I have a mitsubishi vs-50605 in rear projection tv.i wand to know how to get to the bulbs to clean them? i also want to know how to change the blue convergence?
  • 3,459 Answers
You have to remove the front screen or back panel. Every set is different.
convergence is in the menu - if you have the original remote.
Posted on Sep 06, 2009
Mitsubishi VS-5041
your set is not a DLP its a traditional rear projection tv set and has three picture tubes
there is not a bulb or color wheel in this model
if its dead ? you would need to check the power supply first to see if you have the proper voltages . the trouble shoot the rest of the circuits to see what is shutting it down . convergence circuit failure is always a good suspect in these sets
May 22, 2014 | Mitsubishi VS-50605 50" Rear Projection...
My mitsubichi projection tv model vs-50605 is getting dark, Do i need to change the bulb
This model does not use a "bulb", it has three picture tubes.
What does happen is the lens for each can get dusty; picture will gradually get dimmer and dull looking.
With set unplugged, remove rear cover (it can be done from front but back is safer for a do it yourself person..
With the rear cover removed look for the 3 large black lens pointing up in the middle of the set--simply clean them with a lens cloth or a paper towel with glass cleaner sprayed on it---this should usually be done once a year.
If they have not been cleaned recently or you are in a dusty environment, cleaning them should improve the picture a lot.
Let me know if you have questions.
SD TECH
Jun 01, 2011 | Mitsubishi VS-50605 50" Rear Projection...
Where is the pip board located on a Mitsubishi vs-50605?? need to know so i can replace caps please!
what is the problem with your set? I can only find a small stand up board on the signal pcboard that has anything to do with pip. I can't find anything on the mitsubishi web site that says anything about changing any caps on a pip board.
Aug 18, 2009 | Mitsubishi VS-50605 50" Rear Projection...
No picture . tvturns, immediately turns off
Your TV set is in protect mode .To protect further damage of some component parts.There is something internal problem inside maybe there is a shorted.
Good luck;
Regards:
VOTIT
Jul 01, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi 50605 Convergence Board - Replacement?
Replacing the whole board will fix it, but is a bit of overkill. If you can solder and feel comfortable working inside the set, you can fix this yourself. Let me know if you wish to attempt the repair and I'll proviode additional details and instructions.
Dan
Oct 13, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Screen is blue
the problem will either fix itself out or the screen will go. chances are one color goes then the next and then its toast but can go after blue as well.
Aug 06, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Blue Screen
no those tvs came with a black otuer screen that have rough ridges . If your screen is blue, someone may have replaced it with a dark colored plastic. You can get replacement screens at the following link, They are exspensive though.
http://servicemanuals.vstore.ca/
Jul 12, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi big screen tv
Do the self test first find the error code. Look on here or ctechnicians.com
Jan 02, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-50605 - Colors separated
You have a convergence problem and need to reset
Nov 26, 2007 | Mitsubishi VS-50605 50" Rear Projection...
How to take off protection screen of a Mitsubishi VS-50605 50 in. Rear Projection
Usually have to pull the speaker grill off (friction fit), there will be some screws under the bottom edge of the screen, if there are wires you may have to unhook them, sometimes the plugs are behind a pannel that gets unscrewed from the front. The frame will come apart to drop the new screens in.
Jul 14, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Televison & Video Logo
137 people viewed this question
Top Televison & Video Experts
Electro Med Services...
