Question about Krups KM7000
Same thing here. It was working one minute, and then is wasn't.
The water does not appear to be heating at all. The beans get ground and that's the last thing that it does. The heating plate is working.
  • SmallApplFix May 11, 2010
    Mine had the same problem ... all the lights are on, but no heating on the plate, and no dripping of water. After a weekend on the workbench, I've mastered this machine. The KM7005 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. I'll be happy to advise you to fix this, or fix it for you. Write me at KM7005@flightsystems.biz.
    Scholar:
  • 22 Answers
Mine had the same problem ... all the lights are on, but no heat on the plate and no dripping water.
After a weekend on the workbench, I've mastered this machine. The KM7000 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. I'll be happy to advise you to fix this, or fix it for you. Write me at KM7000@flightsystems.biz
Posted on Jan 31, 2010
    Problem Solver:
  • 17 Answers
Check to see if your Duo filter is clogged, and after you remove it see if there is an obstruction beneath it. Sometimes people drop coffee beans in it.
Posted on Dec 22, 2009
On Vienna Deluxe after the beans are ground and ready to drop the espresso shots, nothing comes out and the red light goes on? I shut the unit off for a minute or so, turn it back on and it works ok, but...
Solid red light is a ventilate light.. Try Priming the machine to see if the light goes away.
Something may be in the flow meter. Its the while device between the water tank and the pump of the machine. You would have to open the machine and clean out the flow meter.
Also, if you haven't descaled the machine already, I would start there.
Saeco Espresso Parts Brew Groups Pumps Boilers Water Tanks Drip trays
Mar 07, 2015 | Saeco Vienna De Luxe Espresso Machine
The problem is when I use pre ground coffee beans. The water doesn't run through. It comes over the top and the grounds get in the coffee. I buy them that way because they mark them down half price. I
There are whole coffee beans, and there are ground coffee beans, but there is no such thing as "pre-ground" coffee beans because you wouldn't want the beans to be ground AFTER making coffee.
If you have a problem using "pre-ground" beans, then STOP using pre-ground beans and grind them yourself.
I hope this helps.
Randy
Dec 01, 2012 | Coffee Makers & Espresso Machines
How many tablespoons of ground coffee are needed per cup of water in the Smart Brew coffee maker?
For ground coffee, use 1-1/2 (one and one-half) tablespoons of beans per 6 ounces of water.
For whole bean coffee, use two tablespoons of beans per 6 ounces of water.
Coffee strength is a very personal preference, so use these numbers as a guideline for middle-of-the-road coffee, and adjust to make the coffee that you like to drink.
Sep 30, 2010 | Black & Decker DLX900 12-Cup Coffee Maker
How do you make coffee in cafetiere 6 cups
You grind the beans quite fine
Pull up the knob on the lid till it pulls out of the top and the filter out of the glass container.
Put enough of the the ground coffee for six cups into the glass container , pour on boiling water till it reaches about one inch from the top
Put the top back on a push the knob slightly down to locate it in the top of the glass container
Give the water a few minutes to work on the beans and then gently push the knob all the way down so that the filter goes to the bottom og the glass container taking the grounds with it
Pour the coffee
Enjoy!!
Jun 19, 2009 | La Cafetiere Santos SN030200 3-Cup Coffee...
How do i use the pressure cooker? After adding water and beans, I let it come to boil and the steam noise is steady....then I turn down the heat? At the end I let out the steam manually, turn off and open...
Add the water and beans. Put the lid on the cooker and tighten down. Turn on the heat and let the steam make a full plume before closing the valve. Lower the temperature to medium. Watch the gauge and when it reaches the correct pressure keep adjusting the heat to maintain the pressure for however many minutes the beans need to cook. When the time is up turn off the heat and let the cooker cool for a while. Ten minutes or so. Then slowly open the pressure valve when the pressure has reduced to a low level. If the pressure is still to high when you open the valve the water will be pulled out of the beans and the jars will only be half full of liquid. Once the pressure is down to zero, open the lid carefully because the jars are still hot and break easily. As the jars cool you will hear them pop. This means that they are sealed. Good luck.
Jun 15, 2009 | Kitchen Appliances - Others
Cooking corn on cob, heating up brisket, cooking beans
1. How long does it take to cook small corn on the cob and do you add water?
20 minutes once the water starts to simmer. you only need to half cover the corn.
2. What temp do I heat up already cooked briskets, how do I keep it moist, and how long?
Add a half inch of water, 300'F for 30 minutes
3. How long do I need to cook pinto beans and at what temp?
1 hour at 275'F
here is your manual with recipes
http://www.rivalproducts.com/on/demandware.static/-/Sites-rival-products-Library/default/dwc45513c3/documents/instruction-manuals/RO230-B-1.pdf
Recipe ideas for you
rival 22 qt roaster oven recipes Google Search
Jan 03, 2018 | Rival 18 Qt Roaster Oven with Buffet...
Heat
Hey Nashville,
I have a few suggestions/questions for you. I've had the Innova(Ascaso) Dream for several years now and use it at least twice daily. I would trust your own senses before sweating the gauges too much. If you're really worried about it being a temperature problem, my first question is whether or not the espresso is actually hot when it comes out.
But my best guess is honestly your beans and grinder (or lack thereof). The problem with using pre-ground beans is that even on the day you open the can, they won't be nearly as fresh as truly fresh ground beans you grind yourself. And the problem gets dramatically worse every day after they are opened.
The key to a thick, crema-laden espresso is very fresh beans that you grind right before making your espresso. You can certainly confirm that the machine is working with any old coffee grinder and a bag of *really* fresh beans from a local roaster.
You really need all the oils that come with really fresh-roasted and fresh-ground beans. And the beans really need to be ground very fine for espresso.
I keep a can of pre-ground Illy decaf beans around for the rare occasions I need to make a decaf, and it's like night a day between that and what I drink daily.
If you try the fresh beans and grind them yourself and can see the obvious difference, then you may want to invest in a good-quality burr grinder (as opposed to the spinning blade kind that most folks use for drip coffee). The reason is that with a burr grinder you can get consistently-sized particles every time. So once you get the setting right on your grinder you can keep pumping out the shots time after time. With a rotary blade grinder you get some big pieces, some little pieces and the water flows through too easily -- or you grind it longer and (1) burn the beans from the heat, and (2) end up with some particles that are just too small -- essentially dust, that will actually clog the process.
So, my best suggestion would be to find a local cafe/roaster and buy a half a pound of beans from them and grind yourself. If you don't have a grinder or want to eliminate a variable, ask them to grind it for you for an espresso machine.
Again, if you can see the difference (and I think you will), then you can consider getting yourself a good grinder.
Tony
Jan 03, 2009 | Ascaso Dream Espresso Machine
Espresso will not come through my Saeco Gran crema
Well first thing I got to ask to exclude a couple of things.
Does it come out water if you dont have the filter or the handle on the machine?
Sep 08, 2008 | Coffee Makers & Espresso Machines
Won't grind
the container were the coffee bean go .remove the bean, in the hole were the coffee goes you see the grinder wheel clean the grinder wheel with a brush you may have coffee residue on the wheel thanks for using fixya pierre
Feb 07, 2008 | Cuisinart DGB-300 Coffee Maker
Coffee Grinder not working
the grinder is most likely stripped and needs to be replaced:-{
Jul 23, 2006 | Saeco Caffe Charisma Espresso Machine
Krups KM7000 Logo
189 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
