Mitsubishi VS-45607 Sometimes the tv will work fine for hours, days or even weeks. Then when you are watching it, it will shut off and wil not come back on. Sometimes it will shut off as soon as you turn it on or after just a couple of minutes. There are days that you can not even get it to turn on.
We have the VS-45607 Mitsubishi and it will shut off on us sometimes in a few seconds, sometimes after a few hours, but it will not come back on. We tried doing the self-diagnosis turn on and holding the input and menu keys down for 5 seconds at a time. We did this several times and it did blink. The TV, however, will still not turn on. Any ideas?We have the VS-45607 Mitsubishi and it will shut off on us sometimes in a few seconds, sometimes after a few hours, but it will not come back on. We tried doing the self-diagnosis turn on and holding the input and menu keys down for 5 seconds at a time. We did this several times and it did blink. The TV, however, will still not turn on. Any ideas?
Sometimes the tv will work fine for hours, days or even weeks. Then when you are watching it, it will shut off and wil not come back on. Sometimes it will shut off as soon as you turn it on or after just a couple of minutes. There are days that you can not even get it to turn on.Sometimes the tv will work fine for hours, days or even weeks. Then when you are watching it, it will shut off and wil not come back on. Sometimes it will shut off as soon as you turn it on or after just a couple of minutes. There are days that you can not even get it to turn on.
You can't post conmments that contain an email address.
The STKs are three channel ICs they each control horizontal and vertical of one color the third channel controls part of green and the other half of green is controled by the other ICs third channel. Its customary for the Ics to fail and only have one channel bad in the IC. However its recomended to change both because of the bad Ic having green it can actually weaken the other IC and that one will fail shortly.
Good Day, rmorales;
Does the buttons on the front panel work properly? I would suspect a bad button assembly.
I hope this helped, good luck, big IRISH.
sounds like a defective cappacitor or leaky diode in the deflection circuits. Unless youre comfortable working around the high voltage circuits of a rear projection set, it may be best to call a reputable repair facility that is famillair with mitsubishi products.
It may cure the problem but I would suspect the 9 Volt source
CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND
IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH
ARE ON THE SIGNAL PCB.
Push the menu and inputs buttons on the set in both together and hold for 8 seconds this should make the led flash a two digit code. Let me know what happens after doing this test.
It could be a bad solder connection that opens up as the set warms up. It could also be caused by a couple of bad capacitors, C2p05 (100uf/16v) Located By Ic2p01 and check C2c52 (10uf/50v) Located near Q2c51. A technican will be able to fix it for about what you paid for it I suppose.
