My cannon bjc-2100 printer sends an error message "paper jam" but no paper is jammed. won't print anything. can this be solved?
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Paper goes in crooked and won't go down into the printer to print. This is a Cannon bjc-2100.
In most cases there is an obstruction in the paper path causing this. Sometimes by lifting the printer upside down and shaking it can remove the obstruction. If this does,nt work get a torch and look down into the paper path and see if you can see anything foreign.
I have also dislodged the objet by using a A4 cardboard ( folio ) and feeding it back in from the inside of the printer to where the paper usually sits.
I have found hundreds of varied objects that have dropped into printers.
Jul 17, 2011 | Office Equipment & Supplies
Cannon Ip4300 - Orange light flashes on printer.
A possible paper jam has happen on the unit. Did you have an paper jam error before you have this problem?
You must clear any paper jam on the unit, check the unit for any stuck paper or object or check if there was misaligned parts inside.
Let me know for any clarifications.
Thank you for using fixya.
micro-
Dec 12, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
I have a cannon printer bjc 2100. It is printing
After replacing ink cartridges, you generally have to perform an alignment routine. On some printers, they have an automatic alignment function, others require the printing out of one or two sheets of paper and a possible adjustment via the service section of your printer software. If this isn't done, you can have an output similar to that you describe.
Oct 24, 2009 | Office Equipment & Supplies
Paper jam(Canon BJC 3000)
Try to open the printer cover and look for tiny paper shreds that might got stuck between the rollers. Also if your printer has a sensor, there could also be a tiny piece of paper blocking it, thus sensing a paper jam.
Aug 31, 2009 | Canon BJC 3000 InkJet Printer
Printer erroneously reports a paper jam
Perform a hard reset of printer and see if that clears up the situation. Also uninstall and reinstall drivers.
Sep 04, 2017 | Office Equipment & Supplies
Printer bjc 2100 problem
Sorry for late answer.
First reset your printer by unplugging the power cable for a couple of minutes.
Open the printer and check for paper stuck inside, check also for lost foreign objects inside the printer (eg small screw) by turning it upside down.
Try also moving gently the printer head (cartridge slot) on the rail.
If after this you still get the error message then you probably damaged some mechanics inside the printer, in this case you will need to have printer serviced.
Apr 16, 2008 | Canon BJC 2100 InkJet Printer
Cannon copier pc940 paper jam
canon i960 -three flashing orange lights (paper jam error) but no paper is jammed. The print cartridge1.gif will not slide to center either-- I have tried to get the printer into service mode, but cannot get there because the orange lights never stop flashing.
Dec 06, 2007 | Cannon Canon i960 Photo Printer
49 people viewed this question
k24674
jasbo
jasbo
