Question about Dahlquist ORBIT 5.1A System
My subwoofer blow fuse the otherday and when i replaced it with a new fuse that one also blew
  • 53 Answers
Chase down your power wire. sounds like a short in that wire
Posted on Sep 05, 2009
New subwoofer blows fuses
you have some wires touching causing it to ground.check wiring
Dec 27, 2012 | Gemini Sound Products Gemini GVX SUB15P...
Why does only one speaker channel play? Did i blow a fuse if the speaker wires touched?? Where are they located?
If its the stereo = Blew a channel, Get a new one.
If its the Amp = open it up , there should be 2/4 little white fuses,,
find the one with a light Brown/Black burn mark, remove and replace bad fuse.
If amp is all Digital Buy a new one..
Your Welcome
HotRod42069
Jul 16, 2011 | Car Audio & Video
A few days ago the subwoofer stopped working. Yesterday I turned the system on and it wouldn't work at all. I discovered the fuse had blown. I replaced the fuse, couldn't find a slow blow fuse so had to...
Try removing the wires to the subwoofer and then hook a "aa" battery to it and see if it makes a pop sound..this will tell you if speker is ok...if it is then I think the amplifier sectionj for the sub is what is blowing the fuses...you are probably right..it looks like it's a 1 A fuse...but if it's blowing right away..it may be circuitry related
Jan 04, 2011 | Altec Lansing VS3251 Speaker
Unit blew the internal fuse. SONY SA-WMS367 SUB-WOOFER
Bad output IC or voltage rectifier are the most likely at fault.
Nov 28, 2009 | Sony SA-WX700 Subwoofer
Fuse blows
Both 3 or 4 amp slow blow fuses are suitable replacements for the 3.125 amp subwoofer fuse.
It could be that the subwoofer is blowing the fuse because the one you installed was not slow blow.
But, more likely is the subwoofer has a short in the power supply which is causing the fuse to blow.
May 31, 2009 | JBL PB10 Subwoofer
Klh powered subwoofer keeps blowing fuses?
then the circuits took a hit and the fuse didn't do it's job in the 1st place. best is too get new circuit thats inside the sub woofer.
sorry to be the bearer of bad news
Apr 26, 2009 | KLH BB-II Subwoofer
Fuse on subwoofer keeps blowing
Subwoofers draw a tremendous amount of power. With the amount of heat generated by amperage flow and the movement of the voice coil, you may have burned out the coil. Do a resistance check across the coil. Easy check? Temporarily attach another speaker to replace that one. Use LOW VOLUME and slowly work the vol up,and, if the fuse does not blow, it's the other speaker.
Mar 10, 2009 | Dahlquist ORBIT 5.1A System
Car audio
Does it blow the fuse if you disconnect the RCA cables and disconnect the speaker wires from the speaker terminals of the amp?
Does it only blow the fuse after the head unit is switched on (only after remote voltage is applied to the amp)?
Apr 28, 2008 | Car Audio & Video
Subwoofer eating fuses.
Check the circiut board for any blown capacitors. Sometimes it's that simple as replacing a capacitor. But then again, what is causing the capacitor to blow??/ Hope this helps.
Nov 02, 2007 | Audio Players & Recorders
Dahlquist ORBIT 5.1A System Logo
177 people viewed this question
Top Dahlquist Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Dahlquist Audio Player and Recorder Expert? Answer questions, earn points and help others
