Shredder says bin is full but its empty won't operate
  • 328 Answers
What model is it? Most of the time some paper shreds are hanging down from the cutter asm and blocking the sensors. Unplug the unit and reach up underneith to remove the shreds.
Posted on Sep 07, 2009
SOURCE: Staples SPL-1506X Shredder Issue
I had the same problem. I have a solution but I do not recommend this unless you have technical experience with repairing electrical appliances. I took the back cover of the main shredder unit to expose the wiring (there are 7 screws in total). The bin full sensor has a blue, green, and red connected to it. I clipped the blue wire to defeat the Bin Full error. You can look through the plastic window to check that the bin is full.
Posted on Aug 09, 2008
danforddan1
  • 192 Answers
SOURCE: shredder won't shred
They may be a compression switch on the lip where it sets on the bucket. This it to prevent it from running while its off its buckette. If this is not all the way in it wont run. Look for that clean any safty switch or buttons you find.
Slap it with your tax booklet and call me in the morning. Good luck DFD
Posted on Apr 16, 2009
  • 226 Answers
SOURCE: Royal 1610X Shredder keeps indicator telling
sounds like a piece is stuck in or around the sensor
Posted on Jul 20, 2009
  • 610 Answers
SOURCE: SHREDDER INDICATOR KEEPS COMING ON WHILE SHREDDING
look for two LED lights where paper falls into bin and wipe them off, but the sensors could be faulty as well. I have seen both.
Posted on Nov 11, 2009
SOURCE: office max shredder, says bin full but its not,
I had the same problem. I found that the sensor on the shredder is light sensitive. The viewing window in the bin was letting too much light in and was triggering the bin full light to turn on. I covered the window with a piece of paper and then restarted the shredder.It worked fine after that.
Posted on Oct 02, 2010
Staples SPL-QW120D shredder is stuck on "Bin Full" even when empty?
Check operation of the bin interlock inside the area where the bin fits. It may be damaged/defective.
Sep 16, 2016 | Staples Office Equipment & Supplies
Shredder bin full
Most models: 1) unplug, 2) put something down to collect paper bits, 3) lift up the shredder top unit off the bin, 4) empty the bin, 5) try and pull out any paper from the shredder top using tweezers - first remove paper that has not fed through by pulling it back out.
Often if the bin is overfull the shredder gets clogged and won't work or beeps. When unplugged, you have to carefully remove all the bits of paper from the teeth to unjam the two rows of teeth. Remedy is to frequently empty the bin.
Jul 29, 2014 | Office Equipment & Supplies
Shredder will not operate in forward mode.
Sounds like the bin might be over full. Switch machine off. Remove top section, or open door, Empty bin. Look at shredder blades to make sure nothing is stuck in them. When sure blades are clear put back together and then switch on.
Mar 18, 2014 | Royal 15MX Shredder
Need owners manual for B&D paper shredder Model BD-10P. i have a jam
Hi and welcome to FixYa, I am Kelly.
The manual is little help but you can find it here:
http://media.homedics.com/IBs/bds/BD-10P_IB.pdf
Troubleshooting
If you have a problem with your shredder, check the symptoms and remedies below.
If you cannot solve the problem this way, contact Black & Decker paper shredders
Customer Service.
Do not open shredder head to attempt repair: It could expose
you to electric shock and will void your warranty.
- Check to see if bin is full. If bin is full, empty bin and
replace. Follow instructions under maintenance.
- Oil cutting cylinders.
Shredder squeaks, grinds or runs
below capacity.
- No action required. This is a self-Shredder continues to run for cleaning function.
1 or 2 seconds after shredding
has been completed.
Symptom Remedy
- Make sure shredder is plugged in.
- Make sure power switch is in "Auto" position.
- Make sure bin is fully closed.
- Check to see if either bin is overfull which could result
in a jam. If so, empty.
- If you are unable to clear the jam, turn off and unplug
the shredder. Slowly and carefully pull the remaining
paper out. Forcefully removing the paper is likely to
cause irreparable damage to the shredder.
Shredder does not start or stops
while shredding.
Paper jams.
HOW TO GET SERVICE:
Visit our website at www.blackanddeckershredders.com or call the toll free customer
service line at 1-800-297-5028.
® SKU #BD-10P
Product Information
This product is designed to shred paper, staples, small paper clips, credit cards, CDs and DVDs.
It is not intended to shred large paper clips, continuous forms, adhesive labels, transparencies,
newspaper, cardboard or any other plastic other than credit cards. Using it for these purposes
is likely to cause irreparable damage. Please do not attempt to shred more than 10 sheets/1 CD
or DVD at a time. Shredder should not run more than 200 sheets/50 disks continuously. Items
should be centered and unit will begin and end shredding automatically. All disks should use
specific entry as noted on your shredder.
Maintenance
It is important to empty the waste bin regularly to ensure the smooth operation of the
cutting cylinders. The shredder will not operate when the bin is full. Regular oiling
is also necessary for proper performance. It is recommended to use the shredder oil
every few weeks.
Maximum running time: 3 minutes
Automatic cool-down period: 30 minutes
Voltage: 120
If you have any questions regarding the product, please feel free to
call toll-free 1-800-297-5028
Thanks for Choosing FixYa,
Kelly
Apr 07, 2011 | Black & Decker Garden
The bin on my royal cross cut paper shredder will not open . It is full and needs to be emptied. It seems to be stuck near the top. If I pull any harder I am afraid the hard plastic will crack.
Yes it is probably "over-full".... you will just have to try to somehow get it open a little and start to fish out the paper without breaking the waste bin....it has to be emptied more frequently, there is no "bin-full" indicator.
Dec 28, 2010 | Royal Office Equipment & Supplies
How do you empty royal 10x shredder? PX1000MS Platinum
Remove the waste bin from the front and empty.
If you have it jammed so full the bin wont come out I have heard people say that they got the bin out when they turned the machine upside-down....be aware this might make a mess.
Jul 22, 2010 | Royal 10X Shredder
Nov 11, 2009 | Fellowes DM15C Shredder
The basket full light will not go out
YOU WILL HAVE TO HAVE SENSORS REPLACED
Sep 15, 2009 | Fellowes DM15C Shredder
The empty basket light stays on all the time
Try cleaning the bin full sensors. located on both sides of your machine, inside the bin,under the cutter head. If that does not solve problem, you need to replace bin full sensors.
May 04, 2009 | Fellowes Powershred 320 Shredder
Apr 25, 2008 | Office Depot Ativa DQ60M Shredder
423 people viewed this question
k24674
