Question about Philips Audio Players & Recorders
I have a Phillips gogear aria MP3 player. It originally worked OK. After about a week, the play button no longer worked. I used the reset button, but that did not help. The device manager from the CD said that repairs were needed and then repaired it. The play button worked for a few minutes than stopped again. I repeated the repair procedure, and the same thing happened. I then returned the player and got a replacement yesterday. It worked OK yesterday, but today the play button on the new player stopped working. What do you suggest? Don McGrew
    Top Expert:
  • Philips Master
  • 77,499 Answers
Time for anew MP3 player.
Posted on May 01, 2017
ThaMp3Doctor
  • 8596 Answers
SOURCE: Phillips Gogear SA5285/37 is frozen
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Posted on Mar 18, 2009
  • 24 Answers
SOURCE: why cant i get device manager for my gogear aria
device manager
Posted on Jul 15, 2009
CRTN
  • 716 Answers
SOURCE: Where can I download Phillips GoGear device
Click Here Its A Guide On How To Get It To Get It To Work.
If That Doesn't Help Let Me Know.
Sincerely,
Michael Scott
Posted on Jul 23, 2009
SOURCE: Creating Playlists for GoGear Aria 8gb player
If you want to make a new playlist for your 8 gig GoGear Aria, all you have to do is highlight the songs you want to add, then right click the mouse and choose create playlist. Name the new playlist then cut and paste it into "Playlist" in the music choices and there you go. No WMP needed.
Posted on Apr 10, 2010
  • 519 Answers
SOURCE: ive tried to download video into my gogear aria
for you are not convert the format of your video.
you can choose Video Download Studio as your tool.
you can get the free version in http://www.asharer.com/
Posted on Apr 24, 2010
I have a phillips go gear MP3 player and when i turn it on it freezes only the words www.phillips/welcome.com screens shows. how to i fix this?
Hello
Your GoGear is freezing because there is an error in the operating system and can be fixed by resetting the device. Resetting the GoGear is similar to rebooting your computer. You will not lose any of the data uploaded to the device. To reset the GoGear, press the "Reset" button located on the left of the device. The screen will go blank for a few seconds and then turn back on.
If the GoGear freezes after uploading a file to the device or if one song or sound file freezes the device each time you play it, the file is likely corrupt and needs to be removed from the GoGear. Connect the GoGear to a computer and delete the file from the device.
Sep 02, 2010 | Philips SA3025/37 Flash MP3 Player
MP3 is not syncing
try pressing the reset button on the back you may need a pin or tooth pick because it is very small it should work then
Apr 22, 2010 | Philips GoGear Ariaz MP3 Player
My Phillips GoGear 16GB won't come on.
I have a phillips go gear 8 MGB.numbers on inside of mp3 is 4901v3.68 and sstm12 080929 . I have tried reset & charging it but nothing will make it turn on. I spent alot of money on this thing for it to work a short period of time.What can I do???????????
Apr 14, 2010 | Philips GOGEAR SA6045 MP3 Player
My 16 gb gogear froze
1 On your computer, select Start >
Programs > Philips Digital Audio Player
> Aria Device Manager > Philips Device
Manager to launch the Philips Device
Manager.
2 Turn off GoGear Aria before you
continue.
3 Press and hold the volume button
while you connect GoGear Aria to your
computer.
4 Keep holding the key until the Philips
Device Manager acknowledges GoGear
Aria and enters the recovery mode.
5 On the computer, click the Repair
button and follow the instructions of the
Philips Device Manager to complete the
recovery process.
6 When the recovery is completed,
disconnect GoGear Aria from your
computer.
7 Restart GoGear Aria.
The full manual is found here: http://www.p4c.philips.com/files/s/sa1ara16k_17/sa1ara16k_17_dfu_aen.pdf
Oct 29, 2009 | Audio Players & Recorders
Aug 18, 2009 | Philips GOGEAR SA6045 MP3 Player
Phillips gogear sa6185
-Tha Mp3 Doctor
Oct 24, 2008 | Philips GoGear HDD075/17 MP3 Player
player says i should not connect and then that detachment is ok.
Oct 22, 2008 | Philips GOGEAR SA6045 MP3 Player
Phillips go gear SA5125 mp3 player
Make sure you are using the original USB cable that came supplied with the GoGear, and then try the volume + method again. If the volume + method doesn't work, then there is a problem with the USB port recognziing the device being plugged in - or, the player was physically damaged.
May 29, 2008 | Philips SA5125/37 MP3 Player
Phillips 2GB mp3
Make sure you got the one with GoGear docking station instead of the one with Ipod Docking Station.
Here's how to fix the player:
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Dec 26, 2007 | Philips SA5125/37 MP3 Player
403 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
