Question about Vivitek Televison & Video
When I push the power button on the ready and
When I push the power button, the ready and power lights at the front of the t.v randomly blink, and the set doesn't turn on.
  • 1 more comment
  • afloran6 Sep 04, 2009
    It is a Vivitek rear projection HD DLP. Model number is RP51HD41-A
    I know for a fact it is not the bulb because it has recently been changed. If it is the power supply how do i test or check that and exactly where is it located.
    I have another question. Prior to the tv not turning on, while watching the colors blue, green and red would overtake scenery and faces.The colors wouldn't always go to normal quickly (within 5-10 min) and the problem would persist. Could this be caused by an error when the replacement bulb installed, or something else within the set?
  • afloran6 Sep 05, 2009
    Thank you for answering the color question. I will certainly leave the most advanced procedures to technicians. As for the set not turning on, have you heard of this set experiencing similar problems. If so do you know what their issues were.
  • 3,037 Answers
What kind of tv is this? Can you give me the make and model number please.
If it is a projection, then most likely the bulb is burnt out. Otherwise a good spot to start is with the power supply.
Benjamin
Posted on Sep 04, 2009
  • Benjamin Patri
    Benjamin Patri Sep 05, 2009
    Yes the colors could either be the bulb or maybe the light engine is worth checking out which you should leave to an experienced technician if you don't have advanced electronic skills. A bad power supply would most likely not cause color changes
  • Benjamin Patri
    many times a set not turning on is because the protection circuit takes over, which usually takes over when the power supply may be at fault but it really could be anything that is shorting out if this is the case. Generally, it physically must be narrowed down by a technician unless it was giving off an error code, but if they randomly blink and there is no set code, then it could be almost anything. Sorry about not being more helpful
Fisher Paykel DS605i single dishdrawer with a user-supplied integrate panel. There are three buttons on front. The left-hand button is power button; the center button is start/pause; and the right-hand...
Hello, Thank You for using FixYa. I will be helping you today.Are any of the cycle lights lighting up like rinse and normal and is the light on front blinking and pausing if so how many times is it blinking? Try turning the power off too the unit for five minutes and back on, because if the lid was open some or was stuck it can stop the unit from running.
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Jun 29, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
I have a mitsubishi ws-65315. When I go to turn the tv on the green power light comes on and you can hear the tv click on, but seconds later shuts off.
this model has a self check, when green light comes on and then goes off. Push and hold both the Menu and Input buttons on the front of the set for at least 5 seconds and release both.
Power light will blink a two digit error code like 2 blinks 2 blinks, a pause and then repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
Feb 22, 2011 | Mitsubishi WS-65315 65" Rear Projection...
Sony HD Projection TV KDP-57WS550, timer light blinks 5 times and repeats sequence. When power button is pushed sound comes on briefly, no picture, then TV goes off. Please advise.
Mine did this after a power flash. Lights blinking 5 or 6. They blink fast lol. I have sound till tv powers back down. Front yard bond fire? Or any ideas? Thx.
Dec 25, 2010 | Sony Grand WEGA KDP-57WS550 57" Rear...
How do you set the router ?
From the router user manual on page 13 , it says:
9. Reset The "Reset" button is used in rare cases when the Router may function improperly. Resetting the Router will restore the Router's normal operation while maintaining the programmed settings. You can also restore the factory default settings by using the "Reset" button. Use the restore option in instances where you may have forgotten your custom password.
a. Resetting the Router Push and release the "Reset" button. The lights on the Router will momentarily flash. The Power/Ready light will begin to blink. When the Power/Ready light becomes solid again, the reset is complete.
b. Restoring the Factory Defaults Press and hold the "Reset" button for at least 10 seconds, then release it. The lights on the Router will momentarily flash. The "Power/Ready" light will begin to blink. When the "Power/Ready" light becomes solid again, the restore is complete.
Dec 21, 2010 | Belkin My Essential (ME1004-R) Wireless...
Cant get the BELKIN to work
From the manual:
Push and release the “Reset” button. The lights on the
Press and hold the “Reset” button for at least 10 seconds,
Power/Ready light becomes solid again, the restore
is complete.
Feb 12, 2009 | Belkin (F5D5231-4) Router
Dell 1700n Ready/Data light blinking (secondary fault)
Ok, try this--1.power off printer 2. open front door 3. press and hold continue and cancel buttons 4. power back on 5. wait until light sequence stops om error 6. power off and back on.
this resets factory defaults on the printer..
Nov 11, 2008 | Dell 1700n Laser Printer
The printer apear to be dead!
Buttons and lights on the printer Two buttons and three lights are located on the front of an HP Deskjet printer.
  • The lights tell when the printer is working or when it needs attention.
  • The buttons help control the printer.
Buttons and lights Purpose c00123886.jpg POWER button and light Push the POWER button to turn the printer off and on. When lit, the light shows that the printer is turned on. c00123889.jpg RESUME button and light The light blinks when there is a problem with paper. When the problem is corrected, press the button. c00123892.jpg Print cartridge light The light blinks when there is a problem with a print cartridge. When the problem is corrected and the top cover is closed, the light will stop blinking. Troubleshooting blinking printer lights Blinking lights Reason c00123895.jpg
All lights are off. The printer is off (asleep).
Press the POWER buttonc00123886.jpg to turn the printer on.
The printer should turn on automatically when a print job is sent to it. c00123898.jpg
The POWER (top) light is on. The printer is idle.
The POWER (top) light is blinking. The printer is busy printing.
Allow enough time to print. When a document has many fonts or graphics or uses complex color such as a color photo, it takes longer to begin printing. c00123902.jpg
The PRINT CARTRIDGE (bottom) light is blinking. Possible causes:
  • The front cover is open. Make sure the front cover is completely closed.
  • The print cartridge is missing. Make sure the print cartridge has been installed correctly.
  • The print cartridge is broken or incompatible. Lift the front cover, and wait for the print-cartridge cradle to slide out. Check the part numbers on the print cartridge:
Black: 51645A
Color: C1823D,
If the print cartridges are compatible and correctly installed, they may be defective. Try replacing the print cartridges.
If none of the above suggestions fix the problem, and, if the error message still occurs, it may be a hardware failure. Call the HP Customer Support Center.
Jan 20, 2008 | HP DeskJet 710c InkJet Printer
Televison & Video Logo
Top Vivitek Televison & Video Experts
Jim Goldsmith
Jim Goldsmith
matt martin
matt martin
Are you a Vivitek Televison and Video Expert? Answer questions, earn points and help others
