Question about Maytag SAV2555A Top Load Washer
Maytag SAV2555AWW will not agitate. Checked breaker and that is not the problem. Can I fix this myself?
  • 6,784 Answers
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction. Another issue that might cause this disruption is the Motor coupler.
Washers with a direct drive motor have a motor coupler instead of a belt. The motor coupler consists of three plastic disks (or tri-stars) with interlocking tabs. Those tabs can wear and break which results in slippage. The slippage causes little or no power to be transferred to the transmission. A worn motor coupling can result in weak or no movement of the agitator and spin basket. Inspecting the motor couplers requires removing the motor, which is fairly easy to do.
Remove the cabinet. Locate the motor. The pump is mounted to one side of the motor. You do not have to remove the hoses from the pump unless they prevent you from moving the pump out of your way. If you must remove the hoses, label where they connect first. To disconnect the hoses, pinch the wire clamps with pliers (or loosen the screw) and slide the clamp farther up the hose. Slide the hose off of the pump port.
There are two clips that secure the pump housing to the motor. Use a screwdriver to pry up the clips and remove the cover. Next, slide off the pump to reveal the motor. Disconnect the wiring harness from the motor, do not pull on the wires themselves. The motor typically is secured with retaining clips and bolts. Remove the bolts and use a screwdriver to pry up the clips (if present). Remove the motor.
Mounted on the shaft of the back of the motor you will find the motor coupler. Separate the three disks and inspect them for damage. If you find cracks or excessive wear, replace the coupler.
**(((If the motor couple is in good condition, replace the agitator components and clutch assembly as well.)))
Posted on Sep 04, 2009
I am trying to replace the belt on the washer but i have to take the water pump off first
Posted on Dec 07, 2009
Maytag washer mav8601aww
Check out the belt for stretching.
Aug 25, 2017 | Washing Machines
Washer wont agitate, pops breaker
Could be the gears/transmission for the agitate cycle are jammed, the motor then freezers, creates an overload and the breaker pops.
Jan 27, 2014 | Maytag Ensignia MAV4758AWW Top Load Washer
My maytag top load washer model #sav2555aww spins but not fast... I replaced the belt and that helped but still not like it did before.. Everything else works fine, any suggestions?
some of these machines have a timer conflict between rinse [ spin pulse ] and full spin at end of wash cycle the timer contacts remain in the pulse cycle the switching assembley may need replacing
Mar 05, 2011 | Maytag SAV2555A Top Load Washer
Breaker on motor keeps popping off ///cools down,powers up=but blows out again====replaced motor and checked water pump if clogged ok.
You need to try turning the parts by hand that the motor is supposed to be turning. The breaker is popping because of a mechanical overload--probably within the transmission itself. Check drum rotation as well as the agitator for high resistance. Good luck!
Sep 21, 2010 | Maytag Atlantis MAV6000 Top Load Washer
My Maytag Ensignia washer is not spinning well. It bangs side to side with even the smallest loads. It seems like something is loose. Is this something I can fix myself or do I need a repair mans help....
Try leveling the washer... If the washer is level, then don't wrap the clothes around the agitator...drop the clothes straight in, on top of each other evenly around the agitator. The Ensignia washer has a Dual action agitator... That means the clothes roll over them selves, instead of moving side to side, as with a traditional agitator. wrapping the clothes around the agitator will cause the load to be un balanced and then cause the "banging" noise... this should take care of the problem...
Jul 31, 2009 | Maytag Ensignia MAV4758AWW Top Load Washer
Agitator on maytag sav2555aww won't spin, loud clicking noise
I just replaced the trans in my maytag.if the washer is less than 5 years old trans is covered under warranty. but here is the kicker, labor and thrush bearing is not. trans cost is about 300.00 and labor is about the same. a new washer is about 450.00 So if you know someone who can do trans.[like for free] if not buy a new one. Good Luck
May 21, 2009 | Maytag SAV2655A Top Load Washer
Will not agitate
Bad pump Pump bearing locked up something up in pump brazzierre underwire shoulder suppet thing IN pump. Check pump
Feb 13, 2009 | Kenmore 63942 Dryer
Washing machine won't agitate.
Depending on type of washer, typical top load Maytag, motor turns in opposite direction for wash and spin. Your problem will no doubt be the transmission.
Nov 01, 2008 | Washing Machines
Maytag PAV2300
when you say its the whole thing, is a shaft coming out out with it or is it a two part agitator? if the shaft is coming out its time for a new transmission. if its a two part agitator, replace it
Aug 26, 2007 | Maytag PAV2300 Top Load Washer
Maytag SAV2555A Top Load Washer Logo
472 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
