Question about Haier HDN455E 45 Pint Dehumidifier Dehumidifier
Haier 45 pint dehumidifier water froze on the coils on the front but the back panel was fine and water leaked out as it thawed onto the floor. This is something that it suddenly started doing for no apparent reason
    Brigadier General:
  • 5,158 Answers
Generally they freeze up for two reasons. very low humidity or the temperature in the room is too cool
for low humidity it's best to cycle the dehumifier (so it goes off occasionally) using the control for it.
for temperature you may have to use a heater or warm up the room in some fashion.
most likely the reasons for it starting to do that is a season change of low humidity/cooler weather.
robert
Posted on Sep 04, 2009
Heat exchanger line frosting up. Then drips on the floor
The condensate bucket may be missing or installed incorrectly. In some dehumidifiers poor design causes condensate to drip onto the floor.
Apr 21, 2015 | Haier 45-Pint Dehumidifier
Why doesn't water drain into the hose?
My dehumidifier was dumping condensate onto the floor instead of through the hose to the floor drain. The solution turned out to be making sure the unit was level. No worries since then.
Feb 05, 2013 | Haier 65-Pint Energy Star Dehumidifier...
Haier 45-pint dehumidifier unit cannot be turned on. It has been running fine last few days.
The first thing that comes to mind, is have you emptied the water collection bucket recently? If so, be sure that the bucket was properly reinstalled and is making contact with the bucket safety removal switch.
If you haven't emptied the bucket in the past few days, it may simply be full and will not start until it's emptied.
Hope this helped you and thanks for choosing FixYa.
Sep 13, 2011 | Haier 45-Pint Dehumidifier
I have a 45 pint haier dehumidifier that is plugged in, everything lights up, but doesn't run. What's the deal?
There are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
Hope this helps to troubleshoot & solve the problem. Please let e know.
Jul 06, 2011 | Haier 45-Pint Dehumidifier
Runs constantly and will freeze up the coils. Will not stop compressor to allow the coils to thaw.
You are taking too big a bite out of your humidity at one time ... plade the adjustment on a higher setting for now. When youe machine has achieved that goad, ower the setting a bit.
Alternatively, set a small fan to blow more room air on the coils ... you will probably still have to adjust the stting higher ...
Thanks for using FixYa.com
Aug 23, 2010 | Haier 45-Pint Dehumidifier
I have a brand new Haier 45 pint Dehumidifier. The manual gives no advice on setting temperatures. What do I do? I set up with hose going in to my sump pump but no water seems to come out
Most of the time you set @55% RH. But on most Portable dehumidifiers you dont have a setting that tell you percent. Set about 1/2 way and see how much water it put out. That is about 60%. Go from there. Rus
Oct 29, 2009 | Haier 45-Pint Dehumidifier
I have a model HD-306 Haier dehumidifier which is hooked up with a hose to a drain. It has been working fine until several days ago. Water now is coming from the bottom of the unit onto the floor. I...
please make sure the unit is leveled.also make sure the hole in the drain pan not clogged.also the size of the hose must be fit the hole not smaller
Sep 04, 2009 | Haier 45-Pint Dehumidifier
My HDN455 45 pint Dehumidifier did not work
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 17, 2009 | Haier HDN455E 45 Pint Dehumidifier...
Haier hdn455 45 pint overflows
Float switch is stuck, has a broken spring or the actuator arm is bent
Aug 19, 2008 | Haier HDN455 45 Pint Dehumidifier...
Dehumidifiers Logo
65 people viewed this question
Top Haier Dehumidifiers Experts
Shawn DuRee
Michael Vincent Cruz
Shehu Pro
Shehu Pro
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
