Water runs during final spin cycle
You have a blockage in the drain pump. Remove the front panel to access the drain pump.
Bail the water from the tub.
Remove the hoses on the pump and clean out the lint or garment from the pump.
Mar 26, 2009 | Frigidaire Washing Machines
Frigidaire Affinity Atf7000e...Does not load up water.
clean your inlet screen...onthejob...take hose off and take screens out of inlet water vavle and clean then replace..onthejob
Jan 20, 2009 | Frigidaire Affinity ATF7000E Front Load...
Dishwasher not pumping the water out?
hi
the larger motor housing underneath the unit is what moves the water around to wash, the smaller pump is the drain pump, if you don't hear that running it is likely in need of replacement. check your paper work for warranty, if it's out of warranty try to find a deal online and it's relatively easy to replace
Mar 20, 2008 | Frigidaire 24 in. FDB750RCC Stainless...
Frigidaire FDB740RCS0 Upper Armnot Turning
the motor stops and runs in the opposite direction to pump water up to the top rack. you first need to listen for the motor to stop and start. if you hear that open the door and try to tell if water was coming out of the top spray arm.
Nov 01, 2007 | Frigidaire 24 in. FDB1050RE Built-in...
Water Dispenser
GodofHops: The motor that you hear on the refrigerator is the water pump that carries the water to your dispenser. If no water is coming from the dispenser. You have to check 3 things: 1. If there's any water. 2. Water filter clogged. 3. Water line for dispenser clogged with minerales carried on water flow. SithPitt
Jul 04, 2007 | Frigidaire FSC23F7DSB Stainless Steel Side...
Frigidaire dishwasher
CHECK WATER INLET SOLENOID OR TIMER
Jan 26, 2007 | Frigidaire 24 in. PLD2850 Built-in...
Dishwashers Logo
117 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
