Question about Vacuums
Motor makes loud growling noise, no suction on model 270 i Miele canister style vacuum
    Novelist:
  • 171 Answers
Hi there SmartAlec from NelsonVacuums.com.au here. Unfortunately that normally means the motor has shot its bearings and/or its carbon brushes. I think it is time to purchase a new one. On the bright side there are some rreally great vacuums out there! If you want any help choosing a new machine send me a message. Happy Vacuuming :)
Posted on Sep 05, 2009
  • 1 more comment
  • Van Douglas
    Van Douglas Mar 31, 2014
    how can i look insis it
  • Van Douglas
  • Van Douglas
    how can i get inside it to look at the issue?
  • 430 Answers
Growling sound on a canister is normally caused by a suction fan wobbling loose due to damage or a bad bearing. Loss of suction would occur if the fan is loose or damaged. If the bearing is bad but the fan intact you will still lose suction as the motor will not run properly out of balance. Take it to a Miele service center for parts
Posted on Sep 07, 2009
  • Van Douglas
    how can i take it apart to look inside it
  • Van Douglas
Power is on but no suction....
I recommend taking your vacuum to a qualified repair person for diagnosis and/ or repairs. Electronic repairs can be fairly reasonable to fix but much more expensive and dangerous if not done properly
Apr 21, 2014 | Miele S548 Bagged Canister Vacuum
Loud noise ,hot air and poor suction in Miele vacuum cleaner
Hello, this is Ava with Think Crucial.
To make your Miele work properly, a general maintenance will do the trick. Most of the time cleaning the filters, checking for blockages and clearing the passageways will eliminate the noise. Please refer to your User's Manual on how you can do this.
You can purchase a wide variety of high quality Miele replacement parts for your Miele Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=miele
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jan 11, 2013 | Miele Vacuums
My Kenmore bagless intelliclean vacuum is making a loud noise mainly when it is vacuuming on the highest setting (when the light is red). We have taken it apart and cannot find a clog. It has also lost...
This might help, it was posted on a previous problem but is the same issue you are having it seems: "Here is a possible solution. If the vacuum sounds normal when the green light comes on, then the issue is a suction bypass. Kenmore built a suction bypass in to help cool down and protect the motor should someone either never clean the filter, empty the canister or somehow manage to clog the hose. There is a spring holding the bypass closed and is overridden by vacuum suction. I guess the spring becomes weak, allowing high suction to pull it open which in turn reduces suction so it closes again. It can do this several times per second making a loud racket and slightly affecting performance until the sensor goes green, then the vacuum suction is too low to overcome the spring tension thus why it sounds fine then. The trick? The very hard way (what I did) was to open the vacuum, open the casing where the spring is and pull it apart slightly to increase the spring tension. The easy way is to put tape over the hole where the bypass is. The inlet is under the hose track on the back on the right side as you're looking at it. The hole is about the size of a quarter and you'll see fins across the hole. The tape would keep the suction. The motor would still pull back the bypass but since tape is applied, there would be nothing to reduce the suction thus keeping performance and reducing the noise. However, this circumvents the intended design so you do so only at your own risk."
Dec 27, 2010 | Kenmore Progressive Bagless Upright with...
Miele canister keeps shutting off when i press + it starts again for short while and off again whats problem i have changed bar but still no good
Was it hot when you pressed "+" button? Did you check the filters(Hepa) or bag if clogged or suction path was blocked? Does it happen after it was cool down? From what you said, it seems none of the above. Only thing I can think of is circuit board. The mortor runs in variable speed. "+" increase the average voltage to the motor thus higher suction. PWM circuit in main pcb may not working correctly.
High priced vacuum cleaner like this shouldn't fail like this but it does. JMO.
Nov 07, 2010 | Miele S548 Bagged Canister Vacuum
My Miele Red Star suddenly has very weak suction
Either motor is clogged with dust or suction hose is clogged, replace bad also.
Apr 16, 2010 | Miele Red Star Bagged Canister Vacuum
My Miele capricorn has started making an odd noise. It seems like something is blocking the engine. I've turned if off and on, and reset it and it still have the odd, almost loud barking noise. The power...
Greetings,
This is a major problem. The Miele vacuums motor should never make a loud noise, period. The way the motor is designed, it's quiet and should be quiet for the life of the motor. There are two motors on your Miele canister. One of the motors controls only the suction of the vacuum, while the other motor controls the power brush. Which one of your motors is making this horrible noise? You can tell this by removing the wands and power brush so that you just have the handle of the hose by itself. Now turn on the vacuum, do you still hear this noise? If yes, then this is a problem with your suction motor, and you need to bring this in to have an authorized Miele repair center take a look at it. The reason I say that is because you have a 7 year warranty on that suction motor, so if something is wrong with that motor, then this will be covered under Miele warranty. If it's the power brush motor that's causing the sound, this probably will not be covered unless the vacuum is under 1 year old. If it is the power brush, please just use the clarificaiton request here on Fixya and let me know, I'd be more then happy to try and walk you through diagnosing the power brush motor with you.
I hope this was helpful to you. If you did find this helpful, please be sure to click the thumbs up icon in the repair. I really appreciate it.
Chris J.
Mar 21, 2010 | Vacuums
My almost new miele Dog and Cat vac keeps telling me the bag is full when it's not (new bag, no clogs)and I have almost no suction. Any ideas?
Remove the hose and check the suction. It it is still bad check to see if the canister is closing on the bag. Most likely the hepa filter needs replaced. Here http://www.totalvac.com/mielevacuumcleanerfilters.htm
Aug 12, 2009 | Miele S514 Solaris Bagged Canister Vacuum
Loss of suction, loud blowing noise
Hi.
Try cleaning out the vortex this will sort out poor suction.
http://dysonmanuals.llc.nu/
Oct 16, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Miele vacuum cleaner hepa tt2000 blue
Is there a valve on the handle, near the tube or right on top by the switch that you can move to allow for less suction?
Jun 15, 2008 | Miele Blue Moon Bagged Canister Vacuum
Vacuums Logo
468 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
