Question about Canon PIXMA MP460 All-In-One InkJet Printer
Printer jams and then says ''Error, no paper. Load paper and press OK.'' Jam is caused by roller (there is only one) taking a small bite out of paper edge and trying to feed diagonally. Can find nothing stuck in paper path, nothing on rollers. Fed through piece of card stock to dislodge hidden obstructions and THAT fed ok. Ordinary paper jams.
Printer says paper jam on calibration
If you check closely, you may find there is a small piece of paper trapped between the rollers?
Feb 21, 2013 | HP PhotoSmart 7760 InkJet Printer
My printer mp 145 showing error 3 but no paper jam.. anyone can help?? Urgent!!
first:
Remove the jammed paper, close the cover and press Ā«Resume / CancelĀ»
second:
If there is no jam - check the checkbox sensor registration papers and the sensor itself
In addition, this error may cause failure of the paper feed roller or gear
or maybe small parts inside of the printer that block paper.
May 24, 2011 | Office Equipment & Supplies
The printer indicates out of page. Load paaper the press OK. I have paper loaded in the printer and only on the first page i will get the indicated out of page. Once I press OK the system the printer...
The pick up rollers are dirty. You need to clean them with a damp cloth. These rollers should be just above the leading edge of the paper when loaded.
Dec 23, 2010 | Office Equipment & Supplies
Open door cariadge jam
this error generally comes in when there is actually a paper jam or it gives a false paper jam.. so first of all make sure that these should not be any paper stuck inside the printer.. clean all the paper rollers with a little moist lint free cloth.. then plug the printer directly to the wall jack for the power supply if not connected..
if it doesnt resolve the issue.. we may have to perform a reset as well ..
Oct 22, 2009 | HP OfficeJet 4255 All-In-One InkJet...
Paper jam ,no paper jam found Dell 1815dn
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 01, 2009 | Dell 1815dn All-In-One Laser Printer
"Clear paper jam" error, but there is no jam!
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-23
Sep 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Carriage Jam -- Paper Jam
I have serviced an officejet pro L7580 which was showing a paper jam error when powered on. our customer had had a paper jam and removed the paper . I found small peices of paper in the pick up assy gears. If you remove the rear door, you need to check the 2 small white gears on the left. turn the roller slowly by hand and clear any paper stuck between the teeth. (they may be very small).
after doing this....no more paper jam errors for me!
Jun 18, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Try cleaning the rollers, it's the maintenance tab on the printer's properties. Maybe this will help.
Feb 28, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Out of Paper. Load Paper Error
Check
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00265823&cc=nz&lc=en&dlc=en&product=422000&dlc=en&lang=en
HP PSC 1600 and 2350 Series - Paper Jam or Paper Feed Problems"
When the all-in-one detects a paper jam, the following message appears: Paper jam: Press OK to continue . The computer might display the following message: There is a paper jam (or misfeed). Clear the jam and press the Enter, Resume or OK button on the HP PSC. This document will assist in correcting paper-feed problems such as paper jamming, print slanting, and multiple pages feeding into the all-in-one. s.gif Clearing paper jams
Jul 28, 2006 | HP PSC 2355 All-In-One InkJet Printer
Canon PIXMA  MP460 All-In-One InkJet Printer Logo
124 people viewed this question
old marine
old marine
