Question about Refrigerators
How do i put my kenmore fridge model 97065842e into forced defrost
  • 4,059 Answers
Try to find the model number using this. It should start with 106.xxxxxxx
http://www.appliancepartspros.com/modelnumber_locator.aspx
Posted on Sep 05, 2009
MY KENMORE FRIDGE ONLY WORKS ON THE ICE MAKERS SIDE NOT ON THE RIGHT SIDE..
You probably have a component failure in the self defrost system or a failure of the evaporator (cooling coil) fan motor that forces air from the freezer over to the refrigerator.
Sep 22, 2014 | Kenmore Refrigerators
I have a kenmore coldspot, my freezer works but my fridge does not, i hear the fan work, it used to blow cold air from th ebottom of the fridge when we first had it and now it does not model number...
chec for frost on the back of the freezer compartment in the lower section if frost is forming the fridge is not de frosting properly a very comon problem usualy caused by the timer not advancing and turning the ellements on could also be caused by the ellements or defrost termination switch you will have to turn the defros on manualy and test for power through the termination switch and to the ellements .the termination switch will show an open circuit if it is above a certain temprature usualy around 45 degrees.
Mar 08, 2011 | Kenmore Side by Side Refrigerator
Freezer getting tomuch ice,fridge doesnot gets cold
The problem you describe is very frequent. The fridge is getting the coldness from the freezer through a chant and the force of a motor fan Motor evaporator
Number: 173301 Substitution: 5300158289 part no. 26. So the build up of ice in the freezer is blocking the air pass thought and get the fridge cold. Also it may block the fan motor blades from rotating.
So the first you need to check is the heating element on the evaporator in the freezer department. This element might have burn out (and now is open circuit) and even f the defrost timer give instruction for start heating up the element is bad so the defrost is not performed. You just need to replace the heating element. Heater
Number: 178425-01Substitution:5317842502
Is the part no 1 in the diagram in this link.
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/All-Products-Parts/Model-2538648024/0582/0160000/00040500/00003?blt=06&prst=&shdMod=
If the heating element then the defrost timer is bad and does not give any instruction to the heater so you need to replace the defrost timer Defrost timer
Number: 174820 Substitution: 215846602 part no 40 in the following link
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/All-Products-Parts/Model-2538648024/0582/0160000/00040500/00002?blt=06&prst=&shdMod=
As you can see in above links and the one below you can find all the parts of your fridge which the diagrams can help you find them.
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/All-Products-Parts/Model-2538648024/0582/0160000?searchedModel=64802&blt=
Nov 28, 2010 | Kenmore 64802 Top Freezer Refrigerator
Can I manually force the defrost cycle
on the older fridges you could, but not now, just unplug it
Oct 29, 2010 | Kenmore Refrigerators
Kenmore side-by-side not dispensing ice or water, the ice maker has been replaced, no water going into the tray. I cannot locate the water filter, does this model have one?
Don't know what is the model number of your fridge. 1.Need check electric water valve under the fridge. If that fridge made by GE (Kenmore just a Sears brand name and they use several others manufacturers for refrigeration), usually it's a frozen plastic water supply line inside freezer door. You could unplug fridge for 24 hours (you have to put food from freezer to other freezer).
Jun 29, 2010 | Kenmore 24.5 cu. ft. Side-by-Side...
KitchenAid fridge model #EE4412201, freezer is NOT defrosting. Air tower iced up a little, freezer floor all ice. water in back of fridge. Freezer is cold, fridge isn't. I cleaned the freezer, took the...
try a new defrost timer. or new kit defros timer defrost terminator and heater. tfound the timer rotate, open the freezer. if you hear a noise like ICE BREAKING. your onli problem is the timer. really important after repair your fridge. allow at least 24 hr for defost the whole evap. REALLY IMPORTANT
Mar 31, 2010 | Refrigerators
Magic chef fridge not working
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Could also be beginning of defros problem.
Jun 04, 2009 | Magic Chef CTB1821AR Top Freezer...
Refrigerators Logo
200 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
