Amana Temp assure 2 heat pump- previously would buzz a couple times at about 30 second intervals before the compressor would turn on. Went to turn on the central air today and and the compressor will not kick in.
    Problem Solver:
  • 10 Answers
COULD BE A DIRTY CONTACT OR CHECK UNIT FOR ANT BED AT THE BOTTOM OF YOUR UNIT THEY LOVE TO GET IN THOSE CONTACTERS
Posted on Sep 04, 2009
Click buzzing and click coming from unit mounted to the compressor every couple of minutes. freezer not cold enough. Runs constantly.
Often replacing the temp relay and current relay on the compressor will solve the issue. You can buy what is called a 2 in 1 compressor control... easy to install and inexpensive. It just may work!
Jul 28, 2014 | Amana Refrigerators
4 ton Amana -heat comes on sporadic in spring and fall (Every season change) Heat worked through 20 degree weather. Thermostat at 74. Today is 100% humidity and 52 degrees outside and heat won't work. By...
Assuming this is a heat pump I'm guessing you have a bad temp sensor. Your outdoor fan is likely controlled by a temp sensor so it only runs as needed during heating. Fan not coming on and compressor still needs cooled therefore compressor protection kicking in?????
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Aug 12, 2017 | Amana Heating & Cooling
Had 16 xi Trane heat pump installed 3 years ago. It ran well for the first couple of years. It began to stop heating and would blow cold air only. Have tried both aux heat and reg. heat to run and neither...
That's a complicated system that needs a qualified technician to service it. Lots of people can install them and they run fine, for a few years. Your indoor unit, operating on 2 heat elements, will feel like its blowing cold air even though its heating, just not so well. And not like you are accustomed to. Each element (5kw)=22.7amps, on average. So 3 elements operating should trip a breaker. Its probably been operating on 2 heat element plus the heat pump. And now you have trouble with the heat pump. If you can't TRUST the guys working on your equipment, try someone else. A second opinion. Normally a 3 or 4 ton unit will have 15kw heat installed, heatpump or not. 5 ton, 20kw. If yours is a 3-4ton, cooling, the 100amp(or normally two 60 amp) breaker should have been installed upon equipment change out. If yours is blowing cold all the time, something is wrong with your heatpump. The electric heat inside operates only when the heatpump can't keep up(real cold outside), the heatpump is in defrost(then it's actually in cooling mode), or if you have the tstat in aux/em. heat. Try a local trane dealer? Of a technician with 15-20 yrs under their belt. A trane dealer should have trane tech support also. BIG HELP!!!
Mar 01, 2017 | Haier Energy Star ESA3183 Air Conditioner
My goodman heat pump makes a load buzzing noise when it starts
Does the buzzing stop after 30-60 seconds of running or does it continue?
Nov 04, 2013 | Amana PTH123B25AJ Heat Pump Air...
Amana ABB222DE is the overload/capacitor the same thing as the compressor relay? I just had the compressor relay replaced in amana bottom mount. Frig cools fine but every 2 days or so buzzing noise...
I have been doing refrigeration for over 30 years and I have never seen a compressor with a chip inside of it. Have you tried cleaning the condensor coils? I almost sounds like you have a weak start capacitor. Let me know if i can help you any futher.
Apr 24, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Amana Temp Assure bottom freezer model BB120TW---about 10yrs old; ice forming throughout freezer: refrigerator works fine. Diane Curry
I am having a similiar problem. How is your seal - check the gasket and see if there is any separation from the door where air could get in. I had our gasket replaced several years ago but the door was not level and the seal pulled away from the freezer in the upper left corner allowing air to get in and make snow in the unit. Now the compressor has trouble kicking on after the auto defrost. We hear an electric buzzing sound every 20 seconds or so. Fans run but the unit doesn't cool. If we pull it out and unplug, wait and plug back in it usually starts back up. I have read that rather than replacing the whole compressor we may be able to just replace the relay,overload and run capacitor assembly - looking into that now...
Sep 29, 2010 | Amana Refrigerators
I have an Amana SxS (model DRS2663B) that is about 8 years old. About a week ago, it started making a sound - kind of a buzz coming from the compressor area (or the little box I identified as a...
You may have a bad relay/overload part number 12555902 runs about $15 but if the compressor is going bad it may not work.If you take the relay/overload off  turn it into your hand and shake it if you it sprinkles out like a pepper shaker go with the OEM part afore mentioned,but if it sounds solid and nothing comes out go with a hard start(SUPCO RC0410 also about $15) it will buy you at least another couple years in which to shop around for a replacement or save the money for a new compressor.You can call Amana to check on the warranty but most only had five years on sealed system.
Sep 27, 2009 | Amana DRS2663B Side by Side Refrigerator
Buzzing sound for about 2 months
Compressor was replaced (also see additional comments made).
Mar 20, 2008 | Amana ABD2533DEW / ABD2533DEB / ABD2533DEQ...
Problem with RSKP 0006 control board
If the unit has an outdoor thermostat, this turns the aux. heat on very cold days. It may need to be replaced, or removed completely, if its kicking over to soon before it gets that cold. If its set to turn on the electric at 30 degrees, then its working the right way. Also, look for different temp. setting on the board you lust installed, there should be some sort of adjustment options on it. Especially if there is no thermostat outside.
Feb 28, 2008 | Amana PTH123B25AJ Heat Pump Air...
Goodman Condenser - Heat - Buzzing Noise every 60 seconds
It could be your compressor trying to start but not being able to do so. It shouldnt happen that often but in cold temp the overload protector may cycle that quickly. I reccomemnd to have it checked to salvage the expensive compressor.
Dec 24, 2007 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
200 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
