Question about Karcher 2500 PSI Pressure Washer
Troy bilt pressure washer will not build or reach high pressure
Troy bilt model 020207
rev no - 01
serial - 1010326762
psi - 2450
gpm - 2.0
pressure washer motor runs fine - but will not build high pressure
    Sniper:
  • 61 Answers
Check the non-return valves in the pump block. if these are damaged or dirty you pressure will be greatly reduced. they are located behind the 3 lage brass hexagonal caps.
I hope this helps
Posted on Sep 20, 2009
Troy bilt pressure washer not siphoning soap
clean and soak all valves if do get work do not leave solution in it over time.carb cleaner with that little straw
Oct 19, 2014 | Troy-Bilt XP 3000 PSI 2.7 GPM Gas Pressure...
No high pressure when running
check valves are not working properly or unloader problems
Oct 01, 2014 | Troy-Bilt XP 3000 PSI 2.7 GPM Gas Pressure...
020488 USER MANUAL
Contact Troy-Bilt...
http://troybilt.custhelp.com/
They have a page for Pressure Washers explaining thet tehy do not build their own pressure washers...
http://troybilt.custhelp.com/app/answers/detail/a_id/430
Jul 14, 2014 | Troy-Bilt XP 2800 PSI 2.5 GPM Gas Pressure...
My troy-bilt 20486 pressure washer runs but does not spray water
OK just so we are on the same page.
You did turn on the water (right?)
Jun 12, 2014 | Troy-Bilt 2700 PSI 2.3 GPM Gas Pressure...
My neighbor just gave me a Troy Bilt 020207 power washer. It is 2450 PSI and 2 GPM. He snapped the pull cord rope. I looked at the pull cord cover and it seems to have 3 rivets holding it to the main...
sounds like a briggs engine, DONT remove the rivits, go down a little further and remove the 4 3/8 bolts that hold the blower housing on.Turn it upside down, prewinf the pulley in the direction that it turns when the rope is being pulled. When it stops turning because the spring is tight, let it unwind one turn and line up the hole in the pulley with the hole in the metal part where the rope comes in and slip the rope in, tie a not and melt the freyed end. Let the starter pull the rope in by itself.
Nov 15, 2009 | Briggs & Stratton Garden
Oil for a troy bilt 2550 psi pressure washer pump
What fluid and how much is required in the Troy-Bilt 2550 power washer pump?
May 17, 2009 | Briggs & Stratton Garden
Karcher 2500 PSI Pressure Washer Logo
3,192 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
