Question about Kenmore 53542 / 53544 Side by Side Refrigerator
Smelt burning smell in the morning stopped cooling
Right now fridge and freezer is about 50 to 60 degrees this morning was fine about 6 am smelt a burning electrical smell . Noon time freezer was leaking water everywhere . by 4pm fridge was at about 50 degrees. any one have any ideas.
  • 135 Answers
I suspect the start relay burnt on the compressor. Now the compressor can not turn on. You need to repalce the relay.
Posted on Sep 05, 2009
Car dashboard lights wont turn on and smell of burning wires
If you're smelling insulation burning - STOP. Fuses should be blowing before insulation melts / burns.
Have the car checked my a trusted mechanic before using anything in the car that makes the wiring burn or melt.
Apr 16, 2014 | 2001 Ford Taurus
Burning electrical smell, refrigerator hot at lt side (freezer side) and at center area between doors
When you smelt this was the fan in freezer off? If so it is most likely in defrost mode and the smell is from frost melting and hitting the heater in the freezer. The hot on the sides and in the center. Is this outside the box? If so this is normal. There are coils inside the frame of a fridge that stay warm to eliminate condensation. Sometimes they shift and get too close to the wall and thats what you are feeling.
If you have any further questions please feel free to contact.
Jul 27, 2011 | LG LSC26905TT Side by Side Refrigerator
At first i smelt a burning smell then found the fuse had blown,i replaced the fuse and worked for a while then the motor was geting hot and the fridge wouldnt stay cold
it means your compressor hi pressure cause of blown fuse check the condenser fan if running ok if not replace capacitor or lubricate main shaft. then observe your comp. if working continues.
Feb 19, 2011 | Engel 43 Qt.Portable Freezer.
Freezer quit working. smelt a burning smell yesterday
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 21, 2010 | Frigidaire FRS3R5EMB Side by Side...
Describe your Kenmore 53652 / 53654 / 53659 Side by Side Refrigerator Unit is not cooling. Stopped working after power outage
Kenmore Coldspot 106.53652300
I just fixed my neighbors fridge that suffered from a power surge. She explained that she smelt a burning smell in the kitchen and the next day the fridge and freezer were not cold. Of course she did not share the burnt smell part until after I discovered the starter relay and the capacitor were burnt on the compressor. She purchased the new starter kit and capacitor from a local supply company and while installing them I discovered the compressor fan was not running which also meant the compressor was not getting any power. I removed the screws that held the control panel on the fridge side (right side) and inspected the circuit board which I discovered a burnt trace on the board for the compressor control relay. I fixed the board by soldering a piece of solid core wire across it and it works great!
Make sure you shop around for your parts. The BIG local supplier here in Tulsa wanted $65 for the starter kit and $65 for the capacitor. We shopped around and found another supplier in Tulsa that sold them for $25 each and they were FSP parts!
Dec 15, 2009 | Kenmore 53652 / 53654 / 53659 Side by Side...
1997 nissan Pathfinder once warm rpms drop when
The sweet smell is your engine coolant,check for a leak under the hood,look for green fluid,Have your catalyst checked,for the other problems,and your fuel presure checked,or change the fuel filter.Either of these should help a little.
Jul 22, 2009 | 1997 Nissan Pathfinder
I heard lots of clicking, smelt a vague burning smell, then machine stopped
IT SOUNDS LIKE A PROBLEM WITH THE MOTOR,WIRING, OR TIMER. SOMETIMES THE TIMER MOTOR WILL START CLICKING AFTER IT GETS SOME AGE ON IT. IT IS UNUSUAL FOR THAT TO CAUSE YOUR PROBLEM. THE SLIGHT BURNING SMELL COULD BE THE MOTOR. IT MIGHT HAVE TRIPPED THE OVERLOAD ON THE MOTOR FROM GETTING TOO HOT. AFTER IT HAS COOLED AWHILE, THE OVERLOAD SHOULD RESET ITSELF. YOU MAY WANT TO ADVANCE THE TIMER TO SPIN AND SEE IF IT WILL RUN NOW.
SOME RETAILERS OFFER NO CHARGE ON THE SERVICE CALL IF YOU END UP BUYING A NEW REPLACEMENT APPLIANCE FROM THEM. ASK AROUND.
IF YOU GET THAT DEAL, IT'S TO YOUR ADVANTAGE TO CALL FOR SERVICE. IF HE FIXES IT, YOU HAVE YOUR WASHER READY TO GO, IF NOT, AND YOU BUY A NEW ONE FROM THAT RETAILER, NO CHARGE FOR THE SERVICE CALL.
Apr 04, 2008 | Maytag MAV6300 Top Load Washer
Burning Smell
sounds like the motor is fried or seized up, which would explain that smell.
Feb 17, 2008 | Refrigerators
Kenmore 53542 / 53544 Side by Side Refrigerator Logo
346 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
