Question about Motorola Mobility X205 Headset
Motorolax205 will not transmit.
Why is it i canhear fine but cannot transmit.This is ridiculous it was like this right out of the box. im using it on a playstation2 system. it works fine on an xbox system though. you hook it to a ps2 and i cant transmit
  • Anonymous Apr 05, 2009
    same thing...ugh
Yeah, alternatively you can just connect to the controller directly with the wire (not through the grey connector that comes with the headset)
Posted on Jun 30, 2009
Umm do you know where to get another garey conector mine broke
Posted on Dec 11, 2009
  • 38 Answers
There is probably a problem with the connection through the little gray piece. you can bring it to your local best buy and they should fix it.
Posted on Aug 01, 2008
Replaced the fuel pump. Car runs 10 min then shuts down. Acts like out of gas or pump. I wait 1 day and it starts fine for 10 min. I canhear the pump working.
run the fault codes and look for an EVAP problem not venting the tank
look also for a sensor problem that is failing from internal overheating problem from faulty components
Jan 02, 2017 | Cars & Trucks
Why no modulation in transmit mode?
Without seeing it I would guess (and it's only a guess) that maybe you have a broken microphone wire. If it's a factory mic the most common place for it to break is right up from the mic plug. Factory cords are not flexible, their really stiff. We could really use some more information. Mike
Oct 15, 2015 | Uniden Radio Communications
Cb antenna warning
If your readings are below 0.5 with a dipole that is a excellent swr reading, most fall in the area of 2.0 or higher, you will not harm your RF output transistor, if you are getting antenna warnings see if you can recalibrate it.
May 04, 2012 | Cobra 29lx Cb Radio W/clock 29 Lx Lcd
I have a 1986 fully size jimmy with a 305. I need to find out where the computer is located. Everywhere i have searched has said in the glove box and i have taken it down but its not there
Your truck has no ECU (computer) it has a (ESC)-electronict spark control. this has the ability to change the ability to change the ignition timing under any and all operating conditions. Data from various remote sensors (coolant temperature, throttle position, rpm,ect.) is transmitted to the ESC. The ESC computes the information and triggers the ignition spark at precisely the right instant.
hope this helps...
May 18, 2011 | 1986 GMC Jimmy
I have a Bosch Power Box PB10-CD, the GFI outlets clicks on/off
Disconnected the GFCI outlets, and everything works just fine. Ridiculous that Bosch manufactures GFCI outlets that does not last for 2 years. The cheepest American made GFCI outlets last practically for ever. Beeing "Bosch", the replacement outlets cost $38 plus shipping.
It is ridiculous.
Sep 16, 2009 | Bosch PB10-CD Radio/CD Boombox
Transmission swap
yes but you may have to change output shafts, costs $85.00
Jun 24, 2009 | 1993 Chevrolet Suburban
Problem: Audio Connections 2
Thanks, I got your responce. Im currently looking into it.
also, what cable box you got?
Aug 07, 2008 | JVC RX-D301S Receiver
Wireless downloads at very low transmit rate
Could it be the website that is hosting the file?  Have you tried to download it with a different computer?
Apr 21, 2008 | Apple MacBook Pro Notebook
Paper feeding the original.
A number of solutions. Open the transmit cover and examine the paper path for obstructions, "white out" and alignment of the rollers. The exit roller is the last roller and is prone to become misaligned due to the attachment points on the lower transmit tray being actually broken. I have even seen this on so called "B" stock or warranty repaired machines right out of the box. It happens when a sheet of paper gets stopped and someone pulls it out instead of opening the transmit cover to do it. Also, sometimes the transmit cover doesn't close properly. In this case make sure it does close by using 2 hands to do it.
Dec 26, 2007 | Canon FaxPhone L75 Plain Paper Laser
Motorola Mobility X205 Headset Logo
675 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
