Question about Pioneer DV-F07 DVD Player
Door won't open and turntable does not turn
Brand new unit. Neither the door nor the turntable functions. The internal blue light simply blinks. The unit acts as if a locking pin is preventing operation but there is none.
  • rello Dec 12, 2007
    My unit was working fine, then I did an "auto update" where it reads all the disks and updates the names for the display. It is supposed to shut off after finished. Now the turntable does not spin at all. The door does open and close however. I tried everthing.
  • joey246 Jun 07, 2008
    The turntable is locked. Will not spin.
    Problem Solver:
  • 4 Answers
Unfortunately you may have to reset the unit. This will cause you to lose everything saved in memory so make sure its not just a DVD stuck in the mechanism. To reset to factory default turn unit off then press and hold Stop and press Standby/On
Posted on Nov 13, 2008
My microwave has stopped working. Everything functions properly, including the light when the door is open, and the timer countdown begins when I press start, but the actual unit will not turn on...
Sounds like a bad magnatron (the part that emits microwave energy) or maybe just a bad door switch. If the door switch is bad it won't let the unit come on.
Feb 19, 2015 | In Microwave Ovens
Why does Panasonic nn-sn651 usually work; but sometimes, turntable won't start ?
This is an inverter model so there is no diode or hv capacitor.
You must adt. the door latch switch assembly to make sure that the door hooks make contact with the switches. Common problem is that the assembly is bent and must be perpendicular to the door.If it is bent the switch will not make contact with the door hooks.
Place a dab of lithium grease on the tip of the door hooks to ease closing the door. This is the cause of the bent switch assembly!
Aug 31, 2014 | Panasonic 1.2 Cu. Ft. Mid-Size Microwave -...
GE Profile JE2160 - Just stopped working. Touch pad works, light goes on when door opens. When starting, timer counts down, can hear a relay click, but nothing (no fan, no turntable, no magnetron. Fuse...
Hi
If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work. You should check the internal door switches, the high voltage circuitry and the circuit board for this kind of problems. But for that you will need a certified technician to help you make these repairs.
Aug 19, 2011 | GE JE2160 Microwave Oven
How do i change the numerical code?
How to change or program code on your Craftsman Liftmaster keyless keypad made by Chamberlain.
1. Program using the "Learn" Button
2.
Within 30 seconds, enter a four digit personal identification number (PIN) of your choice on the keypad. Then press and hold the ENTER button.
3. Release the button when the motor unit lights blink. It has learned the code. If light bulbs are not installed, two clicks will be heard.
Program using the Multi-Function Door Control
NOTE: This method requires two people if the Keyless Entry is already mounted outside the garage.
  1. Enter a four digit personal identification number (PIN) of your choice on the keypad. Then press and hold ENTER.
  2. While holding the ENTER button, press and hold the LIGHT button on the Multi-Function Door Control. Both of these should now be held down at the same time.
  3. Continue holding the ENTER and LIGHT buttons while you press the push bar on the Multi-Function Door Control (all three buttons are held).
  4. Release buttons when the motor unit lights blink. It has learned the code. If light bulbs are not installed, two clicks will be heard.
Change an Existing, Known PIN
If the existing PIN is known, it may be changed by one person without using a ladder.
  1. Press the four buttons for the present PIN, then press and hold the # button. The opener light will blink twice. Release the # button.
  2. Press the new 4-digit PIN you have chosen, then press ENTER.
The motor unit lights will blink once when the PIN has been learned.
Test by pressing the new PIN, then press ENTER. The door should move.
Your new Keyless Entry must be programmed to operate your garage door opener
May 24, 2011 | liftmaster 977lm 976lm Liftmaster...
How do I change the keyless entry code to another number
How to change the code on a Chamberlain Keyless Entry Garage Door opener
How do I add, program or change a Keyless Entry PIN?
Your new Keyless Entry must be programmed to operate your garage door opener.
  1. Press and release the "learn" button on the motor unit. The learn indicator light will glow steadily for 30 seconds.
  2. Within 30 seconds, enter a four digit personal identification number (PIN) of your choice on the keypad. Then press and hold the ENTER button.
Change a Known, or Existing Pin/Code
The light on the motor will blink once when the PIN has been learned.
Test this by pressing the new PIN, then press ENTER. The door should then move.
I hope you find this helpful. If you need further assistance please let me know!
Have a great day! :)
Carrie
May 22, 2011 | Chamberlain Keyless Entry
Liftmaster not responding to any remote. Learn
If the door is stuck in the open position it probably because the trolley is jammed against the bolt just in front of the motor unit. Remove the bolt and run the opener until the door is closed. On the side of the unit you will find an adjustment for the 'up limit'. Turn this about 3 turns in the opposite direction of the arrow printed on the cover. Be sure to replace the bolt.
Post back if this isn't your problem.
Jun 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
Need to know how to adjust the door auto lock function.
Not an easy fix! The door lock function was designed to lock doors only. you can however, disable this lock feature by simply cutting the light blue automatic door lock signal wire on the 6-wire harness plug connector located on the chime module (In component center).
Mar 15, 2009 | 2005 Toyota Camry Solara
Pioneer DV-F07 DVD Player Logo
145 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
