Question about Coleman 5640B807 Compact Refrigerator
Fan motor for my coleman icebox model564 quit working after 4 mouths need to replace
  • 124 Answers
Check with your local computer or electronics hobby store.
Recomend you remove the original fan and take it with you to the store so they can match it to one they may have in stock.
Posted on Sep 21, 2009
3 Suggested Answers
  • 4 Answers
SOURCE: Coleman 12-volt cooler stoped working/fan burned out
Sound like you have the newer version. These fans can be found at Radio Shack or anywhere computer parts are sold. It doesnt have to be an exact replacement. Just big enough to fit over the Cooling fins. Also make sure it's a 12 volt motor
Posted on Jul 14, 2009
SOURCE: coleman model 5645 inside fan motor not working
it is a 60x60x10mm 12 volt cooling fan available at many computer part suppliers or on ebay is where
I got mine it is very simple to replace
Posted on Jun 03, 2011
Dean sings his arms and body move but his mouth does not i saw that someone replace d the string is there a diagram to show the workings of the doll
slide tux collar down and find 4 staples in neck, with small flat screwdriver work stales from neck, they are quite long and it takes some time. then with thumb under mouth at chin, gently wiggle and pull owtwards until mouth slides from head, mouth must be removed before head will lift from neck. once head removed, you will see drive motor near top that drives mouth. there should be a smoll nylon string connected to small plastic wheel on end of this motor, most times the adheasive that hold this string in place has let loose and string is still in tact. before reconnecting press activation button and be sure motor is spinning, if so simply reconnect string to plastic end, and reassemble head I used 2 part epoxy (JB Quick) Note if motor is not turning when activated then this too needs repaired
DW Mylin.
Sep 28, 2012 | Gemmy Bing Crosby Big Head Doll
Coleman mach 6759C707 quit on us, only the fan is running. What do i need to replace? The compressor? WHat part number?
my coleman 7330 fan only runs when ac unit is on and then sometimes shuts off and then restarts
Aug 18, 2011 | Coleman Mach III Air Conditioner
I have a coleman mack roof ac and the air is cool but the fan is not blowing it out. We left it off last night then turned it on this morning and it worked well for a while then quit blowing. Any...
Soounds as though the motor is getting hot and kicking out on overloads.. best have it checked . But my money is on your going to need a new motor..
Jul 18, 2011 | Coleman Heating & Cooling
My coleman furnace in my rv just quit blowing it stays lit but the blower doesnt work it is a coleman presidential
It could be a bad temp sensor that tells the fan to come on when the heater reaches a certain temperature or it could be a bad fan motor. Take a 12 volt jump start box and hook it directly to the fan motor to see if it will spin. If it does not the motor is bad and if it does you have to replace the temperature sensor in the heater.
Mar 18, 2011 | Coleman Heating & Cooling
NEED PART NUMBER FOR THE FAN ON A COLEMAN POWER CHILL ICELESS 12-VOLT COOLER.
Visit the Coleman replacement parts web site.
www.coleman.com/coleman/parts/PartsDefault2.asp
Jul 19, 2010 | Electronics - Others
Coleman model 5645 inside fan motor not working .. how do you open the cover to get to the fan and motor
pull straight up on the cover. Remove the 4 screws that hold the fan to the heat sink. You can then remove the 2 torx screws and remove the heat sink if you need to. Clip the wires as close to the bad fan as possible so you will have enough for the new fan.
Feb 01, 2010 | Coleman Electric Cooler 40 Beverage Cooler
The outer fan dont work. where can i get a replacement ?
Check at your local computer/ Hobby Electronics parts store.
Take the fan out of the unit and to the store with you, that way they can match it to one they may have in stock.
Sep 14, 2009 | Coleman Electric Cooler 40 Beverage Cooler
Coleman AC compreser work but fan dont
If the selector switch is broken, you need to replace that first. This will cause the fan not to come on if there is an open in it. After replacing the switch, if you still have to fan operation, it is possible that you have a bad fan capacitor, part# 1499-5461, or a bad fan motor, part# 14683099. Replace the capacitor first before spending the money on a motor. An easy way to check is to see if you can start the fan motor by hand while turning it on a the selector switch. If the motor starts this way, replace the capacitor.
Hope this helps,
Jeff
Jul 05, 2009 | Dometic 57915531 Air Conditioner
Jun 25, 2009 | Coleman Electric Cooler 40 Beverage Cooler
Gemmy Santa Bear mouth does not move
I would like to first tell you what the problem is with either your Bing or Bear head. Inside the head is a motor that works the mouth. On this rotating motor is a pulley type system, which has a twine or you could call a heavy string piece. It is attached to the motor, and when the is activated it rotates the thread round the spindle on the motor and the mouth operates.. It is quite a difficult to take this head apart. I worked on my Bing for some time to find out this problem.. The string comes away with use and of course time, that is is why the mouth no longer moves. If you wish to try and repair, you first have to remove the head from the base. If you look there are 4 heavy duty staples just round the collar neck area. They will come out with a small head screwdriver or something pointed. Just work it slowly under till staple raises up, then just pull it out. Once they are all removed the head should be loose. This is only to give you access to seeing the internals firstly. Now comes the hardest part. The soft moving part of the mouth needs to be removed. You need to work it of slowly as there is a glue base on it, so care is needed here and can take time. If you managed this all is left is the metal pin it was on. Now inside is the plastic unit that moves the mouth this is glued in which is the main problem. And this is the issue, it is pushed on and the only way is to remove is to have a precision head screwdriver and work it off... Best done by someone who is quite good with their hands and very patienced. Because it may break. Took me severals hours to remove. When you get it off the internal workings will come out of the head. There is no other way of doing this. Having the head loose allows you to look at the piece and the workings. A small torchlight held by someone is best as you work out the mouth fitting.....As i said it is no easy job and took me long periods of time to get to this point. I wish you all the luck in achieving this.......
Dec 15, 2008 | Gemmy Rocky Balboa Big Head Animated...
Coleman 5640B807 Compact Refrigerator Logo
219 people viewed this question
Top Coleman Home Experts
Donni Steen
Tom Chichester
Are you a Coleman Home Expert? Answer questions, earn points and help others
