Question about American Standard Cadet 3 Right Height Elongated Toilet by - ADA Compliant
How much draw down (tightening) do use to attach the water tank to the toilet bowl on a American Standard Flowise Cadet 3 toilet? Does the tank need to meet the bowl?
  • dickdb Sep 05, 2009
    What I need to know is how tight to make the tank bolted onto the base...now it rocks after hand tightening the two bolts to compress the rubber seal!
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 46 Answers
Seat the tank well on a new wax ring and then tightnen the two bolts on the sides evenly there is a small amount of pressure but thats it. To much and you'll snap the side of the bowl. You can caulk around the edge if you want more security,less movement.
The tension on the nuts is very tricky just a feel kinda thing.
Be carefull not to over do it.
Posted on Sep 04, 2009
  • Tony Sheppard
    Tony Sheppard Sep 04, 2009
  • Tony Sheppard
    Tony Sheppard Sep 05, 2009
    Sorry , the tank tourqe should be enough to set the tank almost to the bowl with just a small gap inbetween.
    There could still be some movement but remember its gonna have water in it and your dealing with porcelin.So dont over tighten!
Squeaky toilet
As the water in the tank reaches the full mark, the valve that shuts the water off begins to close. As it closes, less and less water is allowed to go past the valve. When the tank is at the full mark, the water is shut off completely. It's like letting air out of balloon. The smaller the opening, the louder the squeal. You may need to replace the float and valve set or some how lower the water pressure at the toilet.
Dec 29, 2015 | American Standard 3011001.02 Cadet 3...
I had the same issue wit my champion toilet the issue was finally resolved by using a plastic drain snake and cleaning out the flush tube at bottom of drain (1" hole at bottom of drain facing toward front of toilet) mine was restricted down to 1/2" "bad casting I think"
May 14, 2014 | American Standard Cadet 3 FloWise...
Relace flush valve seal
The American Standard Cadet 3 flowise one piece toilet uses a flapper valve with a soft nylon washer to seal against the water outlet.
Over time this nylon washer develops 'puckers' causing water to seep between the nylon washer and the seat of the flapper. This seepage causes the water level in the tank to drop to a point where the water inlet valve opens to replace the lost water in the tank.
There are two ways to correct this problem:
1. Replace the soft nylon washer on the flapper, or
2. Replace the entire flapper valve.
Hope this solution helps.
Apr 15, 2014 | American Standard Cadet 3 Right Height...
Toilet tank to bowl small leak
You need to replace the tank to bowl nuts, washers, and gaskets as well as the flush valve gasket. One word of caution. When installing the new bolts to hold the tank in, place a rubber gasket under the washer inside the tank, and also one on each bolt under the washer underneath the tank. If you omit the one under the tank you may end up cracking the tank when you tighten it down.
Jan 16, 2014 | American Standard Cadet 3 Right Height...
I have a new American Standard Cadet 3 that was just installed. After flushing, the water fills into the bowl. However, after several minutes, the water in the bowl slowly drains away and is nearly gone....
Sorry for problem with new toilet.
You say water is leaking out of the bowl?
Toilets have 2 parts:
1) Tank: where water is stored for the flush and is sealed with a flapper.
2) Bowl: where water flushes down.
a) If tank is leaking water, then flapper is suspect. Replace flapper and see if that works.
Lift up flapper and run finger around rim to see if there is a rough spot that would indicate flush valve is defective, and needs replacement.
See typical flush valve
b) If bowl is leaking, that is very unusual and would indicate a crack in the porcelain.
If installer sold you the toilet, it is his responsibility to make good on product.
All products are guarantee against workmanship flaws.
Feb 26, 2011 | American Standard Cadet 3 Right Height...
Why is there low water level in bowl
That is the way the toilet is designed. There is not a large water surface in this brand of toilet.
Sep 08, 2010 | American Standard Cadet 3 FloWise...
After flushing, water level in bowl fills and then slowly drops.
Check to be sure small tube is flowing inside the ovefow tube. This is the water that flushes the rim holes, and refills the bowl. If you don't have flow clean or replace the float valve.
Jul 19, 2010 | American Standard Cadet 3 FloWise...
I just installed two A/S Flowise Cadet 3 toilets..how tight should the tank be bolted down to keep it from rocking?
The tank should come down until it touches the bowl. You tighten one side a bit and then the other to bring it down evenly. You have to be looking in between the two as you tighten.
Sep 05, 2009 | American Standard Cadet 3 FloWise...
Cadet 3 round bowl toilet not flushing all from bowl
You are probably correct, the water level needs to be raised. There are many different toilet tank systems, but all have some way to control the water level in the tank. Let me know if you need help figuring it out...
P.S. You'll have to take the lid off the tank, first...pardon me if that is too obvious
May 08, 2009 | American Standard Cadet 3 Right Height...
American Standard Cadet 3 Right Height Elongated Toilet by  - ADA Compliant Logo
385 people viewed this question
Top American Standard Home Experts
Donni Steen
Mike
john h
Are you an American Standard Home Expert? Answer questions, earn points and help others
