Question about RCA Scenium D40W20 40" Rear Projection HDTV
Unusable signal The TV will come on and you can go to the menu and see difference set-ups on the screen, but when you hit guide, exit, or menu, the screen goes to blue and has the message unusable signal. We hooked up another TV to the cable and it works fine, so it is not the cable.
  • Thomas
    Thomas Oct 20, 2017
    St. Anne Academic Centre has investigated the striking similarity of students engagement in the US in TV signals society. Around 28% of students create their own films even during the first year of studying. Do you think I can typemyessay or better write a script? Surely, the last one.
  • 979 Answers
Could be a bad buffer/amp or bad tuner, depending on source selected....accordianman
Posted on Jun 25, 2008
It is stuck on video mode and there is a message on the screen stating unusable signal. How do I return it to TV?
Hello
Highlight Exit and press MENU
Press 0 on the remote
Press CLEAR. The on-screen displays are cleared from the screen and you
return to TV viewing
Ok
Jun 25, 2011 | RCA F25441 25" TV
Black and white tv
Hello
Your RCA, system setup has changed I thinks.To change this you have to go to the Menu option surf for system settings, and change the system reception to "AUTO".
Setup
The Setup menu allows you to access the GUIDE Plus+ system setup information. To access the
Setup option:
1. If the GUIDE Plus+ system isn't on your screen, press GUIDE on your remote control.
2. Press MENU to select the Menu Bar.
3. Use the right arrow to highlight the Setup menu selection.
4. Use the up and down arrows to select Change system settings, Review options, or
View demo.
Change system settings Confirms the settings you completed in the GUIDE Plus+
system setup are correct.
Review options Displays the GUIDE Plus+ system auto display options.
On Automatically displays the GUIDE Plus+ system when you press the ON•OFF
button on the remote control.
Off Disables the GUIDE Plus+ system from being displayed when you press the
ON•OFF button on the remote control.
View demo Runs the GUIDE Plus+ system demonstration
Note: If you have not completed your GUIDE Plus+ system setup, these options will not be available. A
screen will prompt you to complete your setup.
Getting In & Out of the GUIDE Plus+ System
To enter the GUIDE Plus+ system:
• Press GUIDE on the remote.
• Press and hold MENU for 2 seconds on the front panel.
To exit the GUIDE Plus+ system:
• Highlight a program and press OK to exit the GUIDE Plus+ system and tune
to the channel.
• Press GUIDE to exit the GUIDE Plus+ system and tune to the channel
displayed in the video window.
• Press CLEAR to exit the GUIDE Plus+ system and return to the original
channel
OK.
Dec 04, 2010 | RCA 32V420T 32" TV
Stuck on menu screen
Try connecting the TV directly to a different wall outlet and check. Try resetting the TV to the factory settings. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 26, 2010 | Philips 42PF9431D/37 TV
How do I reset a Viewsonic N2759w to Factory default settings
On most Viewsonic TVs, hit menu (on the TV or your remote) go to Options (or Setup). The icon will look like a hammer with a double ended wrench across it (at least on my TV - a different model). Hit the down arrow and select Restore Default or Memory Recall. Select Yes and Enter when you see the prompt. Then exit the menu system (by hitting menu). The action is saved when you exit.
I hope this helps.
(the two different commands results from a change in Viewsonic's menu system - my print manual differs from the current on-line manual at Viewsonic's site. I'm not sure which set of commands will apply. If your TV menus are different, the names should still be similar.)
Jun 04, 2010 | ViewSonic N2750w 27 in. HD-Ready LCD...
My Phillips Plasma tv MENU pops up unasked and obscures screen.
there is a soft ware upgrade for that problem on there web site you can down load it to a thumb drive and upgrade your set
Oct 31, 2009 | Philips 32PF7320A 32 in. LCD Television
RCS Scenium
What is your TV input connection? Are you using Antenna? Cable? Dish?
The Unusable Signal sounds like the TV is not getting a signal. Does your TV have a built in HD Tuner?
If you are using Antenna you might want to try setting up the connections and it should search for quality channels that you get good signal strength. If you are on channel 2 and there is no over the air channel 2 it may say "unusable signal".
Sep 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Unusable Signal for PS2
If you want to use a PS2 with an RCA stereo monitor Colortrak plus television, folllow these steps:
1.Buy a universal remote compatible with RCA televisions if you don't have the original.
2.If your remote needs programming, program it with the manual provided.
3.Goto Menu
4.Goto Alarm
5.Goto Alarm Channel
6.Set Alarm Channel to 00
7.Exit Menu
8.Goto channel 00 on the television by using the remote.
9.You should be in AV mode, and able to play your PS2.
P.S. I don't know if you need to set Alarm Channel to 00, but that's how i did it.
May 13, 2008 | Televison & Video
Help me remove the Guide Plus Grid on my RCA television
Simply enter 00000 for the zip code and complete the set up process; if you're in Canada, select the USA as your country and use the zip. However, you MUST complete the set up, including allowing the TV to search for appropriate code. In the long scheme of things, location and codes don't really matter because you won't see the GUIDE again.
Mar 08, 2008 | Televison & Video
Poweroutage t.v. won't work now
It sounds like the TV set went to default settings. You should go into the menu again with the original remote and go thru the channel setup or guide plus if you have one. Good Luck PS Please dont forget to rate this thread.
Oct 23, 2006 | Proscan PS50700 50" Rear Projection...
RCA Scenium D40W20 40" Rear Projection HDTV Logo
303 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
