Question about Mitsubishi WD-65000 65" Rear Projection Television
Dont know what the difference is between lamps
What is the difference between the 2 OSRAM lamps: P-VIP 100-120/1.4 P23 and P-VIP 100-120/1.3 P23a
  • 736 Answers
These are Panasonic arc lamps .. the numbers 100-120 indicates the intended voltage range of operation .. the /1.3 or /1.4 is the current in amps .. so the 1.4 is slightly higher current and likely a bit brighter .. thats 156 watts vs. 168 watts .. arc lamps are much more efficient than incandescent so 150 watts in an arc lamp is a lot more light than a 150 watt incandescent...
Posted on Sep 04, 2009
Testimonial: "thanks that helps out alot. you are the only one that actually ansered my question"
  • Jason Ferris
    Jason Ferris Jan 15, 2014
    Not true... the 100-120 is the wattage, the /1.4 is the arc length...
My Mitsubishi tv WD 73734 won't show a picture you can hear sound and it powers on and off lamp light red and timer lighter blinking
No TVs will behave that way due to a timer. TVs only will display a nag screen telling you to reset the timer. If your lamp is more than 2 years old, it is suspect of failure. Be sure you buy a lamp with an Osram brand or Philips brand bulb inside. Any compatible(knockoff)lamps will not perform as they should. Mitsubishi DLP TV Bulbs
These folks sell original Osram bulbs in their lamps and they have a 6 month warranty. I use them myself for repairs and really have had great experiences with them.
Sep 09, 2015 | Mitsubishi WD-73734 73" Television
Mitisbuski 73737 made popping sound and cut off
Check your lamp. The popping sound was most likely the arc tube exploding. Make sure you only install a real Philips or Osram lamp. WD73737 Mitsubishi Genuine High Quality Original Projector Lamps now...
These folks have good lamps.
Apr 28, 2015 | Mitsubishi WD-73827 73" HDTV DLP TV
Replacement bulb/lamp availability
Google search your manufacturer make and model and the words replacement lamp. You can find reputable vendors it in the search results.
Mar 31, 2015 | Televison & Video
When powered up picture comes on very dim then it turns off but unit fans stay on for 5 minutes then shuts down all the while the power button is flashing.
You most likely need a new light bulb. The bulb is an Osram P-VIP 180/230w. Just google it, or here is a link to it: http://www.purelandsupply.com/D1000-Bulb-Cinego-Lamp-Bulbs.html They cost about $180 new. Good luck!
PS - Be sure NOT TO TOUCH the bulb when you replace it. The oil in your finger skin will cause the lamp to fail early.
Nov 29, 2010 | Radio Shack Cinego D-1000 Multimedia...
Sony KDF50E2000 lcd tv has burned out it's second bulb. Replacement bulb was OSRAM brand. It only lasted 10 months, now it won't come on. Should I be looking at the ballast or did I just get a poor...
Hi,Osram lamps average around 3000-4000 hrs.Normally 1 -1 1/2 yr.I do think the lamp went out.The ballast is a possibility,when it's going bad it will make clicking noises or attempts to light the bulb.I recommend to get the Original Philips lamp for they average 6000-8000 hrs 3-4 yrs.
Mar 25, 2010 | Sony KDF-50E2000 50" HDTV
Replacement lamp not bright
as i previously posted, my picture was dim, muddy looking after replacing lamp with osram lamp. i fixed mine by taking the screen off and cleaning the small mirror. it had a thick layer of dust on it, cleaned with a microfiber cloth. no water, no glass cleaners. i also used a very fine new small paint brush and dusted the projector lens which also had a dust film. brightness, contrast and clarity returned!
Mar 05, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi wd 52725 lamp troubles
You can use Mitsubishi 915p020010 or Osram E023. Remove the front and clean the lense using only a clean microfiber cloth. dirty lense main cause of dark picture. The lamp could be incorrect wattage.
Mar 05, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Pcb/board
You really need PT VIP 2AC/380 01 PART FROM OSRAM
Sep 30, 2008 | Televison & Video
Lamp bulb
Hi shanoo
I've learnt that most Projector brands can take Osram lamps - try finding a Osram agent near you and remember to keep the wattage of the lamp the same as the previous.
May 09, 2008 | Sony XL-2000U Projector Lamp for XBR800...
Ghost images!
I had the same problem, reset the lamp hours by pressing 'menu, 619 , menu" and browsing until I found the setting, but then I also saw an option to test the lamp.  The TV shut off when I tried this and 2 red lights indicating a new lamp is needed came on instead.  It's probably the ballast and not the lamp, but I don't know that I want to put any more money into this set.  I have only had it 2 years.
Apr 26, 2008 | Optoma RD50 50" Rear Projection HDTV-Ready...
Mitsubishi WD-65000 65" Rear Projection Television Logo
138 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
