Question about Spark Plugs BR4HS Plug 10/BX #3322
What is the spark plug gap for a kubota zg23 - Spark Plugs BR4HS Plug 10/BX #3322
  • 27 Answers
28 thou
Posted on Sep 05, 2009
Kubota ZG23 I need to remove the deck adjustment knob what's the best way to do this without breaking it?
knobs are held on by various methods
threaded with a lock nut
left hand thread
or with a small roll pin under the knob through the hub section of the knob
If you have no threads showing or lock nuts then I would be checking for the roll pin probably around 1/8 " dia
Apr 04, 2018 | Kubota Garden
NEED SPARK PLUG GAP FOR 9BSXS 190-1VH
The gap is .040 and is pretty much a standard gap.
May 17, 2017 | Cars & Trucks
What is the spark plug gap for the above car which is 4 cylinder. thanks
1988 Oldsmobile Cutlass Ciera, original GM plug gap .045".
this is what i would gap new plugs too, AC Delco Part # R44LTS plugs probably gaped at this already.
press the helpful button
How To Change Spark Plugs on 1987 Cutlass Ciera SL 3 8L
Spark Plug Gap NGK Spark Plugs Tech Video
How to Gap Spark Plug
Feb 04, 2016 | 1988 Oldsmobile Cutlass Ciera
Spark plug gap
How to Gap a Spark Plug - YouTube
? 2:57
https://www.youtube.com/watch?v=IuW3svdqKZM
Oct 15, 2012 - Uploaded by ChrisFix
How to correctly gap a spark plug. This is a fast and easy video on how to gap a spark plug and spark plug gap ...
FAQ: Find My Engine Spark Plug & Gap ' Briggs & Stratton
www.briggsandstratton.com/.../identifying-the-correct-s...
Briggs & StrattonFollow this step-by-step image guide to locate spark plugs in different Briggs & Stratton engine types. ... Spark Plug Type & Gap Chart for Briggs & Stratton Engines. Now that you've found the part you'd like to replace, you can use the chart below to identify the genuine Briggs & ...
Spark Plug Gap - AutoZone
Dec 15, 2015 | Cars & Trucks
17 hp kubota burns out right side spark plug in in an hour, not filed just dead will not work on the other side if switched after burned out. What can cause that?
Hi Robert:
Sounds like you've some trouble shooting to do. Try starting by installing new spark plugs in all cylinders. Find a project and run the machine for an hour or so. Let it cool off, then pull the spark plugs. Keep track of which one is from each cylinder. There are some excellent charts available that show what is going on in an engine from the appearance of the plug. OILY & Fouled is usually bad rings, SOOTY black can be too rich a mixture, Too lean can make the tip look almost melted. Enjoy the chase!
Mar 03, 2015 | Kubota Garden
I have a Kubota zg23 that will run great for ten minutes then stall. It will start back up and the cycle continues.
Try checking the gas filler cap to make sure the vent hole hasn't got clogged. When it is clogged a vacuum will develop in the tank as it runs. When the vacuum is greater than the pressure from the fuel pump the engine will stop from fuel starvation.
May 19, 2014 | Cars & Trucks
Need spark plug part# and gap for stiener 420 with 21hp kubota 3cyl. water cooled engine
Here are the plugs you need, pre-gapped to .035
http://www.rcpw.com/rc12yc-spark-plugs/130119.html
May 04, 2011 | Computers & Internet
Need do know the spark plugs gap
If you're replacing the spark plugs in your car engine, you'll need to set the gap before reseating the spark plug. The gap is the distance electricity arcs between the ground electrode and center electrode. The gap must be set correctly to ensure maximum performance. Here's how to set the gap of a spark plug.
  1. Remove the spark plug wires. Use a socket wrench to remove the spark plugs from their chambers.
  2. Clean the spark plug if you are not replacing it with a new one. Remove all dirt and debris from the spark plug.
  3. Check the owner's manual for your car (or any appliance with spark plugs) to find out the recommended gap setting.
  4. Use a gap tool to check the gap of the spark plug. Slip the tool between the ground electrode and center electrode. The gap tool should fit snugly at the recommended gap width indicated on the tool.
  5. Push the tool between the electrodes a few times to ensure proper gap. If the gap is too wide, push the ground electrode firmly against a flat surface to narrow the gap and then check again with the gap tool.
  6. Repeat Step 5 as necessary until you reach the correct gap. Reseat the spark plug and reattach the spark plug wires
Good Luck
Dec 10, 2010 | 1997 Pontiac Grand Am
Spark plug gap
Notice: This engine has aluminum cylinder heads. Do not remove the spark plugs from a hot engine, allow it to cool first. Removing the spark plugs from a hot engine may cause spark plug thread damage or cylinder head damage.
Gap the spark plug, using round wire type spark plug gap gage.
Gap Adjust the spark plug gap to 1.14 mm (0.045 in).
DO NOT coat the spark plugs with anti seize compound. Over torquing could occur and damage to the cylinder head threads may result.
If your going to use Platnum plugs, DO NOT GAP them. Just check the gap and if there not the right gap, ask for new one's with the right gap.
The metal on the PLatnum plugs, are harder and my break apart in the cylinder .
Good luck and hope this helps
May 02, 2009 | Pontiac Sunfire Cars & Trucks
Spark Plugs BR4HS  Plug 10/BX #3322 Logo
549 people viewed this question
Top Ngk Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Ngk Vehicle Part and Accessory Expert? Answer questions, earn points and help others
