Question about Indesit W 123 Front Load Washer
After i drain the washing machine will it start back draining itself
Yes
Posted on Sep 04, 2009
Machine stopped in mid cycle with the drain/unlocking light on. No error codes. Machine goes directly to the drain/unlocking position after start. Will not fill, spin, operate. Any ideas?
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 01, 2013 | Whirlpool WFC7500VW Washer
My Beko 81241 LW seems to be stuck in the Spin & Drain cycle (it's not actually on though) and the Start symbol is flashing. The time is also displayed (12mins). The door is also locked. Holding the Start...
Good Day,
Oct 30, 2013 | Beko Washing Machines
Washing machine will not drain water
Here are some basic troubleshooting steps you can follow to help you determine why your washing machine won't drain:
1. Check the drain hose in the back of the machine and make sure it isn't kinked or flattened.
2. If it spins but won't drain, there could be a piece of fabric stuck between the inner and outer tub, or even the drain hose or pump itself. The farther into the machinery a clog goes, the trickier it can be to remove. It could also be a faulty timer.
3. Are clothes soaked at the end of the wash, even though it appears to go through the spin and drain cycles? Worn or loose belts could be the culprit.
4. When the spin cycle starts, do you hear a humming noise? It could be a faulty or jammed impeller pump.
For more suggestions on troubleshooting and fixing this issue, check out Washing machine not draining. I hope this helps!
Sep 11, 2012 | Whirlpool Washing Machines
I have a Zanussi Aquacycle 1000. It is taking in water and draining but the drum does not rotate both during wash cycle and spin cycle. Urgent help needed as we have people staying from England and NO wash...
Hi.
If the machine is filling up, then cycling and draining, the problem is usually the belt. The belt is reached disassembling the appliance . If the belt is OK the problem is usually the motor or the motor control unit, which is a sealed electronic module connected to motor and to control board and located inside the washer. If the motor has volts and does not turn, then the motor must be replaced. In some less common case the control module itself may be responsible. Motor assembly and belt are located at the back of the drum and get accessed disassembling top and back of the washing machine.
If the machine does not go through the cycle, but it starts draining from start, then the problem is overfill detected. In that case check the drain system, the drain hose, the inlet valve and the pressure switch.
Regards.
Ginko
Aug 29, 2011 | Zanussi FJS1225W Front Load Washer
I have a Roper washing machine and it will not drain the water?
Most common causes for a machine that won't drain are:
  1. Clogged drain tube
  2. Clogged drain hose
  3. Clogged drain pump
To diagnose, remove the drain hose from the drain tube and look for water in the tube. A clog will force water back into the machine. If this is clear, some debris could have worked it's way into the drain hose itself. Check this by removing the hose and inspect for a blockage. If both are fine, the problem is most likely in the drain pump. Many times, a piece of paper left in a pocket will work it's way into the drain pump and get lodged.
Mar 31, 2011 | Roper RAS8445KQ Top Load Washer
Kenmore topload washing machine that wont switch to drain
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Then, see the Whirlpool / Kenmore Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Normally, this would appear to be a Lid Switch or Neutral Drain problem BUT since it is re-filling , it sounds like a Timer problem.
See the Service Manual for how to test / replace the timer.
Apr 16, 2010 | Kenmore Washing Machines
Does not start. Went thru all possible
this can usually be a blockage in the drain pump.the neext thing to check after the drain pump is the door lock.
Jan 30, 2010 | Frigidaire ATF6000ES Front Load Washer
What does the flashing OE mean? My washer is flashing OE and the water will not drain after the cycle.
OE means the drain hose is clogged. UE means unbalanced or overloaded. This is decribed in the owner's manual page 31-32. Pull the hose from the back of machine and rinse it out. Then, check the lint filter on the bottom, front left side. Put drain hose back and close lint filter. Unplug the machine, press and hold the start button for 10 seconds to reset machine computer (not the on button...leave machine turned off and unplugged while resetting computer) plug back in, put on no spin and start the machine. It should drain.
Jan 20, 2010 | LG WM2487H Front Load Washer
My washing machine won't drain... It went through a washing cycle and then started beeping at the moment of draining...
check the pump drive belt under the washing machine, if that is ok it may be the pump itself
May 17, 2009 | Washing Machines
Indesit W 123 Front Load Washer Logo
16 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
