Question about Toshiba SD-V291 DVD Player/VCR
When trying to program the timer recording on my SD-V291, the channel settings go from 1-13 the then L1 or L2 shows up. I don't know how to get rid of the L1/L2 so I can program a new show. This is the first time this problem has occurred. HELP! EMAIL: djroberts@snet.net
  • 2,200 Answers
Hi
L1 and L2 are to do with recording an external source or duplicating a cassette from another VCR or camcorder so it seems you have accidentally activated this feature.
First do this
1) Press VCR/DVD to select VCR mode and insert a blank cassette
2) Press the input select button and cycle to see if L1 or L2 will turn off
3) If not press record and allow the tape to run for 10 seconds or so - press stop - see if the issue is now resolved.
If not move to this procedure
1) Press VCR MENU and select TIMER REC SET then press ENTER
2) Check the lines for any sign or a program set to L1 or L2
3) If you find one use Set + or Set - to select it and press ENTER
4) Press CANCEL to cancel the program
5) Press VCR MENU twice to exit.
Finally if the issue is still not resolved do this.
1) Press VCR menu
2) Press set + or - to select "CH SETUP" then press enter.
3) Press set + or - to select TV/CATV then press enter
4) If your channels are through an antenna select TV. If through cable select CATV and press enter for either option.
5) Press VCR MENU until the screen is cleared.
Hope this helps. If so please do accept and rate my answer. If you continue to have problems post up a comment with futher details.
Posted on Sep 04, 2009
Www philips com support
This unit doesn't have a tuner of any sort. Even on the few DVR/DVD recorders that have tuners, the external composite video inputs do not connect to the tuner. To record from the L1 or L2 inputs, you must be using a set-top box (cable, satellite, or digital-to-analog converter for OTA signals) or another video source (video camera or a vcr). Most TVs do not have video output capabilities. If you have one of those, follow the directions for recording from set-top boxes below.
Turn on and set the source to the channel that you wish to record for any set-top box. Then make sure that the set-top box is left on and at the correct channel after you finish setting the frequency, speed and length of time for the recording. Note: if the set-top box is turned off, your recorder will still record the blank video and audio.
What source do you have connected to the VCR?
To record from a video camera or a VCR, set that source to play back at the desired time point. This is best done without the timer. Just start recording and then the playback.
I hope this helps. Please add a comment with your video source for more support.
(My OTA tuner has a energy-saver option that turns off the unit when there is no activity for a while. Since I usually record when I'm either asleep or away from home, I had to disable the feature to get the correct recordings.)
Jul 04, 2013 | Philips DVP3345VB/F7 DVD Player/VCR
Can't get rid off L2 message on the recorder.
If I'm understanding this as what I think it is - that's not an error message at all! It's the input your recorder is currently set on (I'm talking about the "L2" shown in the right side of the LED display when the unit is powered on, where the channel number would usually be.) In order to change that, you have to open the bottom flap on the front of the machine (or slide open the remote bottom for the record controls to be exposed,) and press the "Input Select" button twice until it cycles through L3 and ends on whatever channel you last left it on - I think it defaults to 100 if the power has been interrupted. When you press this button after that, it would cycle through "L1", "L2", "L3", and the channel input (or coaxial cable input, to be exact), as expected. I know of no other "L2" message you might be speaking of. If I'm incorrect on this, I apologize. But I hope I'm not and that this simple issue is all that is causing you a headache! Good luck! And by the way, "L1,2, & 3" are the RCA/S-Video inputs on the back (L1 and L3) and on the front (L2) of your machine for various things you might plug in (video cameras, etc.) Note: For L1 and L3 ONLY, you have to go into setup to select whether you will be using the RCA yellow or S-Video jack on the back of the machine for the video of that particular input (with no bearing on the RCA audio jacks for that particular input - they're always used...) - the front L2 input evidently selects on its own between S-Video and the RCA yellow plug, based on which plug has something plugged in. I haven't tested to see which it will select if they are both occupied with a plug on L2. I don't mean to treat you like an idiot -- please don't take it that way - but I don't know how much you know about electronics, and IF I'm right about this whole thing, then I'm sort of assuming you aren't too familiar with them. In either case, please know that I mean well, and any information that you already know, just overlook. Thanks, and again, good luck!
May 29, 2011 | Sony RDR-GX300 DVD Recorder
Hos do you program the vcr to recorde a show withthe cable box
You need to connect the cable box to the VCR using a SCART lead. Note which input you connect it to on the VCR (usually called AV1 or 2, or L1 or L2) To record your show, put the cable box onto the desired channel, then set the vcr to the correct input. (on the remote there will be a button marked input select or AV or AUX) Now when you record, it will record whatever the cable box is showing. :)
Jul 11, 2010 | Televison & Video
Panasonic PV-9451 VCR, When setting up the VCR to record a channel, the only channel options are Channel 02 thru 25 and L1 And L2. What has to be reset with the digital cable input??
You will need to use L1 or L2 (one is probably on the front of the VCR, and the other on the back, they should be labeled).
YOu need to plug the digital receiver's output into L1, or L2, and set the VCR to record the one you're using. Then set it to the time you want, and then set the channel on the digital box tho the one you want.
One Channel, One time. (or recurring daily, if your VCR allows daily recording from L1,2)
Jun 13, 2009 | Televison & Video
Can't get to recorded programs
Check and make sure you have the DVD Recorder hooked up to the TV. I think you have the Cable box or Satellite hooked up or else you could not record. So there is a second set of outputs on the back of your DVD Recorder, Buy a set of RCA jacks and plug them into the Yellow,White, Red Plugs of your DVD Recorder, Then plug the other end into your TV in either L1 or L2 inputs, whichever ones are free.
May 12, 2009 | Panasonic DMR-E85H DVD Recorder
How do I record a TV Program.
Video & Left,Right audio go out of Comcast cable box to L1 input on DVD recorder,Video & Left,Right audio go out of DVD recorder to a line input of your TV.  Record L1 input on DVD recorder.
Jan 10, 2009 | Panasonic DMR-E80H DVD Recorder
Leaves blank TV screen when Return button operated
It sounds as though the unit is actually recording a DVD, but is getting no incoming signal to record. What is your recording source? Satellite and receiver? Antenna? Cable box? In the set-up menu, be sure you have chosen the proper input source; i.e., recording from where? You may be able to access that menu through the Function button on the remote, AFter setting that menu, be sure to press Return to restore the recorder to the ready mode. If you are using the RF input for recording, be sure that is selected as well, as opposed to L1 or L2. The input channel must match the output channel on your receiver, usually channel 3 or four. What is the model number?
Dec 02, 2008 | Sony RDR-GX300 DVD Recorder
Cannot do timer recording
I need more information, what kind of recorder is? it has built in tv tuner?
Nov 11, 2008 | Philips Magnavox DVD/VCR Dual Player
Dvd/vcr combo
I'l make sure, but I beleave L1 and L2 are inputs. You need to select the one where the show comes from, Its it coming from the L1 connector or L2.
Your device doesn't have a tuner input jack. To record TV programs on your DVD/VCR, you need to connect this DVD/VCR to an external tuner device (e.g., set top box, cable box or satellite receiver) that has audio/video output jacks.
Il confirm this and reply to you in a moment.
May 18, 2008 | Televison & Video
Recording from cable
L1 and L2 are different inputs on the VCR.If you have red, white and yellow input on the front of the VCR then when you put the VCR on L1 it should pick up a signal from the front.To get more channels on your vcr you want to do an autoprogram make sure the cable from the wall is plugged into the input in the back and go to the menu on the VCR and look for channel search or auto program and start the search.usually you can find this setting under something like SETUP, Programming,settings on the main menu of the VCR.You may have to search in the menu of the vcr for a little bit until you find it.Youll know when you got it when the channels automatically start scanning from 1-98.GOOD LUCK and rate me if this fixesya or is helpful.
Nov 16, 2007 | Lands Phones
Toshiba SD-V291 DVD Player/VCR Logo
93 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
