Question about Dryers
My dryer will not spin, it turns on, and blows hot air. timer works, settings work but no rotation.
abhishek33
  • 1239 Answers
SOURCE: Dryer not heating
hi The dryer timer, located in back of the control panel, controls several things: the drying time of the clothes in the drum, the flow of electricity to the heating element, and the flow of power to the timer motor and the drum motor in the dryer cabinet.
Timers are driven by synchronous motors. Although the contact part of the timer can be cleaned and adjusted on some dryers, this is a job for a professional repair person. Timer motor repairs should also be handled by a professional, but you can replace a faulty timer yourself. Here's how to test and replace a dryer timer:
Step 1: To access the timer, remove the front of the control panel. On some dryers, the timer can be removed without removing the panel. In either case, pull the timer knob off the shaft and slip off the pointer. The pointer is usually keyed to the shaft by two flat surfaces to keep the pointer from slipping when it's turned.
Step 2: Test the timer with a VOM set to the RX1 scale. Turn the timer to the NORMAL DRY setting and disconnect one of the timer power leads. Some timers may have several wires connected to them: The power leads are usually larger than the other wires, and this size difference can be spotted under close examination. Clip one probe of the meter to each timer terminal. If the meter reads zero, the timer is working. If the needle jumps to a high reading, the timer is faulty and should be replaced. Replace the timer with a new one of the same size and type.
Step 3: To replace the timer, have a helper hold the new timer close to the old one, especially if there are several wires to be changed. Disconnect the old wires at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram detailing the proper connections. After all the wires are connected, check the connections again for accuracy.thank you
please rate it..............
Posted on Dec 02, 2008
TheMobilian
  • 8220 Answers
SOURCE: Roper Electric Dryer Heats but drum won't spin
Yank the filter out the top. Remove the 2 screws in the filter housing. Use a putty knife to pop the top and then remove the screws holding the front on. NOTE: raise up on the front panel slightly so you won't damage the bottom clips. Get the front out yer way and remove the drum. Clean out the dryer and oil the rollers and idler. Use this handy ROUTING GUIDE to see how to put the belt back.
Posted on Jan 20, 2009
aasc
  • 1606 Answers
SOURCE: dryer working but not blowing hot air
Either bad thermal cutoff or bad element .( first 3 numbers missing on model #)
Posted on Jul 06, 2009
  • 1218 Answers
SOURCE: dryer runs...timer wont rotate and wont heat up
Good day,
Timer woun't run if there is n heat.
1. Check to see you are getting 230 volts to the machine. The motor uses only 115 so is not a good indication.
2. Remove back cover. You will need an ohm meter to test the components.
A. In the center bottom is a skinny white bakelite device held on with one screw. Remove one wire and check. It should check zero ohms. If not replace.
B. On the bottom right is a canister with the heating element terminals sticking out. They should test at 30 or less ohms. If not replace the heating element.
C. There are about 3 other limit thermostats in the area you're working. They should all check at zero ohms. Replace as needed.
Below is a tutorial on changing a heating element.
http://www.applianceaid.com/wp_element.html
Posted on Mar 02, 2010
SOURCE: Kenmore HE Dryer not blowing hot air
I have a gas kenmore dryer... the drum runs- it blows air and for just a few minutes warm air but after a few minutes the air is cold. I have cleaned the vent checked it good. I didn't see the fuse on the back I have the bottom latch open and see several wires that can be disconnected; snap together.
Posted on Mar 18, 2010
Kenmore combo not heating, tested a lot of stuff no luck yet.
Have you checked the relay switch. It is located under the top. It is about the shape of 8quarters stacked up . Remove the wires and bound together and if it works then then replace it. It is crucial in preventing a potential fire. It blows when there is too much current or it gets too hot. This leads to another issue, make sure you have the vent pipe clear and that the motor turning the drum is turning freely. All this builds up heat and electrical resistance.
Mar 13, 2013 | Dryers
Our Intermatic clock operated switch Model T25/16FMD works and then stops. It is hanging up on something. You can spin it but it does not turn on and off the landscape lights. Any thoughts?
Replace timer.
Copy following link to identify timer
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#KM
If analog timer starts hanging, then motor is probably getting weak.
Use air pressure and blow out timer while rotating timer dial.
Turn power off and spay bit of highly flammable vapor from WD40 can while rotating timer dial.
Timers generally have 1 year limited warranty.
Replace timer.
http://waterheatertimer.org/How-to-wire-timers.html
Nov 17, 2012 | Intermatic Grasslin KM2ST-2D Timer, 2 Gang...
Mar 10, 2010 | Kenmore 63942 Dryer
Dryer not blowing hot air- timer not working
im assuming your on the automatic cycle. on this cycle the timer will not advance without heat. check you house circuit breaker/fuse. if one goes the unit will run but will not heat.
Feb 08, 2010 | Dryers
TEDX640PQ1 dryer, timer no longer times and heat does not come on. dryer will spin and blow cool air forever
HI. The timer is the principal initiator off all functions. If the timer module dose not time, or rotate properly, this will signal that the timer mechanism has failed. The timer will need to be replaced in this case. The motor is damaged.
Once the timer is replaced, the heat will return as well.
Oct 23, 2009 | Dryers
Frigidaire gas dryer trouble shooting gas dryer taking too long t
Check the fins on the fan impeller. They may be covered in lint or not spinning adequately.
Mar 05, 2017 | Frigidaire FGQ332ES Gas Dryer
you either have bad element or bad thermo disk or thermo fuse
Jul 01, 2009 | Kenmore 63942 Dryer
Maytag model# LDE482 electric dryer won't blow hot air
Either the control panel is defective or the dryer heating element is defective.
Jun 28, 2017 | Maytag Dryers
Dryer working but not blowing hot air
it sound like the heating element. look to see if it is broken
May 08, 2009 | Bosch Dryers
Mytag Dryer ModelLdg4000Aw
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
Jul 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Dryers Logo
Top Dryers Experts
