Question about Canon PIXMA iP4300 InkJet Photo Printer
Printer will not power up. I have checked and rechecked power line to no avail.
My charger is indicating problem power line.i have checked power supply and is good .what could be my problem ?DeWalt cordless saw 28 v DC9000 charger.
There's a high possibility that your cord could be frayed or damaged in any way I'm sure it's not some sort of offset problem that just says there's something wrong when there's nothing there so I would recheck my line and I would definitely check for insulation of my voltage
Feb 06, 2018 | Saws
Is there a fuel pump reset button on this car ,if so wheres it at?
no reset start by checking ignition key if its worn down vehicle wont recognize it also is key an electronic key may have gone bad if good recheck fuses if good pull fuses and check for power if good recheck relay if good pull relay and check for power if good than check lines and connections and power at pump connections if good than pump bad if anything bad leading up to pump repair replace and recheck connections up to pump also check battery connections for corrision
Jun 02, 2015 | 2007 Pontiac Grand Am
Why am I getting a "Server Failed" notification when running the network diagnostics?
The printer is not communicating with the computer. Recheck the IP address on the printer against which port on the computer is selected. If everything checks out ok then uninstall the printer driver and reinstall.
Oct 28, 2014 | Ricoh Aficio CL7200 Laser Printer
Computer is sayinng the printer is off-line. I
depending on your operating system you can try the following:
go to your control pannel, find your printers, RIGHT click on the icon for your printer and see if the "use printer online" option is availible.
if this option is not availible, or does not work...you may need to download the latest drivers fro. the Cannon website. (I am only assuming that you installed the drivers from the CD that came with it)
again, if this does not work either....check that the printer IS recieving power and the indicator lights come on(I assume you did this already)
as a last resort, if none of the above work at all....I would bring the printer back to the place of purchase and see if you can exchange for another. Sometimes you do get a lemon.
Jan 04, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Communication Error
yes may be try with diffrent cable and other usb port.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Apr 06, 2010 | Dell 924 All-in-One InkJet Printer
Check ink U150 Alarm is on then i click all the ink cartridges down soall the red lights are on but when i close the lid the Alarm goes off again i have replaced all the ink cartridges with new ones...
After you have rechecked that they are all fitted correctly, (which I know you have already done,) check to make sure that the lid is engaging the switch that will show that it is closed correctly. If this fails, remove each cartridge and see if its switch is OK and not damaged. Once this has been achieved and it still does not respond, it is time for the proffesional.
Before you do that though, try a reset of the printer:
1. Turn the printer off with the Power button (if available).
2. Disconnect the data cable from the printer.
3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in.
4. Turn the printer back on.
Feb 15, 2010 | Canon PIXMA MP530 All-In-One InkJet...
I get a printer off line error report when trying to print. How do I get the printer back on line?
This usually means the printer got turned off or the connect between it and your computer came loose. Check connections and turn printer off and on again and recheck.
Nov 23, 2009 | HP Photosmart Premium C309A All-In-One...
I have an IMAC--- version 10.5.7 brother printer H2040---"printer is currently off line" how to fix? Have checked and rechecked all connections and gone through the "reinstall" HELP? Problem started when I...
hi,
have you installed the drivers for the printer?
if the answer is no - please install the specific drivers for the printer.
if the answer is yes - which driver did u install?
if u haven't tried both the drivers (the one is the os X dvd and the brother printer driver) please try that.
if you still have problems with the printer-offline, try moz-screenshot.pngmoz-screenshot-1.pngHP cups drivers, it works for most brother printers. this should solve your problem.
cheers
Jul 23, 2009 | Brother HL-2040 Laser Printer
Does anyone know what a 102H error means on a Minolta Magicolor 2490MF please ?
The error code is a message from the computer to let you know there has been a problem reaching to an adapter or device. It indicates Port 102h register test error. It means you should try reconnecting the printer, and ensure you have the printer properly installed so that it does show up as the correct printer when you select the Start, and Printers. (Or when you go into Control Panel and then select Printers, to see the installed printers in your computer.)
If the printer is on, is completely properly connected, is properly installed and appears in the list of your installed printers, in your computer Control Panel, then possibly you have some problem with the actual whirring, paper-handling printer device. You may try shutting down your computer, after you save any unsaved work that you were doing, and close applications, and can properly completely shut off the computer by selecting Shut down, from the Start Menu. Also please disconnect any cameras and any USB hubs for this test, but keep the printer connected. No need to turn off the printer; leave the printer on. Power on the computer and recheck the status of the printer, to see if it appears in the list of your installed printers, in your computer Control Panel, and see if the printer appears to be available or ready to print. If the printer does not appear, check its connection again, move the printer USB cable to another USB connection on your PC if it was already connected, and recheck. If you still do not see your printer appear there, it seems you will need to try another USB cable or another parallel printer cable, and proceed to install the printer. See if the printer has any flashing indicator - lighted LEDs, and notice the colors, and any error message. Report any questions you have about getting the printer installed please. Report any questions or problems you have with understanding what the manual instructs you to do to resolve the reported error. Maybe the printer has just gone bad, died, become kaput.
Aug 01, 2008 | Minolta Office Equipment & Supplies
Printer not printing
maybe you have set the printer to a wrong port. recheck port address or reinstall printer driver.
Jun 22, 2008 | HP DeskJet 612c InkJet Printer
Canon PIXMA  iP4300 InkJet Photo Printer Logo
141 people viewed this question
old marine
old marine
