Question about Refrigerators
Have frigidaire model FRT 18B5JB1, the space below the crispers fills with water and spills out on my floor about every week and a half..there is no drain, no condensation on the walls..help!!
  • 4,066 Answers
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Sep 05, 2009
Vegetable crisper is filling with water
You may have have your freezer drain stopped up and when it goes into defrost, it melts and the water spills over to the lower section being the crisper. This is a simple fix. You just need to find out where the water is coming from .
Feb 05, 2013 | Samsung RF217ACPN - 20 cu. ft. French Door...
Frigidare r5303b under worktop fridge with little freezer box inside what number should it be on because thermastat does not seem to go off much
Good day,
Don't know the numbering sequence on your model, but all manufacturers design the control so that half way from warmest to coldest is normal.
Mar 31, 2010 | Frigidaire Refrigerators
I have a model FRT 18B5JB1..the area under my crisper continues to fill with water and overflow on my kitchen floor..HELP!!
That is from your defrost drain either being clogged with food, or covered with ice. Behind the back wall in the freezer is a drain that empties underneath the fridge. If that drain gets blocked or froze over then the water will dump into the floor of the freezer and out the door gasket.
Sep 03, 2009 | Frigidaire Refrigerators
Wahser does not stop filling water
replace the water inlet valve
May 03, 2009 | Washing Machines
Water spills out of top
I would suggest using lime away around the area which you say the little holes are it will clean it all away soap build up etc..
Jun 09, 2008 | Washing Machines
Sub-Z 550 reidge internal leak
The tube behind the crisper drawers is not insulated well enough and will repeatedly freeze, leaving the water to drain on your floor. The solution is to thaw the tube and put a piece of copper the length of your tube, into the area below. The wire extending into the area below is just warm enough to keep the tube from freezing.
Aug 19, 2007 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
