Question about Samsung Televison & Video
I just replaced my Samsung Color wheel and now all of the people on the screen have a blue tinge to them. Any suggestions?
I pulled out a small jumper on the board behind the color wheel. There is a sticker indicating which one to pull. I assume that certain color wheels need this and others don't, mine apparently didn't.
Posted on Sep 05, 2009
Crt monitor gradually develops a yellow tinge after being turned on for a few minutes. It fluctuates annoyingly. It is about 4 years old. It is a Samsung SyncMaster 753DFX Crt monitor.
CRT monitors have three color "guns" in them - Red, Blue, & Green. If one of them is starting to go south you will have a tinge as you describe. To make sure it's the monitor, try connecting a different monitor. If the monitor is the problem, it's not worth fixing. Replace it.
If, after changing the monitor you still have a color tinge, you have a problem with your video device in your PC and you need to have it checked out by a PC Technician.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please return to the FixYa website and rate my response to your question.
Best regards,
Yavacotech
Jan 22, 2011 | Samsung SyncMaster 753 DFX 17" CRT Monitor
I own a KP-57HW40 set that has a color and shut off issue. Started as a green tinge problem to the screen after watching for a few hours. Started becoming more and more frequent a couple months ago....
IF YOU HAVE A RA 6 CHASSI THE TUBES RUN HOT ANOID CATHOD SHORT IF YOU TAP ON THE NECK OF THE TUBES AND GOES TO SOLID COLOR THEN SHUTS OFF YOU HAVE TO REPLACE THAT TUBE ALL 3 TUBES WILL HAVE THIS PROBLEM
Feb 09, 2010 | Sony KP-57HW40 57" Rear Projection...
Sharp 65dr650 color wheel noise.
I saw the same post, discount-merchant.com sells it for 69.99 but as I found out it is the WRONG one. Not even close and I'm annoyed he obviously never tried it himself. I bought a sharp replacement off of ebay but it died after 2 weeks, no refund. The Samsung model number that does not work is BP96-01579A. Maybe there is a samsung model that works but this was not it.
Mar 26, 2009 | Sharp 56DR650 Television
Blue spots & haze
two problems .out of that any one will solve the problem. the bulb or the colour wheel any out of that has to be checked and replaced.
how to replace the colour wheel with diagram and procedure
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
how to replace the lamp in 5 minutes with diagram and procedure
http://www.jangro.com/a/2006/08/03/how-to-change-your-samsung-dlp-lamp-in-5-minutes
Mar 03, 2009 | ViewSonic PJ501 Multimedia Projector
Dark scenes are impossible to see
This is a fundamental limit of Ti DLP. The part can not reproduce low grey scale, so low light film is dominated by artifacts. It helps to sit farther away from the screen. The color shift is caused by a factory tollerance on the color wheel, but there is no user adjustment for it.
Sep 10, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung Color Wheel
Here's a good article on the Color Wheel
It says if your red and blue colors are reversed removing the jumper should fix the issue.
Aug 27, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung color wheel jumper
possible cable is not making full contact with connector to or from color wheel assy.
Jul 15, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung dlp color issue
I just had a service tech out and replaced the color wheel. now i have the same issue with the color...the people all look blue. He told me that now the the digital board is bad. It's the board were all of the connections go. I'm not convinced, as I remember reading something about color settings needing to be adjusted after color wheel replacement.
Mar 28, 2008 | Samsung HL-P6163W 61" TV
Color problem
Samsung color wheel fix
Jan 13, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung hlp 4663w picture is all horizontal lines
Bad color wheel...have it checked by a quaified tech.....
Must have lamp code number to get color wheel #.............T.
Dec 08, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Televison & Video Logo
57 people viewed this question
Henry  Thomas
Henry Thomas
