Question about Dell InspironTM 1501 Notebook
Dell screen goes black , after 2 seconds but when low down the brightness it work good it not goes off , but it is very low brightness and difficult to read text some time ,
  • Mohtashim Khan Sep 05, 2009
    hi Guru
    Problem is with the LCD screen ,when i start my laptop it gives Dell logo and after windows logo suddenly It just goes to black after, every thing is working properly , then i check it with external monitor it works fine i saw my desktop on external monitor.
    After a few servery on net i found that if i low my LCD brightness then my LCD will not goes to black , and i did that it works! but the problem is it become too difficult to read in low brightness and if i increase the brightness then the LCD screen again goes to black ! now propose me a solution for it if you have an idea
    Thanks
  • Dell Master
  • 32,281 Answers
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Posted on Sep 04, 2009
Testimonial: "thank you so much "
  • Chris Hingee
    Chris Hingee Sep 05, 2009
    The problem appears to be a backlight problem, It still be an inverter problem, it may not be able to supply enough voltage at a high brightness setting or it could be a faulty CCFL lamp.
    A new inverter id approx. $40 and is easy to swap out, I would try this first. The CCFL lamp is approx. $10 but it is more work to replace.
    Guru:
  • 417 Answers
But when low down the brightness it work good it not goes off , but it is very low brightness and difficult to read text some time......WHAT?
Can you explain in a bit more detail please...I don't know what you mean by.........
'when low down the brightness it work good'?
But try holding down the FN key on your keyboard & tapping the Dell screen goes black , after 2 seconds but when - 5fc1ca0.png Button that alters the brightness.
  • T-Comtech Repairs
    T-Comtech Repairs Sep 05, 2009
    if your still up call me on my land line 01228 523603 just wanna check one thing have your laptop next to you.
How to reduce brightness of dell vostro 1015
not sure if this will help you...
  1. Bright LCD displays under low-light conditions can strain the eyes. ...
  2. Hold the "Fn" key and press the up or down arrows to increase or reduce brightness on most Dell laptops. ...
  3. Right-click the power icon in your Windows 7 system tray and select "Adjust Screen Brightness."
How to Adjust Dell Laptop Screen Brightness ' Chron.com
smallbusiness.chron.com/adjust-dell-laptop-screen-brightness-53143.html...or try this link. How to reduce brightness of dell vostro 1015 Google Search
Oct 21, 2017 | Dell Computers & Internet
Dell Inspirion 546 screen keeps going black
It sounds like a hardware fault, does it happen when the laptop is cold or does it start to go faulty after its been on a while, if it goes faulty after its been on a while, its more than likely that the fan cooler is all blocked up with dust, and will need to be cleaned. Hope this helps.
Nov 25, 2016 | Dell Computers & Internet
Whenever my Dell Precision M6300 is ever on maximum brightness, the backlight goes dark after 1-2 seconds. The screen is fully functional, but the backlight simply isn't working. I can get the backlight to...
guess there is an larger issue with your notebook.....
you need to get the backlite changed, if you have chanaged the lite then there is a compatibility issue with the screen and the invertor board that's behind the LCD screen.
or the system is not supplying the correct current to the backlite / invertor board
a HW tech guy may solve your issue
Nov 18, 2010 | Dell Precision M6300 Mobile Notebook
Screen goes blank after 2 seconds
hold a bright flash light to the screen after it goes black if you can see the words through the glass ... That means the back light is bad...or the power supply feeding it. it will be cheaper to buy a new one. if thats the problem.
Aug 11, 2010 | Dell UltraSharp 1907FP 19" LCD Monitor
Screen Black but Working
It goes black because it went into shutdown due to fault in the inverter circuits, check the 4 transistors in the inverter circuits for shorts, http://s807.photobucket.com/albums/yy352/budm/Dell%20E173FPb/
Feb 14, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Screen Too Bright
Do a factory reset on All Settings:
http://support.dell.com/support/edocs/monitors/se197FP/EN/ug/setup.htm#Using_the_OSD
Dec 06, 2009 | Dell SE197FP 19 inch LCD Monitor
My dell e1404 laptop is having a issue with the screen. When you turn on the computer the screen will come on for about 30 seconds and then go off. When it's on everything looks normal. once it goes out...
The inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. The inverter board converts low voltage DC power (few volts) supplied by the motherboard to high voltage AC power (few hundred volts) needed for the backlight lamp.
When the inverter board works properly, the backlight lamp gets power and the LCD screen lights up. As a result, the image on the screen is bright. If the screen is dimming down, means that the inverter is failing in it;s job to supply the needed voltage to the Backlight.
The Inverter is mounted underneath the display screen and is connected by a two wire plug.
Nov 07, 2009 | Dell Inspiron E1405 Notebook
I have a Dell 1707fp monitor. When I power the monitor on it powers on normally. After a few miniutes, even though the power button is still green the display goes blank. I have tested this on other known...
I just fixed my for less then 1 minute. Here was the problem, when turn on the PC with the monitor connected. The screen appear like normal for about 2 seconds then shut off black but the GREEN power LED stay on, if i press the power off and turn it back on the screen act the same thing.
Here how to fix it, turn off the PC, unplug the monitor power cable then plug it back. The power LED will stay amber. Hold down both brights minus - and plus + same time, turn on the PC, keep hold the - and + buttons press the power button turn on the monitor.
You will see the screen back on, just hold for about 10 more seconds till you see the screen seem to stay on fine then realse them. That's it how i fixed my.....GOOD LUCK
Oct 27, 2009 | Dell E173FP 17" LCD Monitor
Black Screen at full brightness
It sounds like your backlight or inverter is failing, and soon you won't be able to see a picture on any setting. This is common for LCD screens over time, they start out with the occasional blackout and then progressively get worse. You can take it to be repaired, but the cost severely outweighs the cost of purchasing a new laptop.
Sep 16, 2009 | Dell InspironTM 1501 Notebook
L13V36 Dark Screen, picture can be seen in bright light.
If the backlight lights up for a second it's probably fine - It lay odds on the display inverter in the screen. Actually finding parts for anything made by gateway may be difficult, however. They do not sell spare parts. Considering the size of the LCD i bet it would almost exceed the replacement cost of the screen to repair it
Dec 30, 2007 | Gateway FPD1960 19" Flat Panel LCD Monitor
Dell InspironTM 1501 Notebook Logo
1,153 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
