Question about HP Office Equipment & Supplies
Hp 5300 all in one wont print and it says it's
HP 5300 All in One wont fax and it says it's online and all the plugs are connected. What could be wrong?
  • 29 Answers
First off, check to see if the line is working. If not, then that's your problem, but also make certain that you have the telephone jack plugged into the line input marked "L" and not the handset jack. You should also move your unit to another telephone jack to test the copier.
If you're still having problems, make certain that you do not have the TX option turned off (this is highly unlikely unless you've been playing with the settings).
If you're confident that the phone lines are ok, and your settings are ok, then your faxboard may be defective. Is this something that just started? Did you recently have work done on your phone lines? Did you recently move this piece of equipment?
Posted on Sep 12, 2009
I want to know how i can use my copy machine to a fax so i can use it for incoming or outgoing?
Install software
Make sure all cables plugged: phone cable, USB cable to computer
Send fax from computer:
- print your document to printer HP .... FAX
Send "traditional" fax:
- put your document into scanner input
- type phone number on HP Officejet keyboard
- push button "Send"
If your HP Officejet if connected to phone line, it reseiving faxes automatically.
Hope this helps
Nov 12, 2010 | HP Officejet 4215v All-in-One Printer
I had to reinstall the software for an HP 3390 on a Windows XP workstion. The device can print and fax. However, when I try to scan a document I get the following message: The HP imaging device could...
The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
If you prefer, you can skip this information and go directly to downloading the tool .
  • Connectivity :
    • USB: Ensures that the USB connection from your computer to the HP product is working correctly.
    • Network: Ensures that the network connection between your computer and your network is working correctly. If the tool detects a network connectivity problem, you will be prompted to run the HP Network Diagnostic Utility for better results.
  • Spooler : Automatically restarts the print spooler, which sends print jobs from the computer to the product, if it has been stopped.
  • Online status : Checks if the product has been paused or set to offline, and then sets the status back to online if necessary.
  • Device manager : Checks for problems in Device Manager that would prevent printing.
  • Print queue : Checks for and clears pending print jobs in the print queue (a log of print jobs waiting to print).
  • Port : Checks the port settings for the HP product.
  • Driver : Checks for alternate-driver settings.
  • Conflicts : Checks for conflicts with other drivers, such as other printer brands.
  • Default printer : Checks the default printer setting and prompts to select the HP product as default (optional).
Oct 26, 2010 | HP LaserJet 3390 All-In-One Printer
Hi my machine wont send or recieve a fax despite being properly connected. printing from computer is fine. has worked fine up until today
Hi check the following article to from HP
Problems with sending and receiving FAX
HP FAX ISSUES
Check the TELEPHONE LINE
Make sure that you have plugged the phone cord directly and securely into the wall jack and into the back port of the fax product. The fax port on your product is marked "Line," "To Wall Jack," or with a wall jack symbol.
Check LIU
Make sure the Line Interface Unit (box that the phone cord plugs into) is fully seated into the back of the fax product.
Remove the SPLITTER
Remove any other devices from the line such as splitters, credit card machines, or telephone answering machines.
Can try sending the Fax on Another Line
CHECK WITH DIFFERENT CABLE
Try using a different telephone cord.
Jan 05, 2010 | HP Photosmart 2610 All-In-One InkJet...
I have attached the HP 4255 officejet with my computer and want to send the file directly from my computer via fax. how i can send directly without geting print . mubashir@ellahifabrics.com
Well, you'll need a modem to send a fax. Either that, or an online faxing service. Your printer / scanner is only intended to either print files, or scan hard copies into files that can then be printed (or faxed). The printer itself does not fax.
Might I suggest the following online fax service, free of charge:
http://faxzero.com/
There are plenty of others.
-Jon
Oct 21, 2009 | HP OfficeJet 4255 All-In-One InkJet...
The printer wont print - control panel says it is poff line, yet it is all plugged in and installed properly
start - settings - printers and faxes
right click on your printer and click use printer online
Jul 14, 2009 | HP DeskJet F380 All-In-One Printer
HP PRI
completely uninstall all software realated to this printer. disconnect your pc from the web. disable your anti virus and firewall then run your fresh install. if you are getting the diver/software from the web save it to your desktop and follow the first dsirections this should solve your problem
Mar 06, 2009 | HP LaserJet 2840 Printer
Hp 5610 all-in-one not printing
Have you deleted the printer, uninstalled the drivers and related software from add/remove programs, reboot the machine, redownload the drivers from their website??
Aug 13, 2008 | HP Officejet 5610 All-In-One InkJet...
Hp psc 1210 all in one printer
go to printer and faxes and then right click on the printer icon and select use printer online.
check usb cable if it is properly plugged in.
download hp printing diagnostic utility at www.hp.com/support make sure you type it in the website search box
Jul 03, 2008 | HP PSC 1210 All-In-One InkJet Printer
Hp officejet, printer copier and fax
HP OfficeJet 710 InkJet Printer driver
Dec 18, 2007 | HP OfficeJet 710 InkJet Printer
51 people viewed this question
Seeker5211
Seeker5211
