Question about Schiller Medical
Schiller AT 2 plus does not recognize the leads. What should we do?
  • 1 more comment
  • martinhernan Sep 04, 2009
    Is there a way to find out if the lead wires are at fault vs the internal circuits?
  • martinhernan Sep 05, 2009
    It has a battery that I do not know how to disconnect. Do you?
    Shiller AT 2 plus has an internal battery so I cannot turn the machine off. How can I turn off the internal battery?
  • 2,005 Answers
If this is the model i'm used to: remove power then: remove all leads then repower go into menu and, reset then: using one found good lead plug it into the machine jack assuring that each jack recognizes the good lead
then now knowing your lead jacks are recognized check and, verify each additional lead. if any of the reset procedures fail have the machine serviced
Posted on Sep 05, 2009
    Brigadier General:
  • 5,158 Answers
Basically if you unplug it for a couple minutes and plug it back in that should reset the computer
  • Roberta Smith
    Roberta Smith Sep 05, 2009
    unfortunately no. basically that is a computer so removing power sources will cause it to "reboot" and that often sorts it out. if you suspect the leads or want to test them that would require a multimeter. test for continuity on each lead.
  • 3,741 Answers
Internal circuit of the unit needs to be checked if there is a short inside the machine will not detect the leads.also check out the leads in another machine to confirm the faulty part. thanks.please keep updated.please do rate the solution if helped.thank you for using fixya.
Posted on Sep 04, 2009
2 Suggested Answers
  • 16 Answers
SOURCE: the schiller at 2 plus ecg machine not printing ecg
Does it work in auto mode ? are you putting paper correctly means , there is a black mark on paper which is sensed by paper sensor .If you put paper up side down then paper sensor won't be able to sense any paper & gives you error for rifilling paper .If this doesn't help you then You need to replace battrey . Thanks
Posted on Jul 22, 2009
Schiller at-1 says lead off
Check the leads. If any of the Leads is open the this problem can occur. You have to check the continuity of each cable for the lead end to socket. All leads should show a resistance of 10KOhm
If you wish to get some details About schiller AT1; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 28, 2013 | Schiller Cardiovit At 1 Ecg Machine
Do u have a picture on how to put leads on a pt for a Schiller AT-2
HI,
Watch the following picture and video to know about the 12 lead ECG placement.
OK
Sep 12, 2011 | Schiller Welch Allyn Cardiovit At 2...
Do you have a poster for correct lead placement for AT-2 plus ECG? thanks!
hi,
If you need to know how to place the leads then whach the following video. All 12 channel ecg machines have the same lead placement
Jun 23, 2011 | Schiller Welch Allyn Cardiovit At 2...
Schiller AT-Plus, I cannot get all leads to print in sequence I avr v1 v4 II avl v2 v5 III avf v3 v6 not sure what a student did to change the...
The unit is apparently printing out in Cabarra sequence. To restore the correct lead sequence, do the following: Hit the ALT key followed by 7 then 1, hen the stop key. This will restore standard lead sequencing.
That is the start of the battle. If you desire a 3+1ryth format with a lead 2 at the bottom, which is our standard format, then you have more to do. For this format hit the ALT key followed by 1 then 0 followed by the stop key.to set the ryth lead to lead II at the bottom of the page, hit ALT followed by 3 then 8 then 2 followed by the stop key. If your filters are not enabled hit Alt 5 6 stop, alt 5 8 stop, Alt 8 3 stop, ALT 8 1 stop.Do a test print after all of this and be certain the unit is configured to your taste prior to a live patient.
Jun 14, 2011 | Schiller Welch Allyn Cardiovit At 2...
My AT-2 plus EKG suddenly stopped transmitting from the electrodes, i.e. all the leads show flat line. My e-mail is alaronov@mac.com
hi,
You have to check the patient cable of you machine first. you have to check the LF (left foot ) lead of the cable. if there is any other cable you can try it with that. if there is any other ecg machine you have which has the same connector. then try with that also. if the cable found faulty then replace it. Is there is any trace ( line trace ) in the paper for lead 1 to v 6 if not , the problem is with thermal printer of you machine. if so you have to contact the nearest schiller authorized service center. Because the thermal printer head is not available in the open market.
ok
Mar 31, 2011 | Schiller Welch Allyn Cardiovit At 2...
I have Schiller AT-2 Plus, i need instruction
press Alt then 9 - 1 - 1 for the time.
press Alt then 9 - 2 - 2 for the date
May 09, 2010 | Schiller Welch Allyn Cardiovit At 2...
I have Schiller AT-2 Plus, i need instruction manual,or guide me how to chnage date and time,hospital name.
i want to configure my Schiller at-2 plus ecg machine from dutch to english and 3channel to 6channel
Mar 17, 2010 | Schiller Welch Allyn Cardiovit At 2...
The schiller at 2 plus ecg machine not printing ecg
Jul 15, 2009 | Schiller Welch Allyn Cardiovit At 2...
Printing 3 leads only not 12
Hello medico001, The info on the Schiller web site states an option of 12 lead for model Cardivot AT. If your unit has this option only the automatic selection will deliver the 12 lead print. For futher info select the web site http://www.schilleramerica.com and click on 'Contact Us'. This should direct you to someone local. Good luck.
Oct 24, 2008 | Schiller Cardiovit At 2 Light Ecg Machine
Medical Logo
60 people viewed this question
Top Schiller Medical Experts
Jim Goldsmith
Jim Goldsmith
Andrew Taylor
Andrew Taylor
Are you a Schiller Medical Expert? Answer questions, earn points and help others
