Belt squeaks while spinning - Washing Machines
    Top Expert:
  • Washing Mach... Master
  • 78,936 Answers
Replace the belt, they do wear out and slip and make this noise, if the belt is new then the washer has a bad bearing causeing excessive friction.
Posted on Sep 04, 2009
I have a 91 Honda prelude my belt on my alternator skweeks how can I adjust it
Not sure, but isn't this a serpentine belt which uses a spring loaded tensioner? If so, remove belt and spin all driven items to see if one of them squeaks all by itself. Include spinning tensioner pulley. If no squeak found, check for any loose or misaligned parts. Lastly, replace belt.
May 07, 2015 | Honda Cars & Trucks
Kenmore stackable wash/dryer Dryer squeaks so loud. How do I stop the squeak.
You probably have a bearing in one of the rollers that spin when the dryer is turning. You'll have to take the front panel off and remove the dryer tub by taking the belt off. You'll then see two doughnut shaped wheels attached to the back panel. Check and see if one or both are loose on the shaft that holds them. If they are replace them. Lubercating is not an option. If they seem ok, check the wheel that the belt loops through and make sure it spins without wobbling. One of the three things is causing the squeak.
May 18, 2014 | Dryers
04 kia spectra squeaks when starting cold
belt could be too loose possibly or need to replace belt engine is spinning faster then belt is why it squeels
Dec 05, 2012 | 2004 Kia Spectra
Our Kenmore Elite 45992 is making a loud squeaking sound when it spins clothes. We've checked the belt and shocks and they are okay. Any ideas?
Had same problem mine was the yoke thatheld inner drum tobearing was broken. Lucky it was covered by Sears warrenty. Over $1,000 to repair without warrenty..
Sep 30, 2012 | Kenmore Elite Washing Machines
Dryer is squeaking bad
its either the belt slipping .... the motor ....... or the main drum bearing you can take the belt loose and spin the drum and listen for the squeak then spin the motor and listen that should tell you which is causing the squeak
Mar 26, 2012 | Washing Machines
During the spin cycle it has started to squeak? it sounds like rubber, maybe the seal or the fan belt?
If it squeaks or spins slower than when it was new, and/or you smell something like burning rubber, it is probably the belt. You can replace it yourself if you look up the make and model number on the internet. There are free sites that will walk you though the process. free.
Jun 19, 2011 | Neff Washing Machines
What makes a belt squeak?
Belts squeak for the same reason tires do when they spin. They are slipping. Something isn't turning as fast as the belt wants it to. On ford it's usually ether the idler sprocket or the tensioner. If you remove the belt and try spinning all of the pulleys by hand.( note the crank wont spin freely) you will usually be able to tell witch ones slipping.
May 14, 2011 | 1999 Ford Taurus
The dryer is squeaking (especially when it begins spinning), and it spins a little rougher than normal.
The sqeak is from one of two items surrounding the drum. It can be the belt with a bad roller on the belt tensioner or the liner surrounding the round lip of the front part of the drum to the dryers front panel.
If the squeak can be heard dy the dryers door it will be the felt liner. If deeper inside it will bet the belt
Sears has replacement parts online and at all repair centers for sale
Apr 10, 2010 | Amana NED5500TQ Electric Dryer
Squeaking washing Machine during spin cycle
Hi
Loks that your machine is pretty old and hence the belt has hardened making a squeaking noise.
Good fix is get a new drive belt.
OR
Quick fix is you could put some oil on the drive belt..... it will work for now but not a permenant solution.
Regards
Berry
Feb 01, 2010 | Kenmore Washing Machines
1988 jeep cherokee, 4.0. newer water pump *few months maybe* doesnt over heat, no leak, but it squeaks, just like a bad idler pulley would. when running i sprayed oil in on it and it stop squeaking for a...
Take the belt off check the clutch fan and spin all the pullies insure they spin freely and do not wobble if any do replace them if all checks out ok put a new belt on. make sure the belt tension is not to tight should have about 3/4 inch play.
Oct 05, 2009 | 1988 Jeep Cherokee
Washing Machines Logo
98 people viewed this question
Top Washing Machines Experts
