Question about Ryobi Garden
My grass scorpion willn't start,I have changed fuel with a new mixture & spark plug,still no start & plug wet with fuel & exhaust.Any help to the problem appreciated-dealer give me DJ8J spark plug was originally running RDJ7Y is this the correct plug?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 142 Answers
To make sure that you have the right plug,you need to specify the make and model number of your trimmer.The first thing you need to do is check and make sure you have spark to the plug.
Set the trimmer down.Take out the spark plug.Put the plug into the plug boot and set it on top of the motor.Make sure the switch is on,and pull the recoil a couple of times.Look at the end of the plug to see if you have spark,and make sure it is blue.
If you have spark,you might have a problem with your carburetor settings.
Posted on Sep 04, 2009
Testimonial: "thanks for the help elimated one question."
Honda GXV160 will not start.
Is it getting spark? Have change spark plug?
Aug 28, 2017 | Honda Garden
I replaced the fuel and water pump. Now when i try to start it, fuel comes out of the exhaust and air breather
See if your ignition system like your plugs, coil and leads are providing spark.. Wet or oily plugs shows that the fuel mixture is not combusted.. Check your current source ( battery) is providing enough current too..
Jul 19, 2014 | Honda VTX 1300 R Motorcycles
Sears troubleshooting
Check for leaking intake gaskets or leaking head gasket
Those issues will draw in extra air, that will lean out the fuel mixture
or prevent the proper vacuum from drawing fuel into the cylinders,
thus the lean backfire
Need to get yourself the spark plug tester with the clip attached
& says for small engines,to test for a strong spark
There is one also that says HEI on the plug
That one is for vehicles with electronic ignition
& plug gaps of .043 thru .060,not for small equipment
If you have a carb with a float,take the carb apart & clean it
with carb cleaner,then green brakleen & install a new spark plug
For the gaskets,you pretty much have to take things apart to check them
A tune-up on small equipment also includes changing the head gasket, as odd as that seems
If you hear your neighbors mower popping as they cut the grass,
they have a leaking intake gasket or head gasket
When you clean the carbon off a piston & cylinder head you
will think the motor is brand new & starts on the first try
Jun 11, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
2004 mercury 40hp 2 stroke will not start. Fire to the brand new spark plugs. Turns over strong. just no internal combustion. Seems like it's missing the internal "boom" to ignite. Carbs are clean....
if you have spark at the plugs there is a complete ignition circuit for it to start
fuel is the question --are the plugs wet or dry
dry plugs indicate no fuel
wet plugs indicate flooding
inside these motors there are reed valves that open on induction and close for the compression stroke so the mixture is pushed into the combustion chamber
these reed valves fail and the mixture is swapped between cylinders in the inlet manifold hence no combustion mixture for the cylinders
Talk wit a mercury service center for the parts and processes
Oct 28, 2017 | Cars & Trucks
Bike wont start changed battery for new ,there is a spark on plug but wont fire up could it be fuel mixture to strong.
Possibly, but that would be more likely to make it start easily and chuck black smoke out of the exhaust. Have you changed the spark plug? often the plug will work perfectly when sitting on the casing but fail when under compression in the cylinder. Is fuel DEFINITELY getting through?
Mar 02, 2011 | Kymco Zing 125 Motorcycles
Spark Plug gets wet too fast
Air filter may be blocked and inspect exhaust baffles and clean.
Apr 29, 2010 | 2000 Gas Gas EC 200
Chain saw starts and runs once or twice, 3rd time will not start again, spark plug wet - should i replace carburetor?
Most carburetors can be rebuilt and solve most problems, but occasionally the debris is into places where cleaning is not possible, and must be replaced. I would try some basics first though.
Overfuel or 'rich' condition
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check Air filter for fuel saturation
4) Allow engine to run for 5 minutes to excess fuel from muffler
5) Fuel mixture ratio: Make sure the oil mix is per your manufactures recommendations
6) If after the above the engine is still smoking and blubbering:
Adjust carb mixture screws to a 'less rich' setting
*NOTE: only move mixture screws 1/8 of a turn at a time,
and try operation before any more adjustment
Nov 12, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
My Echo GT-200R will not start. The plug is clean and wet. The switch is "On". Fuel (50:1) is new. It was working 2 weeks ago. Thanks, Chuck My echo gt-200r will start and idle but any time you push...
Try cleaning the screen that is located behind the spark arrestor screen cover. This is located on the muffler. Soak it with gasoline and clean it with a wire brush.
May 29, 2009 | Worx 10" 18v 2 In 1 Grass Trimmer/In Line...
V6 Misfire, very Wet plugs #3 and #2
did you change plugs and leads?? doubt its fuel coming out exhaust as most exhausts on vehicles change the emissons to water in the exhaust thats why its wet
Aug 11, 2008 | 1996 Isuzu Rodeo
Garden Logo
328 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
