Question about Compaq Presario Notebook
MY COMPUTER SCREEN LOOKS LIKE IT WENT THROUGH A SHREADER
  • Compaq Master
  • 13,433 Answers
This is mostly caused by either a loose cable connection between the lcd and the mainboard or a faulty video adapter on the mainboard.
You can try the laptop on a external display and see if the issue appears on the external display aswell.
If it does, then its definitely a hardware fault on the mainboard.
If the external display works right, the issue could be the cables between the display and the mainboard or there could be a hardware fault on the internal video connector side, but the card is still sending working video from the 2nd connector.
Unless its a lose cable, only home fix for you would be to replace the mainboard.
Take the laptop to a local professional to look into.
Posted on Sep 04, 2009
  • 22 Answers
Sounds like either a driver problem or a defective graphics chip. Is this a new or older notebook? Determine your graphics manufacturer and try downloading their latest driver for your video graphics software or hardware driver.
If it is a defective chip, you will need to contact the notebook manufacturer to get repair service. If the notebook is less than a year old you should be able to get the service for free. If you have an extended warranty then it should cover your situation.
Hope this helps.
How do you test sending unit on fuel pump
On the top of the engine there is a fuel rail, on the rail is a shreader valve (looks like a tyre valve). You need to screw a fuel pressure gauge to it to test. !DO NOT PRESS! will spray fuel at pressure.
Dec 20, 2013 | 1991 Ford F150
My lap top screen went black but it looks like the computer is running? can i convert my laptop to hook up to a computer screen?
yes you can hook it up to pc screen just plug the blue vga cable into vga connection on laptop its usually the blue connection with pins
Oct 12, 2010 | Computers & Internet
Have a Troy Bilt chipper/shreader model 47285. I
Taked the broken belt to the auto parts store for a replacement.
Jun 06, 2010 | Troy-Bilt ChipperShredder
PS60C-2 Shredder: Fellowes P50CM paper shreader motor runs but cutte...
One of the drive gears has stripped its teeth, usually caused by overloading the machine. These are personal shredders and parts are not available in my experience.Sorry.
May 03, 2010 | Fellowes Office Equipment & Supplies
MTD chipper shreader
Sounds like the carb is gummed up. Do a complete carb cleaning and see if it helps.
Jul 10, 2009 | Yard Machines 24a 452g729 5.5 Hp Chipper...
My acer X193w screen went blue and wont show red
I once had that problem, I think you need to make sure that the power supply cable is fitted well and your monitor receives enough power. if its shares the power cable with your CPU try and separate it then restart your computer.
Jun 24, 2009 | Acer X193W LCD Monitor
Drive gear for staples shredder Model# SPL-770M is worn
is it the drive gear or is it that the shreader is dull that makes the shreader sluggish?
Apr 04, 2009 | Fellowes Office Equipment & Supplies
Blade gone south (shreader)
www.gopresto.com you can order parts here!
Please rate this FREE response!
Dec 07, 2008 | Presto SaladShooter Plus Food Processor
The shredder runs perfectley in the reverse direction, but does not run at all in the shredding direction
I have seen many shreaders that are caked with paper underneath the blades.
After you remove the power, turn the shreader upside down (if possible )and completely clean the area.
Make sure you use shreader oil after you clean it
Dec 01, 2008 | Office Equipment & Supplies
FELLOWS PS 65C SHREADER
There is probably astripped or broken gear inside the gear box.
Nov 05, 2008 | Fellowes Office Equipment & Supplies
Compaq Presario Notebook Logo
63 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
