37LG5010 screen flickery and distorted after short time.
Hi, I have just bought a graded 37" lcd tv (37LG5010). I am using the built in freeview and have an xbox 360 attached using component video connection. The TV is great to start with, but after about 15 to 30 minutes the image breaks up, goes dark in some places and becomes distorted and flickery. When the tv is turned off and on again it is ok for about 5 or 10 minutes then the same happens again. This affects the TV menus as well so can't be anything to do with reception or connection of wires. I am going to call tomorrow but have recently read several reviews that the shop i bought it from ( do not honour guarantees, so I am pre empting this and trying to find out how much it will cost for me to get it fixed myself. Thanks very much!
  • 1139 Answers
The overcurrent circuit is working as it should. You will have to have this set serviced by a qualified techniciam.
Posted on Sep 09, 2007
  • 108 Answers
SOURCE: ACER LCD monitor no image, appears white color only
Quickly go to the Acer website and check FAQ's and while there also find out how to get an RMA to return it. My guess is you have a bad monitor. At $200 roughly for a replacement I would hustle. I am assuming you got nothing but a white screen but did get video on your TV.
Posted on Jan 24, 2008
SOURCE: Hannspree 37" with Xbox 360 HD
Try to use a HDMI cable, your component cables may not be usable with your TV.
Posted on Apr 22, 2008
  • 38 Answers
SOURCE: powering on my tv
Dear smmmobil,
The problem lies with the SMPS (switch mode power supply ) of your TV. The smps board needs to be replaced.
Posted on Jun 15, 2008
  • 3459 Answers
SOURCE: Philips 46-inch Rear Projection with bowed image?? slight distortion
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
You need to replace the convergence chips and convergence resistors. Check the site They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Posted on Nov 28, 2008
Hi have a Neoniq 32cm flat screen, and I can't get it to tune - it keeps saying "no Signal" but it is plugged into the aerial and the aerial works because I was using it with an old TV. I can't...
When i turn on tv the screen goes off after 5 seconds . I have to turn on and off the tv a number of times before the screen stays on. Any suggestions to what is wrong??
Apr 08, 2011 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Hi i have a Sony Bravia KDL37EX403U 37'' Freeview HD LCD TV 1271381 and it is buzzing all the time the tv is on
This is a common problem with this screen, and is caused by a faulty inverter on the panel. Newer ones have a modified part and the fault is recognised by Sony as a manufacturing fault. Therefore you should have no problem having it repaired.
Dec 07, 2010 | Sony Televison & Video
Frozen screen on the dtv
in such cases may restart disconnect and reconnect and if the problem reinside check the local antenna signal may be failing
Nov 04, 2009 | Samsung LE37R72B 37 in. HD-Ready LCD...
How do i get my built-in freeview to work?
I have freeview inbuilt on my tv. I hav sky at the mo so hav the satellite dish but want to get rid of sky and just hav freeview. So how do I make freeview work? Do i need to buy some sort of cord/connection to hook up the satellite cord/connection to the tv?
Oct 14, 2009 | Toshiba 37RV525R 37 in. LCD HDTV
Digital channels have stopped working, only blue screen!
Try resetting the TV:
  1. Switch on TV and switch to any analogue channel.
  2. On the TV: Press and hold the MENU button.
  3. Menu screen will appear on the display.
  4. Do not release the MENU until the menu screen disappears.
  5. TV will go blank for about 60 seconds and then display initial set up screen.
  6. Follow the on-screen prompts to re-tune the TV.
If this does not work then the problem is likely to be a loose ribbon cable or main small signals board inside the TV.
May 17, 2009 | Philips 37PFL5332D 37 in. LCD Television
Calibration for a new lcd hdtv
yuo sound like you are watching analoque tv press the tv button on remote for digital
Mar 11, 2009 | Panasonic VIERA TX-37LZD800 37 in....
Toshiba 37X3030D LCD TV
no, the tv has a setting that auto changes the screen ratio. you can turn the auto screen ratio off in the settings section. Once you have turned it off put ratio to 16:9 and it will solve the problem.
Jun 17, 2008 | Toshiba 37HLX95 37 in. LCD TV/DVD Combo
Samsung Digital TV and Sony DVD Recorder
hi, did you find a solution? i have in built freeview and have bought a recorder but i cant pick up any freeview channels on it. the dvd recorder is a Wharfedale DVDRHD400 cheers tom
Feb 11, 2007 | Samsung 4 CHANNEL DIGITAL VIDEO RECORDER...
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
