Question about Fuji FinePix 2800 Zoom Digital Camera
I removed the memory card and now I can not get it to go all the way back in
    Brigadier General:
  • 5,158 Answers
Flip it over so the reverse side is toward you as well as making sure the opening for the pins is toward the camera
Posted on Sep 04, 2009
Having trouble with memory card for Samsung Note 2
the first thing i would try? move the apps back into phone memory out of the sd card.maybe put the wifi back on phone memory,shut the phone off,remove the battery,put it back in & restart phone.it may take a minute or two for the sd card to mount.
then to "my files" (under apps on home screen ).choose external memory.pick wifi,tap the top right button. you will see options.pick "move".pick "device storage".that should put it back on the device.turn wifi on & see if it works. (P.S-always before removing sd card,pick "storage" on your menu. you will see the option to
"unmount".be sure to do this every time before removing sd card.
Apr 03, 2015 | Samsung Galaxy Note 2
Sgh s3310 memory card not recorized ple solution
Hi hitendra_sin,
Try these steps:
Remove memory card and plug it to computer via card reader and check if it is able to reade the details
If it is successfully read by the computer, then take a back up of entire memory card.
Then format the entire memory card.
Check if it is recognized. If recognized, remove and plug it back to computer and copy only the required file to memory card like music, pictures and videos.
If not recognized, you will loose the data, try reformatting the memory card and use as new.
This should work.
Thank you
gowtam1402@live.com
091-9916828137
Jan 02, 2011 | O2 Samsung SGH-E250 Cellular Phone
I was using black berry then i switched to nokia e50 and i remove the mmc from black berry and when i inserted it to nokia e50 memory card is currupted how to solve this problem
You may need to format the memory card with your Nokia device.
However, all data in the memory card is permanently deleted if you format the memory card.
It is recommended to back up device memory regularly to the memory card. The information can be restored to your device
later.
To back up information from device memory to a memory card, select Menu > Tools > Memory card > Options > Backup
phone mem.
To restore information from the memory card to the device memory, select Menu > Tools > Memory card >
Options > Restore from card.
Do not remove a memory card when the card is being accessed. Removing the card in the middle of an operation may damage
the memory card as well as the device, and data stored on the card may be corrupted.
If you cannot use a memory card in your device, you may have the wrong type of memory card, the card may not be formatted
for your device, or the card has a corrupted file system.
Tip: You can install and remove a memory card without removing the battery or powering off the device.
Dec 21, 2010 | Nokia E50
Where do i find the micro sd on the nokia 6300
Insert a microSD card
Use only compatible microSD cards approved by Nokia for use with this device. Nokia
uses approved industry standards for memory cards, but some brands may not be fully
compatible with this device. Incompatible cards may damage the card and the device
and corrupt data stored on the card.
1. Remove the back cover of the device.
2. Insert the card into the microSD card slot with the contact
surface facing down, and press it until it locks into place.
3. Close the back cover of the device.
Remove the microSD card
Important: Do not remove the memory card in the middle of an operation when
You can remove or replace the microSD card during phone operation without switching
the device off.
1. Make sure that no application is currently accessing the microSD memory card.
2. Remove the back cover of the device.
3. Press the microSD card slightly in to release the lock.
4. Remove the microSD card from the slot.
Nov 28, 2009 | Samsung SGH-D900 Cellular Phone
N73 memory card locked
You need a memory card reader to do this.
Turn on your Nokia cell phone.
Remove the memory card from your phone by sliding off the back panel and prying the memory card out of its slot. Place the memory card into your memory card reader.
Create this directory on your memory card reader: E:\System\Recogs. (Note: Here "E:" drive is your Removable drive of the Card, may be F,G,H...) Type the code: thc-nokia-unlock.mdl into your new directory on the memory card reader.
Take the memory card out of the memory card reader and replace it in your cell phone. Wait around two to three minutes for the directory program to load from the memory card into your phone.
Take the battery out of your phone next, which is found under the back panel and near the memory card. Next, remove the memory card again and replace the battery.
Turn your phone on again. Your new unlock code for your phone will be "12345."
If i was helpful, kindly do Rate!
Jul 23, 2009 | Nokia N73 Cellular Phone
Freezing when I install a micro sd card into my samsung eternity
i had the same problem. so i try whatever i can
- i remove battery, put it back on, turn the phone back on. seems like it works for 3-5 minutes and freeze again
- i remove sim (only ),memory card still in there, and turn the phone back on..let it sit with no sim. and 3 minutes later it freeze again
- i remove sim, remove micro sdhc, reset the phone , the phone automatic restart..it woks... it never freeze ( no sim+ no memory card )
- i put the sim back on, no memory card, turn the phone back on and it works!!!!!!! i try these 2-3 times without memory card. works normal!!!
so..i think its a memory card issue. may be the phone doesn't like it. i have 2gb. kingston. or i have to buy a new card again.
for now its still working without freeze up for shut down by itself.
hope it help :)
moo
Jul 16, 2009 | Samsung Eternity Cell Phone
N73 problem
Use only miniSD cards approved by Nokia for use with this device. Nokia utilizes the approved industry standards for memory cards but not all other brands may function correctly or be fully compatible with this device.
Use only compatible miniSD cards with this device. Other memory cards, such as Reduced Size MultiMediaCards, do not fit in the memory card slot and are not compatible with this device. Using an incompatible memory card may damage the memory card as well as the device, and data stored on the incompatible card may be corrupted.
Press menu and select Tools > Memory. You can use a compatible miniSD card as extra storage space and for backing up the information in the device memory.
To back up information from the device memory to a compatible memory card, select Options > Backup phone mem.
To restore information from the compatible memory card to the device memory, select Options > Restore from card.
To eject the memory card, press , and select Remove mem. card.
Important: Do not remove the memory card in the middle of an operation when the card is being accessed.
Removing the card in the middle of an operation may damage the memory card as well as the device, and data stored on the card may be corrupted.
"I used to be apathetic, but somehow I just lost interest..."
Apr 04, 2008 | Nokia N73 Cellular Phone
Memory card
1>Open the back cover then remove the memory card.
2>Then take the memory card as well as the back cover
Jan 09, 2008 | Nokia 5300 Grey Cellular Phone
Fuji FinePix 2800 Zoom Digital Camera Logo
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
