Question about Pioneer VSX-D3S Receiver
Pioneer VSC-D1S A/V receiver
I have a Pioneer VSC-D1S A/V receiver. The relay that disconnects the speakers at powerup does not reconnect the speakers. I have the service manual, but need some guideance as to where I should begin to look.
  • bdobbs8 Oct 07, 2009
    That should read VSX, not VSC.
  • Anonymous Mar 25, 2014
    HEARD A POP AND ALL SPEAKERS STOPPED WORKING
Did you solve the problem? Mine is doing the same.
Posted on Nov 11, 2009
Pioneer vsx-518-k does not want to come out of standby
Try disconnecting all the cables from the back, including the speakers. Sometimes a short develops on an output stage. If the unit stays on, reconnect one input/output at a time, turning the unit off during the reconnection, to isolate the problem. If it does not stay on, it's an internal problem, requiring a service call.
Nov 07, 2013 | Pioneer VSX-518-K Receiver
Pioneer receiver overload
The "Overload" message usually involves the speakers or the speaker wires. Disconnect the speaker wires and make sure that they aren't frayed or damaged. (When you reconnect them, make sure that no loose wire touches the receiver case, speaker or another wire.) Replace any damaged wire. Make sure that none of your speakers have a lower impedance than the receiver can handle. (Most Pioneer systems have a 8 ohm limit.)
If the message persists, turn off the system. Disconnect one speaker at a time and try turning on the receiver and turning up the volume. If the error disappears when one speaker is removed, that speaker may be damaged and needs to be serviced. Do not reconnect the speaker to the receiver until it is fixed.
I hope this helps.
Jun 20, 2013 | RCA Televison & Video
Receiver is cutting on and off by itself
It is the power control relay that do the cutting OFF and turning On.
these relay is driven by a processor via transistor output.
• One will have to check circuits that accompanies with it.
• Have a plan , prepare tools and equipments
should you need to DIY.
• While having a plan, disconnect all speakers and reconnect later
one at a time if it turns On properly without the speakers.
Sep 22, 2012 | Pioneer VSX-D411 Receiver
My pioneer vsx-d1s muting button and speaker B button not working. no sound in speaker. how i fix that probs???
Dear devan,
Make sure that your speaker buttons are having problem, by connecting new speaker with your system.Let me know the result.
Best regards Chandrashekhar Bhat
Dec 29, 2010 | Pioneer Audio Players & Recorders
My Pioneer VSX-D1S A/V receiver will not power on; this began yesterday. Pressing the power button results in only a clicking sound along with the standby LED turning on. The owner's manual states to press...
Unit is pretty old I had one of these back in 98-99.
Time to upgrade a service tech is going to cost you $150 just to open it up and figure out whats bad.
Pioneer ok but check out Denon's line of receivers Onkyo is good too but they have a high rate of repairs
Pioneer doesn't make them like they used to that D1S was a tank, had tons of audio / video inputs was one of the first with video upconverting had lots of power and a great front display panel. BUT technology has come along way and pioneer hasn't kept up. They even stopped making high end TV's a few years ago even though they were regarded as the best sets out there.
check this out
Denon AVR-4310CIgoogle it they sell for ALOT less than sticker I bought one for $1299 with a 5 year warranty
Hope that helps
Feb 17, 2010 | Pioneer VSX-D307 Receiver
Error 71 an the reciever shuts down
You have a speaker short. Disconnect all speaker wires at the receiver, then turn it back on to test. If you don't get the error code, your receiver is still ok. Reconnect your speaker wires one by one and test the power on the receiver until you find the wire that's causing the problem. Then disconnect that wire at the speaker and test again, this will determine if you have a bad wire or a bad speaker. If the receiver still reads error without speakers attatched, you will need to send it for service. While it's at service, check all wires and speakers for shorts with a meter if you can. This is the most common failure of all receivers, a shorted wire. Hope this helps
Sep 26, 2009 | Pioneer VSX-D711 Receiver
OVERLOAD
HOW MANY SPEAKERS ARE YOU RUNNING? IF you are running more than TWO speakers, the very FIRST thing to check is to make certain ALL of your speakers have an IMPEDENCE of 8 OHMS. Virtually all speakers of even modest quality will include this specification on a label on the back of the speaker. You CANNOT run more than (2) TWO speakers with 4 OHMs impedence on ANY amplifier (technical discussion too long!) [NOTE: Some Pioneer equipment have internal overload protection systems to prevent permanent damage. However, you cannot re-set these systems yourself. Your dealer or authorized HK service center must do this.] But, before you take your unit in for service, there is one more "test": check for shorted and/or mis-connected/disconnected speaker cables/wires. Visually inspect connections at the receiver and speakers first. You might find something obvious! If everything looks okay, then disconnect ALL of the speakers; and reconnect and test them one at a time (at relatively low volume.) For example, reconnect the left front speaker, test the system; THEN add the right front, test the system,and so on, ADDING one more speaker each time - FIRST MAKING SURE EACH OF THEM HAS AN IMPEDENCE OF AT LEAST 8 OHMS! IF there is a short (or bad speaker) this will help isolate it. Hopefully one of these "fixes" will work for you. GOOD LUCK!
Jul 15, 2007 | Pioneer VSX-D511 Receiver
Help please
The very FIRST thing to check is to make certain ALL of your speakers have an IMPEDENCE of 8 OHMS. Virtually all speakers of even modest quality will include this specification on a label on the back of the speaker. You CANNOT run more than (2) TWO speakers with 4 OHMs impedence on ANY amplifier (technical discussion too long!) [NOTE: Your Pioneer unit has an internal overload protection system to prevent permanent damage. However, you cannot re-set these systems yourself. Your dealer or authorized HK service center must do this.] But, before you take it in for service, there is one more "test": check for shorted and/or mis-connected/disconnected speaker cables/wires. Visually inspect connections at the receiver and speakers first. You might find something obvious! If everything looks okay, then disconnect ALL of the speakers; and reconnect and test them one at a time (at relatively low volume.) For example, reconnect the left front speaker, test the system; THEN add the right front, test the system,and so on, ADDING one more speaker each time - FIRST MAKING SURE EACH OF THEM HAS AN IMPEDENCE OF AT LEAST 8 OHMS! IF there is a short (or bad speaker) this will help isolate it. Hopefully one of these "fixes" will work for you. GOOD LUCK!
Jul 07, 2007 | Pioneer VSX-D488 Receiver
Pioneer vsx-d511
Clark, you MIGHT have a simple problem here. Let's keep our fingers crossed... This problem generally has more to do with the speaker WIRES or their IMPEDENCE than anything else, even though the receiver displays "AMP ERR." (Technically, it IS an amp error, but the source MAY not be the amp!) The very FIRST thing we need to do is check to make certain ALL of your speakers have an IMPEDENCE of 8 OHMS. (Pioneer says 6, but that's not necessarily a good recommendation, particularly if you listen LOUD.) Virtually all speakers of even modest quality will include this specification on a label on the back of the speaker. You CANNOT run more than (2) TWO speakers with 4 OHMs impedence on ANY amplifier (technical discussion too long!) [NOTE: Your receiver has internal overload protection systems to prevent permanent damage. On SOME Pioneer models, these can be "reset" but you can't do it yourself. Your dealer or authorized service center must do so.] But, before you take it in for service, there is one more "test": check for shorted and/or mis-connected/disconnected speaker cables/wires. 1) Visually inspect connections at the receiver AND speakers. You might find something obvious! Look for bare wires touching one another. Again, you must look both at the receiver, AND at the speakers. 2) If everything looks okay, then disconnect ALL of the speakers at the receiver; and reconnect and test them one at a time (at relatively low volume.) For example, reconnect the left front speaker, test the system; THEN add the right front, test the system, and so on, ADDING one more speaker each time - FIRST MAKING SURE EACH OF THEM HAS AN IMPEDENCE OF AT LEAST 8 OHMS! IF there is a short (or bad speaker) this will help isolate it. Hopefully one of these simple fixes will get you up-and-running. Good luck!
Jul 02, 2007 | Pioneer VSX-D511 Receiver
416 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
