Question about Pioneer DEH-P7700MP CD Player
When we put power to wires smoke comes from inside system
  • 53 Answers
The inside is fried. sorry but need to replace
Posted on Sep 05, 2009
2004 chevrolet classic 2.2l won't start, maybe have a short circuit on positive wire,circuit, because make nothing no radio no lights inside and outside I check battery is ok fuses is ok, looks st
If you have positive battery cable that is shorted, fix it. A dead short to ground should smoke it or get very hot. Check ground, also.
Use a test lite, ignition bat fuse 1 and 2, underhood fuse block, Should be hot all the time. Voltage and ground, both, are important.
Jul 29, 2017 | 2004 Chevrolet Malibu
Smoke coming out of front speaker,smelled buring inside vehicle found no burned wires,could it be the antenna motor,seems like it doesnt work anymore antenna doesn't go down.
Hi Ron,
When something smokes, my first question is, 'Has after market equipment been installed?'.
Number two is, 'Are ALL the power lines fused'.
That includes the power antenna signal wire.
It sounds as though you are a natural trouble shooter. Any recent or concurrent events almost always are related. It's is certainly the first place I'd look.
Best regards
Mike
Jan 09, 2011 | 1997 Ford Thunderbird LX
My 2002 lincoln LS is sputtering white smoke out the exhaust and leaking power steering fluid severily. I can't drive more than 5 miles w/o putting more fluid in.
You can not use the vehicle at all
Repair the P/S Leak
It may be fluid burning off the exhaust
pipes
You don't want white smoke coming from inside
the exhaust system, or you got coolant in the
engine cylinders and big problems.
Dec 13, 2010 | 2002 Lincoln LS
It smoked out my house when it was on the drying cycle any ideas?
did you have any plastic in it like a tupperware or anything for a baby?the water sprays so hard that it sometimes pushes plastic cookware or whatever out of the racks and it lands on the heater and melts the plastic,also if overloading the racks the plastic wheels pop off and burn on the heater,if not this then you'll have to kill the power and start looking for a broken wire on the door,amelted wire nut where the power wires are connected to the machine or the motor smoked up,could be anything,were you near the machine when it happened?could you see where the smoke was coming out of,under the machine or inside,also next time send the model number
Nov 21, 2010 | Frigidaire Dishwashers
Good morning... we have a samsung dvd home theater system ht x50 yesterday while watching a movie smoke began pouring out of machine. we quickly unplugged it and all it's speaker wires and promptly put it...
You did the right thing, it is probably a write off, smoke from electronics is always a bad thing. most likely a component failed inside and released a lot of heat and smoke, possibly stressing other components as well.
If its under warranty call the dealer, but if its old get something new.
But in any case always tell the maker what happened, just so they know what happened .
Hope this helps
Thanks for using FixYa
Aug 02, 2010 | Samsung HT-X50 System
Smoke comes out of the lid hinge whenever i switch it on. What can I do to remedy this? Thank you Pam
there mire be a short in your system it would involve taking the screen off and checking the woring inside it. its pretty straight forword. get a small screwdriver and find the screw on the lid. there usually under the rubber stoppers. they mite be different screws then a philips +. so be prepaired to buy a new screwdriver if needed. makke sure all the screws are out before you attempt to pop out the cover. once the screw are out the screen will probably take a liittle prying to get it off because of the clicks holding it on. but once its off there will probably be a few open cords touching. just make sure there arent touching and the power is off befor you attempt to touch the cords. if you can not locate the smoke turn the system on and see where its coming from. be sure not to touch any wireing while the system is on. when you locate it jsut tape it up with some electrical tape.
Jan 12, 2010 | HP G70-250us Notebook
Large amount of white smoke from exhaust and loss of water from the system. No visible leaks.
ok open your oil cap and see if its creamy inside there
if it is there is water getting into the head
caused by blown head gasket
if not just get back to me and ill find the other soulution
Jul 19, 2008 | 1996 Audi A4
Pioneer deh 1600 has no power
just run both red and yellow to 12v ...
well put the red on a constant 12v source then
yellow you need to put on a 12v source that comes on and off with key ..
yellow wire can go to the fuse box and take a non-using fuse out and put wire in it and should have power .. ..
i would recommend to locate the cars original wires tho ..
i am no pro iam just an average joe but i kno from installing stereos in many many cars .. ive done hack jobs to comp ..
hope this may help you
Jun 12, 2008 | Pioneer DEH-1600 CD Player
Well.. if there is smoke coming from the head unit, the head unit could be bad. It odviously may have a wire crossed or a fuse blown, or even the wire harness could be bad. First, check the fuse for the radio on drivers side door, then check the other fuse box under the hood. Make sure all radio fuses are intact and not blown. Second, check behind the head unit to make sure no wires are touching each other and shorting out. Third, if nothing else helps, buy a new head unit & wiring harness :]
hope this helps!!!
Pioneer DEH-P7700MP CD Player Logo
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
