Question about Apple iPhone Smartphone
My iphone 2g only shows the apple for 10 seconds then shuts down
When i turn my iphone 2g on it shows the apple likr its turning on normal, then it stays on for 10 seconds then it shuts off. i try to jailbreak it but it doesnt stay on long enough for that or for itunes to recognize it. can anybody help with this problem?
    President:
  • 392 Answers
Try restoring it...here's how...
  1. Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
  2. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
  3. Press and hold the Home button while reconnecting the USB cable to iPhone. When you reconnect the USB to iPhone, the device should then power on.
    Note: If you see the message "Charging... Please Wait" , let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.
  4. Continue holding the Home button while iPhone starts up. While starting up, you will see the Apple logo.
  5. When you see "Connect to iTunes" on the screen, you can release the Home button andiTuneswill display the recovery mode message:
    If you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6.
After this you'll need to jailbreak it too....
Posted on Sep 06, 2009
I had to do this three times before it would work. Don't get discouraged
Posted on Apr 01, 2010
Pls help.. will all the data get erased on restoration? thanks.
Posted on Oct 03, 2011
  • 34 Answers
My iphone 2g i dropped not that hard.and 1st showed the no/yes network for a few seconds,then battery out,then home button stopped responding.and shut down.now when i connect to plug in charger no charging.and pc only apple logo startup for a few seconds.then the display flickers and black screen.how can i do this with no home button.
thnx for any reply.
Posted on May 16, 2010
I have had my iphone less than a week- i did not expect it to have problems so soon. .... i have iphone 2g my battery ran out now it wont recharge or turn back on? .... but it doesn't turn on, it...
If your iPhone's battery runs very far down, the iPhone won't turn on. That's because it's using its remaining battery life to preserve your data and settings.So, your iPhone could be refusing to turn on because its battery doesn't have enough juice. In that case, plug your iPhone into a wall charger or into your computer (plug it directly into the computer; some USB ports on keyboards don't have enough power to charge iPhones). Let it sit for 10-20 minutes. If it was low on battery and needed a charge, when it's got enough juice to power the screen, it will turn on and show you its charging status, starting with the red battery icon.During this process, you may also want to make sure there's no lint packed into your cable or the iPhone's dock connector. This isn't a hugely common problem, but a lot of pocket lint could interfere with the iPhone getting a charge.
Jun 28, 2011 | BoxWave Corporation Apple iPhone 2G...
When I turn on iphone 3G it only show apple logo, after that it is turned off and shows nothing, Further when I connect it to itunes or computer it does not show iphone. I have tried to restart the set by...
Hello.
You'll need to reset the iPhone.
From About:
To do that, hold both the sleep/wake and Home buttons together for at least 10 seconds.
The red shut down slider will show up at the top of the screen and then disappear. Keep holding the buttons. The screen may even go black, but don't let go of the buttons until the Apple logo shows up. When it appears, let the buttons go and the phone will start up normally.
Hope this resolves your problem.
Jan 15, 2011 | Apple iPhone 3G
I tried to upgrade my Iphone and I did not do it. Now I can not use it. I tried to restore and show me and error.
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
Reset
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a 10 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 25, 2010 | Apple iPhone 3G
My iphone 4 is locked .is on 4.1 baseband 02.10.04
Unlock:
Plug it into iTunes with it at the unlock screen. Somewhere it should say "Unlock your iPhone" or something like that in iTunes. Click it. Otherwise do a restore by going to the screen where it shows how much memory you have used up in iTunes and click
Reset
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Dec 17, 2010 | Apple iPhone (16 GB) Smartphone
Iphone is stuck on apple logo
Reset
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Nov 30, 2010 | Apple iPhone Smartphone
I have an iphone 2g that is frozen on the apple logo during an unlock...can't seem to restore it or anything as itunes doesn't recognize it
Try press and hold power button till it turns off and then turn on while holding home and power for 10 seconds and then release power button only and hold home still for 30 seconds. It should put phone in DFU recovery mode and then iTunes should see it. Once it does, re-install latest OS.
Jun 10, 2010 | BoxWave Corporation Apple iPhone 2G...
You need a full system restore, plug into itunes and click restore, apple will guide you through the rest. This will delete all data but it will sync it back to the last time that you synced your iphone.
May 11, 2010 | Apple iPhone Smartphone
Iphone 2g not starting back up after reboot..
When the device is locked up like this hold down the lock and home buttons. After a few seconds the device will turn off, immediately let go of both buttons. Now press down and hold the home button. Hit the power/lock button one time. Continue holding the home button until the phone boots up. It will need to be connected to iTunes for recovery at this point.
Jan 27, 2010 | Apple iPhone Smartphone
I clicked reboot not my iphone wont turn back on what do i do????
Iphone Connect With Itune
Turn Off Your Phone
Press Home Button for 5 Second
After 5 Second Press Power Button for few second
Release Power Button
Still Holding The Home Button
Itune Detect Your Iphone In D.f.u Mode
Release Home Button.
Jan 20, 2010 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
3,003 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
