Question about Dell Latitude C400 Notebook
Screen wont show boot screen
When i turn on my lat c400 it starts up but when its time to show boot screen nothing comes up ?
  • tilden nash Dec 08, 2007
    can i get some help please
    i tried that but nothing
    Sergeant:
    Champion:
  • 270 Answers
Fo to bios options by pressing f2 or del soon the power button is released. thre u can find an option to enable silent boot . turn it on
Posted on Dec 08, 2007
My Del Latitude C400 screen will not work how do i plug in an external monitor
connect to external monitor with 15pin connector. and there is one function key is there with symbol of monitor. at the time of booting presss that key external display will come
Jun 16, 2010 | Dell Latitude C400 Notebook
Wont boot on its own, wont boot with install disc,
As the hard disk appears to be showing up when you boot up using the install disc, I would suspect that the system is somewhat corrupted. You could reinstall the system again and if you are happy starting from scratch and wiping the hard drive select this option failing that and there is some data on the imac you could install using the preserve user data. A fresh install should sort out any problems. Hope this helps.
May 18, 2010 | Apple 20" iMac Desktop
Cant install xp to dell c400 with external cd-rom
This is how I did it, you may or may not have the ability. A basic knowledge of Dos is necessary 1) I used another laptop but you could use an adapter to use the hard drive in a regular computer. 2)boot with a windows 98 boot disk, fdisk it to a fat32 partition, make the hard drive a system boot disk (format /s c:) 3) copy the i386 folder and all its contents from a full or full oem (not branded) disk to the laptop drive, also copy smartdrv and highmem.sys from the floppy (speeds thing up dramatically) and create a config.sys file with device=highmem.sys 4)physically install the hard drive back into the C400, boot to dos run smartdrv.exe, then go to the i386 folder and type winnt.exe (enter) wooo should work. MusslaChooda Pakichooda Nathuram Godse
Oct 22, 2008 | Dell Latitude C400 Notebook
Won't boot from new hard drive
simple prombelm of this is this computer wasn't made to start from xp ,it need start from a ealier system like windows 95/98 see the 386 file is prombally missing that why it wont boot up. lala linda
Oct 15, 2008 | Dell Latitude C400 Notebook
Getting out of the initial set up
First try to Boot to Last Known Good Configuration.. do this by pressing F8 upon bootup...look at the prompt screen for the option mentioned OR
Attempt to boot up in Safe Mode....
Do This by pressing F8 Upon bootup, it will take you to a black Safe Mode Options screen... once there choose the first option.. boot into Safe Mode Only.. If you are able to boot into windows that way,, you can then check for problems... Like checking the device manager for errors, Check the Status of your hard drive.. etc.
Jun 04, 2008 | Dell Latitude C400 Notebook
Dell C400 Resolution Problem
Boot into BIOS and go to the Video card setting, that sould fix it
Jan 26, 2008 | Dell Latitude C400 Notebook
Lat c400
you've probably set the screen resolution on your OS to high, connect an external screen, change it to some lower resolution, and retry
Dec 08, 2007 | Dell Latitude C400 Notebook
Dell C400 will not boot using LCD screen when cold
I have seen this problem before, after booting to the external monitor go into the display settings and try setting the resolution to 1024 X 768 and the color settng to 16 bit or preferably 32 bit. If you can do this, then shut down the laptop remove the external monitor and try booting on the LCD display. BPCS
Nov 17, 2007 | Dell Latitude C400 Notebook
Dell latitude C400 will not boot from hard drive.
Hi, This sounds like a dead hard drive. Still, you may want to try: 1. Enter your CMOS/BIOS and verify that your laptop can detect the hard drive. Further check if it is configured to boot first from the HD; 2. Slip in your XP or Recovery CD and boot from that. It may be that the boot section/files of your HD got messed up. When prompted, instruct the CD to repair; 3. Remove your laptop's HD and connect it to a 2nd PC as an external/removable drive using a 2.5 enclusore with USB attachment. Thereafter proceed to diagnose, check and hopefully recover your important files; 4. If confirmed of a defective HD, replace and reinstall your OS. Hope this be of some help/idea. Post back how things turned up or should you need further information. Good luck and kind regards.
Sep 29, 2007 | Dell Latitude C400 Notebook
Dell Latitude C400 Notebook Logo
196 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
