Question about Kenmore 15892 Built-in Dishwasher
New dish washer
Will not drain only used the one time to discover that.
Did you put a new garbage disposer in as well? You may need to knock out the plug in the garbage disposer
Posted on Oct 10, 2009
  • 833 Answers
Cincai, sounds like you may have a kinked drain line or a defective unit. Check that drain line...if not, get Sears in to fix it.
Posted on Dec 08, 2007
Ran dish washer without water turned on.
The first thing these units do is check the pump. Put a gallon of water in it by hand then try to turn it on. See if it makes any effort to drain.
Nov 27, 2017 | KitchenAid Dishwashers
Dish washer
The drain tube is stopped up, use a metal coat hanger pull unit out unhook drain stick wire in and swirl around.
May 09, 2013 | Dishwashers
Dish washer not emptying
put your model # into a google search and choose a place that has parts and look up your drain pump. you probably have either a clogged drain hose, not likely, or a bad pump.
May 13, 2012 | Dishwashers
We discovered broken glass dish in bottom of dishwasher with some pieces below the bottom pump area. Shortly after the washer is making a louder noise during operation time. The water pump is quite when...
sounds like you have broken glass in the wash pump you will have to remove pump from sump and clear also check the drain pump.good luck let me know how it goes
Jun 22, 2010 | KitchenAid KUDK03ITBK Built-in Dishwasher
Dishwasher really holds smells from soiled foods. Can I put bleach in the dispenser periodically?
First check your main draining system. the entire gas escapes through your dish washer.
Clean the wash chamber with water. Do not try bleach as it may spoil the other parts. If still prefer to use, dilute and use.
For some time use a bucket of 10 to 15 liter and drain the dish washer out let. If the smell not noticed, it is eminating from the main drain system.
May 17, 2010 | Bosch 24 in. SHE43C05UC Stainless Steel...
Dish washer not draining
May be that there was a little regular soap or something put in that made it suds up. vegetable oil poured into the dish washer tub will remove the suds. After running vegetable oil for about 5 minutes, pour 2 cups of vinegar in to the tub and run it on the hottest longest cycle with no dishes in it. This will clean the residue out and what ever "gunk" may be in the internal parts. Use Only powder detergent. No gel and No tabs. These 2 cause a build-up over a period of time of use and reduce the performance of your machine. This should take care of your problem.
Apr 11, 2009 | GE Dishwashers
Kitchenaid dishwasher will not drain completely model kuds25shwh1
there is a plastic cover in the back over the drain under the dish tray,, pull out the tray and in th back of the dish washer there you will look down and see a small strainer that is plastic, you will need a 1/4 inch nut driver to remove the cover,, after you remove it there is a couple of pastice peices to take out that are just laying there, remove them and there is a small blade that is there to help cut up food that has been left behind on the dishes,, you can remove this and under it you will find the drain hole,, clean out any debris that is in there, if you have to you might want to take tha bottom cover off the lower front of the dish washer take off the drain hose and flush water thru,, adfter this and then reinstalling everything the way it was, run the dish washer if it still has water sitting in the bottom it is time to get a new pump, it is bad and not pumping,,, you may wish to have an appliance person out to tackle this job,, good luck
Jan 28, 2009 | KitchenAid Superba Architect KSCS25INSS...
Mucky water after cycle complete
poss a blocked drain or a backe feed from the sink remuve drain hose and check.
Nov 13, 2008 | Dishwashers
Have a trouble: dish-washer will not drain.
I just moved into a new house and builder had provided a dish washer drain just below my kitchen drain line.
DIsh washer install was done by me, every thing worked out OK except dish washer would not drain after a wash cycle.
Cause: drain provided by builder was blocked and needed a circular small cut before mounting drain hose over it.
Mar 21, 2007 | Electrolux 24 in. ESI6220X Free-standing...
Kenmore 15892 Built-in Dishwasher Logo
97 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
