Question about LG Televison & Video
Hi there i bought a LG re-40nz60rb its iether 40'' or 42'' wide screen a few years ago i didnt know that it was HD ready but when i plugged my xbox 360 in i realised it was however it will only select 480p? is this the highest that it will go i dont know if this is good or not? i have seen people saying that they're tv is 1080i/480p is that whet mine is or do i have to upgrade my t.v. as i'm about to get a PS3 and want to watch blueray dvd's will my t.v support this? as people have said they operate on 720 output?
sandrew
  • 2961 Answers
SOURCE: HD resolutions
Your TV would have to be HD ready and will automatically set itself to 1080i, but if you go into the XBOX 360 console settings' the top menu enables you to change resolution, but if the x box does not recognise 1080i it will not show up. See if 720i shows up as this is still High Def. and also that 60 Hertz is the setting and not 50 hertz
Posted on Dec 30, 2006
sandrew
  • 2961 Answers
SOURCE: No HD 1080i
have you got the slider switch at high definition and not TV at the connecting end at the xbox that leads to the tv input
Posted on May 21, 2007
SOURCE: Mitsubishi WT-46809 Problem getting HD from DirecTV
I have found some info on this, please read: "For standard (480i) connections, there are three S-Video/ composite-video/ R/L audio sets. You would use these for any of your standard video connections such as a VHS VCR. There are two component-video (Y-Pb-Pr) connections, each with three RCA jacks, which will accept input at 480i and 480p (such as the output from a progressive-scan DVD player, for example). Each of these two component-input sets has a corresponding R/L audio connection. Finally, there's a single component-video connection with five RCA jacks, handling Y, Pb, Pr, H, and V (the last two are for horizontal and vertical sync signals). This last component-video connection will take input at 480i, 480p, and 1080i. You do not have to use all five connections. If you have a 1080i-output device, such as the analog output from an STB digital high-def broadcast tuner, with only Y-Pb-Pr output, you can connect to just the three Y-Pb-Pr connections on this five-jack component-video connection. As with the other component-video inputs, the Y-Pb-Pr-H-V set has a corresponding R/L audio input jack pair. The Y-Pb-Pr-H-V component-video connection will also accept an analog VGA-connector output. To make such a connection, you will need one of the adapters with a VGA jack on one end, connected to a cable whichs splits into five separate cables, each terminating in the appropriate type of RCA plug (Y-Pb-Pr-H-V)." This might be your solution. It worked on my Mitsubishi WT 46809. I have moved the component cables installed by the Direct TV installer to the second row of component-video connection (labeled 1080i) and finaly my DirectTV HD receiver is recognizing the 1080 signal.
Posted on Jul 11, 2007
TVtechmaniac
  • 140 Answers
SOURCE: Cant get 1080i
This TV came out in 1999 and the HDTV standards wern't established yet. Just make sure you are using the DTV YpRpb inputs and not the DVD YpRpb inputs on the back of the set. Leave the menu setting at 480p and on the :"ASSIGN INPUT" sub menu make sure "DTV" is set to YpRpb. Even then it may not be compatible with a PS3 at 1080i.
Posted on Sep 02, 2007
SOURCE: Interlaced comes in fuzzy & with lines
you need to check if the dvd or games are doing the same thing on different inputs. if they have the same problems you might be looking at the single board or the focus block.
Posted on Dec 14, 2007
I bought a LG 42LB1D LCD tv about 5 years ago.I hardly watch this tv. When i watching dvd few days ago all of a sudden i see only BLACK screen sound is OK and remote control is not consistent sometim
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Dec 11, 2014 | LG 42LB1D 42 in. HD-Ready LCD TV
Red screen LG 32LC2R
Maybe Bad caps in power supply,Crack or splits on top of cap or leaking, Check value of caps in power supply.
Feb 04, 2014 | LG 32LC2R 32 in. HD-Ready LCD Television
I have a Philips flat screen HD ready TV for my xbox. I don't know what type though as my parents have upgraded to an LG and we now have this Philips TV. I have Sky connected to one of the EXT ports and...
Perhaps the Phillips TV isnt compatible with some of the Xbox Settings.
Or mabye when you adjusted your settings it may have affected any graphics.
Apr 07, 2010 | Microsoft Xbox 360 Console
Are all rz-32lz55 hd ready
hi I have the same TV and have been tring for the last year to find someone that know's how to set up the HD. I can get the Picture but no sound for the HD have been told many way to get the sound but does not work. if you find out let us know.
Sep 30, 2009 | LG RZ32LZ55 32 in. HD-Ready LCD Television
How do i tell if my broksonic tv is a digital tv
IT WOULD SAY HD READY ON THE FRONT OF THE SET. YOUR SET IS NOT HD READY. USE CONVERTER BOX FOR HD CHANNELS.
Nov 03, 2008 | Broksonic TV
I have a philips tv and a xbox 360. I cannot get the xbox to work with this tv. The xbox is pluged in to the tv and I know the yellow white red cords work because they work when i use the vcr. It was...
I guess when I moved the xbox i hit the swith for the hd and regular tv. It's on the back of the xbox next to the power cord plug in. I could hear sound but i couldnt see the screen. When I swithched it to TV the picture came on.
Jun 01, 2008 | Philips Televison & Video
Getting a HD Picture on MY LG Plasma
Have you made sure the box is set to send a HDTV signal to your LG? Example 720p, 1080i, or 1080p? You usually have to set the resolution in the v+.
Feb 29, 2008 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
Red Vertical Line and Black Screen, Sound OK
Check this out
http://forum.eserviceinfo.com/viewtopic.php?t=30810
have a nice day
Oct 08, 2007 | LG RU-42PZ61 42 in. HD-Ready Plasma...
Thick multicoloured stripes accross the screen
Some condesator gone bad.. remote control IR eye needs 5V voltage but now it's not there so i think you need to replace bad condesator.
May 30, 2007 | ViewSonic N3000W 30 in. HD-Ready LCD...
Televison & Video Logo
81 people viewed this question
Computer Repairing
Computer Repairing
