Question about D-Link AirPlus DI-524 Wireless Router
All seems ok but the speed keeps switching between 1mpbs and 11mbps, so even though all weems to be working fine I am unable to get interne connection. Can you help me?
  • 7,993 Answers
Check with your ISP.
You get those changes when then the signal you are trying to connect to is too far. (signal is weak).
Also, you may try to access a network, the WIFI will connect, but your machine is not allowed (security settings of router)
Hope it helps.
Posted on Sep 05, 2009
Stihl 090 Chainsaw carburetor get way too much gas at high speed, even though HS jet is completely closed.
You have an internal circuit leak in the body itself, my friend. Get a new carb, it's still going on a $1000 saw and will make it run like new again.
Jul 05, 2012 | Stihl Chain Saw 051 075 088 090 +
Water is over heating when air conditioner is running. Temp is fine when air conditioner is off. Changed radiator fluid and thermostat. Fan is running and water pump seems to be ok.
My suspicion is that the fans may be coming on but they are not picking up speed when you turn on the A/C. Your car would have some of relay to control the speed of the fan whenever the A/C was turned on. This relay system would also increase the speed at which the fans run when the engine heat turns them on too.
Try starting the car cold and turning on the A/C right. Even though the engine is cold the rad fan should start up when you switch on the A/C. Once the engine gets hot the fan speed should increase accordingly when you switch on the A/C.
I'm not familiar with how Chrysler makes this work so I'm unsure what to repair but this is most likely your problem. Hope this helps.
Aug 14, 2011 | Chrysler PT Cruiser Cars & Trucks
Why does my internet speed commence at 15mpbs and reduce to 1mpbs?
Likely the reason for this is the network card. Most network cards are 10/100, and this is typically NOT the bottle neck....100 works well for most users. Routers, and other components auto switch to accomodate the connection speed of the connecting NIC.
You may need to get a higher speed card...
Mar 20, 2011 | Belkin (F5D7231-4) Wireless Router
My emachines laptop, keeps freezing, wont connect to wireless keeps asking for an ip address, and now the mousepad has stopped working, can you help me please.
It seems it Got freezing because its searching for a Wireless network and unable to find that, If possible can you try to switch Off wireless (Button on upper side) and check if its working fine.
For Wireless, You need to check the settings of your wireless router that it should be working fine. All settings should be OK.
Sep 23, 2010 | E-Machines Computers & Internet
I have a cub cadet RZT 54 that was purchased in the spring of 2009. The mower cranks and runs fine but the blades will not engage. Have looked at electrical connections and everything looks fine.
Do you hear a "clunk" when you engage the PTO switch, but the blades don't turn? If so, then check the mower deck belt - is it properly threaded, and tensioned by the idler pulley? If there's absolutely no sound when you engage the PTO switch, the problem is likely electrical (even though everything looks OK). The PTO switch, PTO clutch, and the reverse lockout switches (near the bottom of the fwd/reverse control arms) should be checked. I don't think there's a separate fuse for the PTO on your mower, but there may be a relay. Even though these parts and connections look OK, they can fail internally. Best bet is to get a multitester and check each of them with the ohmmeter function.
Jul 02, 2010 | Cub Cadet Garden
2005 GMC Yukon Speed Odometer gets stuck
It is possible that the battery was the problem due to low voltage. I would keep an eye on the problem and make notes on any conditions if the problem reoccurs. The speedometer head or connections etc. could be a cause, but since problem seems fine now all you can do is watch to see if it happens again. Unfortunatly when a problem is not happening it is very hard to repair or find why it happened. That is why any info on when or how would be helpful even though it may not seem so.
Aug 31, 2009 | 2006 GMC Yukon
Dash lights quit working
I had to replace my dimmer switch when this happened to me even though I thought my dimmer switch was fine
Aug 23, 2009 | 1992 Chevrolet K1500
Hello - amix x5
My wireless router is a Belkin Wireless G Router - 2.4 GHz 802 11g. I do not know what you mean by supporting the B network in my pda.
The wireless card we have is a Symbol for pocket pc/pda. Spectrum24 High Rate Wireless WiFi Networker 802.11b 11Mbps.
Aug 26, 2008 | Dell Axim X5 Pocket PC
Unable to charge :(
Does it say something like "charger not recognized". I remember having this problem with my razor, and it drove me crazy for several days, then it went away and has never returned. I may have also blasted all the txt messages away to help fix it to. Killing all the txt messages seems to help this phone if its acting up. Definitely speeds up the menu operation. Apparently 250 txt messages is its capacity, even though it will store alot more.
Nov 11, 2006 | Motorola Mobility RAZR V3
D-Link AirPlus DI-524 Wireless Router Logo
37 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
